Wall-E (2008), Cannot Backup or Discern Playlist
swampdaddy
I was trying to rip Wall-E (2008) I was not able to Backup the Blu Ray Disc. Also, there are a bunch of versions (Playlists) and I have no way to determine the correct Playlist? Now after restarting the iMac and switching USB ports and power-cycling the optical drive, I now get a FATAL ERROR when trying to backup the disc. So, any ideas which Playlist is correct? Also, any ideas why the backup has been failing? Thanks!
- Screen Shot 2020-10-16 at 3.56.58 PM.png (376.18 KiB) Viewed 8379 times
- Screen Shot 2020-10-16 at 3.45.15 PM.png (164.03 KiB) Viewed 8379 times
- Screen Shot 2020-10-16 at 3.31.33 PM.png (319.88 KiB) Viewed 8379 times
Re: Wall-E (2008), Cannot Backup or Discern Playlist
The Wall-e disc is a little weird it seems.
https://www.makemkv.com/forum/viewtopic.php?f=8&t=1903
I assume your drive is external and plugged in via USB. Is the drive powered by USB or is it in a powered enclosure?
swampdaddy
The OWC purchased external USB3 drive is powered.
