Trouble burning with WH14NS40
skeksis
Post by skeksis »
Tried searching for this answer and the closest i could come to an answer was cross flashing of firmware but i don't think it fits my issue here? Bought a drive and it totally can read 4k, it extracts the file fine however, once i try to burn files using anyburn or burnaware it gets a write error or it just flat out does not work/takes too long to respond. I have it hooked to an external sata to usb converter. the previous bluray drive works fine so im sure its the drive itself and not some bandwidth issue. i tried burning bdr 50gb, bdxl, mdisc, all failed.
here is the info
The sticker on the drive itself says WH14NS40 by the way.
OS device name: E:
Product: BD-RE WH16NS40
Revision: 1.02
Serial number:
Firmware date: 2117-03-10 16:50
Highest AACS version: 62
Firmware version: 1.02
is there a reason for this? i really need to burn bdxl discs but im guessing i cant have best of two worlds since the 4k reading of discs are fine. would going back to previous firmware that maybe cant read 4k be too much of a hassle? if not ill just leave it alone.. thanks
Re: Trouble burning with WH14NS40
skeksis wrote:
Sun Oct 18, 2020 7:03 am
here is the info
OS device name: E:
Revision: 1.02
Serial number:
first try going to WH16NS60 1.02mk and see if burning works
skeksis
Post by skeksis »
Thanks for the reply, i will try that. I went over here https://www.makemkv.com/forum/viewtopic ... 19&t=19113 and downloaded the pack but the directory named WH16NS60 contains a file with the extension .bin but has 1.03 on there and not 1.02, is there a backup somewhere of 1.02mk? thanks again.
skeksis wrote:
Sun Oct 18, 2020 8:22 am
in the old folder
LG drives are lousy burners for all discs >25GB. They consistently fail at the layer break when they switch at the 25GB limit of the first layer to the next. For decent results you need a Pioneer burner an Japanese Verbatim 50GB discs.
I never tried anything with even larger discs but I guess even more trouble is coming your way.
What is the purpose of these big discs? If I have anything larger than 50GB I use Elby's CloneBD to shrink it to 50GB.
skeksis
Post by skeksis »
Billycar11 wrote:
Sun Oct 18, 2020 9:22 am
in the old folder
I noticed right after I hit the reply button. But yea, i patched to 1.02mk and it still fails to burn, on anyburn it says
"Error writing data"
It detects the disk as empty, says VERBAT for disc manufacturer under disc information but no dice with actually burning. Any other tips or suggestions I should try or should I just move on?
Coopervid wrote:
Sun Oct 18, 2020 9:50 am
Strangely enough my previous bluray drive that i used to burn is a Pioneer burner. The disks Im using now are verbatim 50gb discs. I dont mind not having the option to burn with this LG but just trying to find out why I cant burn at all using any disc. I guess Ill use the pioneer to burn and this to rip uhd exclusively. I was just trying to burn regular data discs.
I would continue with the Pioneer only to burn discs. Maybe you have some exotic discs the LG doesn't have a burn strategy in its firmware. Install IMGBURN and it will show if the LG has burn strategies for your disc. Try other / smaller capacity discs if those work. Anyway - using the LG for discs >25GB is not a good idea at all. They will have quality issues. Multi-layer BDs can't avoid the critical outer section. The burner just burns to the end of layer 1 and then continues with layer 2. The layer braek can not be set as it was the case with multi-layer DVDs. With those you could avoid the critical outer section.
skeksis
Post by skeksis »
Here are the results from IMGBurn. Anyways thanks for the replies guys, this place is pretty active :D. What is the ultimate burner out there right now?
I 11:07:05 ImgBurn Version 2.5.8.0 started!
I 11:07:05 Microsoft Windows 8 Enterprise x64 Edition (6.2, Build 9200)
I 11:07:05 Total Physical Memory: 16,697,360 KiB  -  Available: 10,810,812 KiB
I 11:07:05 Initialising SPTI...
I 11:07:05 Searching for SCSI / ATAPI devices...
I 11:07:05 -> Drive 1 - Info: HL-DT-ST BD-RE  WH16NS60 1.02 (E:) (USB 2.0)
I 11:07:05 Found 1 BD-RE XL!
HL-DT-ST BD-RE  WH16NS60 1.02 (USB)
Current Profile: BD-R
Disc Information:
Status: Empty
State of Last Session: Empty
Erasable: No
Free Sectors: 24,438,784
Free Space: 50,050,629,632 bytes
Free Time: 5430:52:34 (MM:SS:FF)
Next Writable Address: 0
MID: VERBAT-IMf-000
Supported Write Speeds: 2x, 4x, 6x, 8x
BD Disc Information (L0):
Disc ID: VERBAT-IMf-000
Disc Type: BD-R
Disc Size: 120 mm
Disc Class: 0
Disc Version: 1
Number of Layers: 2
Layer Type: Writable
DVD Layer Present: No
CD Layer Present: No
Channel Bit Length: 74.50 nm (25 GB Per Layer)
Push-Pull Polarity: Positive
Recorded Mark Polarity: HTL
BCA Present: Yes
Maximum Transfer Rate: Not Specified
First PAA of Data Zone: 131,072
Last PAA of Data Zone: 1,658,494
BD Disc Information (L1):
Disc Type: BD-R
Disc Size: 120 mm
Disc Class: 0
Disc Version: 1
Number of Layers: 2
BCA Present: Yes
First PAA of Data Zone: 2,535,808
Last PAA of Data Zone: 4,063,230
Format Capacities:
DT: 0x01 - NB: 24438784 (0x0174E800) - TDP: 413696
FT: 0x00 - NB: 23652352 (0x0168E800) - TDP: 24576
FT: 0x32 - NB: 23652352 (0x0168E800) - TDP: 0
FT: 0x32 - NB: 11200512 (0x00AAE800) - TDP: 0
FT: 0x32 - NB: 24307712 (0x0172E800) - TDP: 0
Performance (Write Speed):
Descriptor 1...
-> B0: 0x00, B1: 0x00, B2: 0x00, B3: 0x00
-> EL: 24438783 (0x0174E7FF)
-> RS: 35,968 KB/s (8x) - WS: 8,992 KB/s (2x)
Descriptor 2...
-> RS: 35,968 KB/s (8x) - WS: 17,984 KB/s (4x)
Descriptor 3...
-> B0: 0x08, B1: 0x00, B2: 0x00, B3: 0x00
-> RS: 35,968 KB/s (8x) - WS: 26,976 KB/s (6x)
Descriptor 4...
-> RS: 35,968 KB/s (8x) - WS: 35,968 KB/s (8x)
Can you burn using IMGBURN?
Pioneer BD burners are the best. Just get a most recent one. I own a 209.
skeksis
Post by skeksis »
Will do that. No I get the same thing with imgburn, it wont write. Guessing the drive itself is messed up where it cant burn but only read.
edit: i tried 1.02 original, 1.03mk, 1.05mk, downgraded, nothing gets it to burn so im guessing the drive itself is defective and is not capable of burning. the drive itself has sticker that reads 1.03 so the last thing to try is the official? not gonna do that. oh well. if you guys have any other tries i could do let me know, i even hooked it up directly to the sata, same deal, it wont start burning no matter what file i try, tried different discs as well.
just just stops after this
I 14:21:43 ImgBurn Version 2.5.8.0 started!
I 14:21:43 Microsoft Windows 8 Enterprise x64 Edition (6.2, Build 9200)
I 14:21:43 Total Physical Memory: 16,697,360 KiB  -  Available: 13,515,148 KiB
I 14:21:43 Initialising SPTI...
I 14:21:43 Searching for SCSI / ATAPI devices...
I 14:21:43 -> Drive 1 - Info: HL-DT-ST BD-RE  WH14NS40 1.05 (E:) (SATA)
I 14:21:43 Found 1 BD-RE XL!
I 14:22:00 Operation Started!
I 14:22:00 Building Image Tree...
I 14:22:00 Calculating Totals...
I 14:22:00 Preparing Image...
I 14:22:00 Contents: 1 File, 0 Folders
I 14:22:00 Content Type: Data
I 14:22:00 Data Type: MODE1/2048
I 14:22:00 File System(s): UDF (1.02)
I 14:22:00 Volume Label: [Not Configured]
I 14:22:00 Size: 31,265,650,989 bytes
I 14:22:00 Sectors: 15,266,432
I 14:22:00 Image Size: 31,266,242,560 bytes
I 14:22:00 Image Sectors: 15,266,720
I 14:22:00 Operation Successfully Completed! - Duration: 00:00:00
I 14:22:04 Operation Started!
I 14:22:04 Building Image Tree...
I 14:22:08 Calculating Totals...
I 14:22:08 Preparing Image...
I 14:22:08 Contents: 1 File, 0 Folders
I 14:22:08 Content Type: Data
I 14:22:08 Data Type: MODE1/2048
I 14:22:08 File System(s): UDF (1.02)
I 14:22:09 Volume Label: TEST FILES
I 14:22:09 Size: 31,265,650,989 bytes
I 14:22:09 Sectors: 15,266,432
I 14:22:09 Image Size: 31,266,242,560 bytes
I 14:22:09 Image Sectors: 15,266,720
I 14:22:11 Operation Successfully Completed! - Duration: 00:00:06
I 14:22:11 Operation Started!
I 14:22:11 Source File: -==/\/[BUILD IMAGE]\/\==-
I 14:22:11 Source File Sectors: 15,266,720 (MODE1/2048)
I 14:22:11 Source File Size: 31,266,242,560 bytes
I 14:22:11 Source File Volume Identifier: TEST FILES
I 14:22:11 Source File Volume Set Identifier: 515272C200E8F386
I 14:22:11 Source File Application Identifier: ImgBurn v2.5.8.0
I 14:22:11 Source File Implementation Identifier: ImgBurn
I 14:22:11 Source File File System(s): UDF (1.02)
I 14:22:11 Destination Device: [0:0:0] HL-DT-ST BD-RE  WH14NS40 1.05 (E:) (SATA)
I 14:22:11 Destination Media Type: BD-R (Disc ID: VERBAT-IMf-000)
I 14:22:11 Destination Media Supported Write Speeds: 2x, 4x, 6x
I 14:22:11 Destination Media Sectors: 24,438,784
I 14:22:11 Write Mode: BD
I 14:22:11 Write Type: DAO
I 14:22:11 Write Speed: 6x
I 14:22:11 Hardware Defect Management Active: No
I 14:22:11 BD-R Verify Not Required: Yes
I 14:22:11 Link Size: Auto
I 14:22:11 Lock Volume: Yes
I 14:22:11 Test Mode: No
I 14:22:11 OPC: No
I 14:22:11 BURN-Proof: Enabled
I 14:22:11 Write Speed Successfully Set! - Effective: 26,976 KB/s (6x)
I 14:30:57 Filling Buffer... (80 MiB)
I 14:30:58 Writing LeadIn...
skeksis wrote:
Sun Oct 18, 2020 8:02 pm
Urf that sucks that is one of the reasons I stoped selling these so many defective
For uhd ripping I recommend you go back to WH16NS60 firmware to avoid the sleep bug and have faster ripping speeds
skeksis
Post by skeksis »
yup went back to that firmware now. it indeed feels more snappier when ripping.
