Thanks Mike!
Yugatha
Thanks Mike!
#1 Post by Yugatha » Sat Aug 01, 2015 5:53 am
Having just downloaded the 1.9.5 version, I am SO HAPPY that you can limit an instance of MakeMKV to an individual drive. It makes it much easier to work through discs.
THANKS MIKE!!!!!!
:mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
kevmitch
Re: Thanks Mike!
#2 Post by kevmitch » Sat Aug 01, 2015 7:00 am
I was also excited to see this in the changelog. Thanks so much.
At first I felt a little dumb as I couldn't find the setting. Somehow my eyes kept skipping over it even though I looked at the relevant tab a couple times.
In case anyone else is looking for this it's in
View->Preferences->IO->Ask for single drive mode.
Once this is enabled, makemkv will prompt you which drive you want to use on startup, which is perfect.
ndjamena
Re: Thanks Mike!
#3 Post by ndjamena » Sat Aug 01, 2015 10:32 am
Wow, I never thought this would happen after I asked the first time... then went back and found other feature requests for the same thing.
THIS IS PROGRESS PEOPLE!!!
Now I wish I had a bunch of DVD box sets I could rip in tandem just so I can gloat.
BlenderRookie
Re: Thanks Mike!
#4 Post by BlenderRookie » Thu Jul 09, 2020 6:36 pm
kevmitch wrote: Sat Aug 01, 2015 7:00 am I was also excited to see this in the changelog. Thanks so much.
Thanks, that's exactly what I needed being that I am using 3 optical drives and 3 instances ok makemkv
Meister_Proper
Re: Thanks Mike!
#5 Post by Meister_Proper » Sun Oct 18, 2020 5:14 am
Hey Mike, just want to thank you as well for all your efforts through the years. I've been a long time user with the beta key but I finally bought a key.
