Fatal error from successful disc backup and from disc.
nathaniel7
Post by nathaniel7 »
Title: Nine Inch Nails Live: Beside You in Time (BR)
I have the last MakeMKV for Mac and the latest allcombo.svq. I have 2 different brand Blu-Ray drives. I get a Fatal error if I try to MakeMKV from either drive, but MakeMKV full disc Backup was successful, and I also get a Fatal error when I try to process the Backup to an MKV. Any ideas? Thanks!
MakeMKV_log.fromDisc.txt
MakeMKV_log.fromBackup.txt
nathaniel7
Re: Fatal error from successful disc backup and from disc.
Wow I thought after a couple days I might have a reply...
Post by mike admin »
The log shows that VC-1 video is encoded not in accordance with blu-ray spec. Is this a regular commercial blu-ray disc?
nathaniel7
mike admin wrote:The log shows that VC-1 video is encoded not in accordance with blu-ray spec. Is this a regular commercial blu-ray disc?
Yes, it is. Title: Nine Inch Nails Live: Beside You in Time (BR) - http://www.amazon.com/Nine-Inch-Nails-L ... 532&sr=8-1
Then it's a bug in MakeMKV. Your log contains all diagnostic information, there's nothing you can do right now for work around.
nathaniel7
No problem, I was just looking to tell you about it Mike so it might get fixed one day. Thank you.
beatmaster
Post by beatmaster »
Hello there.
I have the same problem with the disc. at least the newer version of makeMKV recognizes the valid length of the main feature, 1:32:28 instead of 40 odd something minutes.
Saving 1 titles into directory /Volumes/Media/HD
DEBUG: Code 0 at K.d>/q.#5<psfdj?#.I:213131525
DEBUG: Code 0 at db(U'_iL&izym*Rbn#V*O:29397449
DEBUG: Code 0 at a+>Es62@;/*QoW6p@9h:121263751
DEBUG: Code 0 at a+>Es62@;/*QoW6p@9h:29399818
DEBUG: Code 0 at a+>Es62@;/*QoW6p@9h:121265200
DEBUG: Code 0 at a+>Es62@;/*QoW6p@9h:213130444
DEBUG: Code 0 at a+>Es62@;/*QoW6p@9h:121261934
DEBUG: Code 0 at db(U'_iL&izym*Rbn#V*O:121265775
DEBUG: Code 0 at RqKWk})Y!>)e2%(~bo,:29394160
DEBUG: Code 0 at RqKWk})Y!>)e2%(~bo,:29395195
Failed to save title 0 to file /Volumes/Media/HD/title00.mkv
0 titles saved, 1 failed
Devices: WDTV Live Hub, LG GGW-H20L, MacPro 1.1, and microsoft hd dvd drive with MBP 2011
Software: MakeMKV 1.7.4, OSX 10.7.3
beatmaster wrote:Hello there.
Is it the same disc? The error indicates an invalid VC-1 interlaced stream, or another bug in MakeMKV.
beatmaster
yes, its the same disc as nathaniel7 mentioned. heck, its even the same place i bought it ;)
beatmaster
still not working, new message though:
Saving 1 titles into directory /Users/xxx/Movies
DEBUG: Code 0 at 1)FjO]"Qy6H&!MBg]V0:213131525
DEBUG: Code 0 at luo#3Eb+D*r/#@J397H>s:29397449
DEBUG: Code 0 at c`3WolRZvs{N2#VuL-[:121263751
DEBUG: Code 0 at c`3WolRZvs{N2#VuL-[:121267822
DEBUG: Code 0 at c`3WolRZvs{N2#VuL-[:121265200
DEBUG: Code 0 at c`3WolRZvs{N2#VuL-[:213130444
DEBUG: Code 0 at c`3WolRZvs{N2#VuL-[:121261934
DEBUG: Code 0 at luo#3Eb+D*r/#@J397H>s:121265775
DEBUG: Code 0 at x\a?3*Imqm*~?QB+vvl:29394160
DEBUG: Code 0 at x\a?3*Imqm*~?QB+vvl:29395195
Failed to save title 0 to file /Users/xxx/Movies/title00.mkv
beatmaster wrote:still not working, new message though:
Your full debug log file should contain a lot of additional info. Please mail it to support@makemkv.com for troubleshooting, feel free to remove any private information from it.
beatmaster
sadly it still doesn’t work with 1.6.10 :(
i’ll send the debug log file again.
theairic
Post by theairic »
Did this ever get resolved? I have the same blu-ray and I get the same error when trying to MakeMKV.
beatmaster
had to make a decrypted backup with makemkv, and then use tsmuxerGUI and mkvtoolsnix to get a working mkv with chapters.
took me several attempts. trying with the new beta once I've got enough time to spare.
m0thr4
Post by m0thr4 »
Not working in 1.7.77 (OS X). Immediate fail when trying to decrypt.
