Buffalo BRXL-PT6U2VB BN12 revision, MK ready?
Hyacin
Re: Buffalo BRXL-PT6U2VB BN12 revision, MK ready?
Post by Hyacin »
Hello all,
Not sure if my last post is awaiting moderation or has been lost in the nether.
I just picked up one of these, flashed it with the firmware from this thread, using the 'modified Asus / LG flasher" as that was the only flasher I could find anywhere on the forum. It seems to have worked, and the drive now shows LibreDrive details in MakeMKV, but I get 'Loading' and then 'No disc' - I tried Logan and Warcraft, same from both. Debug log shows -
Debug log started at Wed Oct 14 20:59:18 2020 , written by MakeMKV v1.15.3 win(x64-release)
001005:0000 MakeMKV v1.15.3 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\hyaci/MakeMKV_log.txt
DEBUG: Code 3 at !-!"R$A%ucExUN:=,c&[KL| :29395310
SDF  v07b: BUFFALO_Optical_Drive_BN12_211905141415_MO2JCDH5408
Any help/pointers would be greatly appreciated. Thanks!!
OS device name: E:
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BN12
Serial number: <snip>
Firmware date: 2119-05-14 14:15
Bus encryption flags: 1F
Firmware version: 0.BN120
Hyacin wrote:
Wed Oct 14, 2020 9:06 pm
Hello all,
what firmware did your drive come with BN12 or did you have the EU version of this drive?
Hyacin
Post by Hyacin »
Billycar11 wrote:
Wed Oct 14, 2020 11:28 pm
BN12, ordered from dell.ca.
Hyacin
Post by Hyacin »
Did some more digging, flashed BU40N-N from the latest bundle, and I'm all good now!!
dgraygt
Post by dgraygt »
Hello, as an update I confirm than the firmware BN12 doesn´t work for me, I flashed the DE_LG BU40N_1.00.bin firmware and all is working fine now
