ragico
#3391 Post by ragico » Sun Oct 18, 2020 6:53 pm
yusesope wrote: Sun Oct 18, 2020 6:35 pm
Yep, underscores are the heart of my hack ... without them the patcher can't work!
Sorry for the stupid question: where you put the underscores?
Example the film title is Back. Should I write Back73_ (if I choose prof.7)?
I have tried different ways with these underscores and, after the Mkv_Patcher always get this:
Where I am wrong?
By the way if I load the file from toolnix in makemkv I got DV and also hd audio and plays in Firestick and Ugoos and Shield.
But the file generated from Mkv_Patcher only plays in hdr.
yusesope
#3392 Post by yusesope » Sun Oct 18, 2020 7:08 pm
ragico wrote: Sun Oct 18, 2020 6:53 pm
Where I am wrong?
:lol: :lol: :lol:
In MkvToolNix, before start muxing, go to the "output" tab and in the "file title" field enter the title you want followed by 73 underscores in the case of profile 7 or 37 in the case of profile 8 (literally 73 or 37 underscores)
yusesope wrote: Sat Oct 17, 2020 11:19 am
#profile 7
Movie Title_________________________________________________________________________
#profile 8
ragico
#3393 Post by ragico » Sun Oct 18, 2020 7:38 pm
#profile 7
#profile 8
I have done it Film title followed by 73 underscores.
Still, after MKV_Patcher only get Hdr as mediainfo confirms. This is mkv_patcher. Is there any error?
yusesope
#3394 Post by yusesope » Sun Oct 18, 2020 7:53 pm
ragico wrote: Sun Oct 18, 2020 7:38 pm
#profile 7
#profile 8
Yep, there is a problem with the patcher!
In the next few days I will ask you to send me a sample using a hex editor so I can correct the problem!
I'll explain what to do but not now because I'm going to sleep ...
I see "Premere un tasto per continuare" in the attached image.
Are you Italian too?
jlpsvk
#3395 Post by jlpsvk » Sun Oct 18, 2020 7:53 pm
File Title metadata tag is not the same as filename.. :D
ragico
#3396 Post by ragico » Sun Oct 18, 2020 7:58 pm
yusesope wrote: Sun Oct 18, 2020 7:53 pm
#profile 7
#profile 8
Yes I am Italian
ragico
#3397 Post by ragico » Sun Oct 18, 2020 8:00 pm
jlpsvk wrote: Sun Oct 18, 2020 7:53 pm
Pls explain
yusesope
#3398 Post by yusesope » Sun Oct 18, 2020 8:04 pm
ragico wrote: Sun Oct 18, 2020 7:58 pm Yes I am Italian
Weeeeeeeeeeeee Paesà. :lol: :lol: :lol: :lol:
Nei prossimi giorni vediamo di risolvere!
E' strano che non funzioni ma il mio patcher non trova il titolo assegnato da MkvToolNix!
Sicuro di aver scritto il titolo nel campo "titolo file" (tab "destinazione")?
Buonanotte!
jlpsvk
#3399 Post by jlpsvk » Sun Oct 18, 2020 8:07 pm
ragico wrote: Sun Oct 18, 2020 8:00 pm
Pls explain
ragico
#3400 Post by ragico » Sun Oct 18, 2020 9:56 pm
jlpsvk wrote: Sun Oct 18, 2020 8:07 pm
Pls explain
Thank you. It have no effect.
ray_007
#3401 Post by ray_007 » Mon Oct 19, 2020 12:00 am
I have tried the Skip HDR10+ method on Hobbs and Shaw and Harley Quinn which are both FEL titles and it worked wonderfully :D
thanks again @yusesope for your hard work
jlpsvk
#3402 Post by jlpsvk » Mon Oct 19, 2020 8:26 am
ray_007 wrote: Mon Oct 19, 2020 12:00 am I have tried the Skip HDR10+ method on Furious 7 and Harley Quinn which are both FEL titles and it worked wonderfully :D
I don't know what UHD's you have, but AFAIK, Furious 7 has no Dolby Vision or HDR10+ (only static HDR), and Birds of Prey has MEL.
ray_007
#3403 Post by ray_007 » Mon Oct 19, 2020 3:32 pm
jlpsvk wrote: Mon Oct 19, 2020 8:26 am
edited my original post. Also, they are both HDR10+ and FEL titles, at least in my case.
jlpsvk
#3404 Post by jlpsvk » Mon Oct 19, 2020 7:26 pm
ray_007 wrote: Mon Oct 19, 2020 3:32 pm
yeah... that's different.. :) Hobbs and Shaw has FEL, but I haven't seen Birds of Prey with FEL, only MEL.
ragico
#3405 Post by ragico » Mon Oct 19, 2020 9:58 pm
@Yusesope
I did other tests and got your MKV_Patcher to work finally.
Because the film is Fel, I choose this "python-3.7.6.amd64\python.exe src\app.py -fel_to_mel -mux_exp" in MUX_Experimental
This is the mediainfo from patched file:
General
Unique ID : 233615448083088882690800691470456384375 (0xAFC0B2DD93337F34F8479E8D2E04EB77)
Complete name : I:\v0.0.4_BETA_TEST_FEL_TO_MEL_PLUS_UHDBD_TO_81__PLUS_SKIP_HDR10plus__PLUS_EXPERIM_MUXER_17102020\transporter.mkv
Format : Matroska
Format version : Version 4
File size : 674 MiB
Duration : 2 min 0 s
Overall bit rate : 47.0 Mb/s
Movie name : transporter_
Encoded date : UTC 2020-10-19 21:34:37
Writing application : mkvmerge v51.0.0 ('I Wish') 64-bit
Writing library : libebml v1.4.0 + libmatroska v1.6.2
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 47.0 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.237
Stream size : 674 MiB (100%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light Level : 907 cd/m2
This file plays as HDR in firestick and as DV in Ugoos/shield.
