You don't even need to flash your drive it's already compatible what are you running around bothering everyone with it forwilliamw38 wrote: Tue Oct 13, 2020 11:51 ammine came with this one but i cant find it anywhereMartyMcNuts wrote: Mon Oct 12, 2020 9:57 amHere you go. Freshly extracted from the BU50N installer...williamw38 wrote: Mon Oct 12, 2020 7:39 am Where could i find DE firmware?, the zip file i downloads only hás mk firmware
DE_LG_BU50N_1.00.bin.zip
Manufacturer: hp HLDS
Product: BDRE BU50N
Revision: BW50
Serial number: KZEH9KA5649
Firmware date: 2116-12-22 10:52
Bus encryption flags: 1F
Highest AACS version: 23
Firmware version: 0.BW50P
Re: SDFtool Flasher
Re: SDFtool Flasher
Based on his post history:Billycar11 wrote: Tue Oct 13, 2020 6:05 pm You don't even need to flash your drive it's already compatible what are you running around bothering everyone with it for
https://www.makemkv.com/forum/viewtopic ... 778#p96778
He broke something or the drive has somehow recently failed and is now struggling to try and recover it. Believing there is a correlation between the firmware and the uninstall he executed of the drive/drivers within Windows. It appears he’s trying everything under the sun to try and recover it. Be it blindly or not and totally unrelated to anything being discussed here.
Re: SDFtool Flasher
i see its probably that ransomware protection garbagest4evr wrote: Wed Oct 14, 2020 12:13 am
Re: SDFtool Flasher
No.williamw38 wrote: Tue Oct 13, 2020 11:39 amthis is not the firmware that cames with my drive, my drive cames with bw50 one, so do you have bw50 one?MartyMcNuts wrote: Mon Oct 12, 2020 9:57 amHere you go. Freshly extracted from the BU50N installer...williamw38 wrote: Mon Oct 12, 2020 7:39 am Where could i find DE firmware?, the zip file i downloads only hás mk firmware
williamw38
Re: SDFtool Flasher
that because the drive broke, does not read any bluray disc even blank ones, no matter firmware i put the drive does not read any bluray anymore ,so i flashed two firmwares and got worse now does not play dvds either because i lost bw50 firware that played dvds, why bothering? that because i bought lifetime makemkv original licence program so i need some support here,Billycar11 wrote: Tue Oct 13, 2020 6:05 pmYou don't even need to flash your drive it's already compatible what are you running around bothering everyone with it forwilliamw38 wrote: Tue Oct 13, 2020 11:51 ammine came with this one but i cant find it anywhereMartyMcNuts wrote: Mon Oct 12, 2020 9:57 am
Product: BDRE BU50N
Revision: BW50
williamw38
Re: SDFtool Flasher
i dont have this firmware anymore because people here told me to flash an unofficial firmware....Billycar11 wrote: Tue Oct 13, 2020 6:05 pmYou don't even need to flash your drive it's already compatible what are you running around bothering everyone with it forwilliamw38 wrote: Tue Oct 13, 2020 11:51 ammine came with this one but i cant find it anywhereMartyMcNuts wrote: Mon Oct 12, 2020 9:57 am
Product: BDRE BU50N
Revision: BW50
williamw38
Re: SDFtool Flasher
no one cared to reply my original post, i need some support here....st4evr wrote: Wed Oct 14, 2020 12:13 amBased on his post history:Billycar11 wrote: Tue Oct 13, 2020 6:05 pm You don't even need to flash your drive it's already compatible what are you running around bothering everyone with it for
williamw38
Re: SDFtool Flasher
the problem is not windows , i even tried a clean windows installation erasing all data on hard drive and didnt work either, so i open an dispute on aliexpressst4evr wrote: Wed Oct 14, 2020 12:13 amBased on his post history:Billycar11 wrote: Tue Oct 13, 2020 6:05 pm You don't even need to flash your drive it's already compatible what are you running around bothering everyone with it for
Re: SDFtool Flasher
Does windows see the discs you put in file explorer?williamw38 wrote: Wed Oct 14, 2020 6:32 pm
williamw38
Re: SDFtool Flasher
Billycar11 wrote: Wed Oct 14, 2020 6:59 pmDoes windows see the discs you put in file explorer?williamw38 wrote: Wed Oct 14, 2020 6:32 pm
williamw38
Re: SDFtool Flasher
Windows does not ser any bluray in filé explorer only DVDs e CDs, like i said it does not read any bluray disc makemkv is loading and then appers no disc, in filé explorer is bdre does not show the disc and the same with DVDFab passkey, i think is a hardware problem, i removed windows drivers trying to fix bluray problem
williamw38
Re: SDFtool Flasher
Maybe is a defective burner driver, that they trying to refurbish and resell i dont know, i made a vídeo to prove on AliExpress, i should have bought from Amazon or ebay
Re: SDFtool Flasher
I think I have one of the newer versions of WH16NS40 (1.05), but I forgot to check the "enc" option when flashing. Now I get this:
Did I mess up by not using the enc option? What can I do?
Re: SDFtool Flasher
Flash to WH16NS60 1.02mk with enc checked and it will worktardiev wrote: Tue Oct 20, 2020 6:00 am I think I have one of the newer versions of WH16NS40 (1.05), but I forgot to check the "enc" option when flashing. Now I get this:
mazdamundi
Re: SDFtool Flasher
Sorry to have to bother with another trouble shooting question. I'm trying to flash my HL-DT-ST BD-RE BP60NB10. When I select the `HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin` from the mk-firmware-pack-20200720/MK/HL-DT-ST/BP60NB10 folder and select the enc option (not shown in screenshot)
I'll get the following error
I tried the bin files for BP60NB10 in the old folder, but they too give me an error. Any suggestions on what I can or should do?
Below is my device information. I appreciate any help or advice any one has to offer.
OS device name: M:
Product: BD-RE BP60NB10
Revision: 1.02
Serial number:
Firmware date: 2120-05-07 09:35
Harware support: Yes
Firmware support: No
Firmware version: 1.02
OS device name: M:
Revision: 1.02
Serial number:
