Permissions issue with 1.15.3
chowbok
Post by chowbok » Wed Oct 14, 2020 7:23 am
I'm noticing now that MKVs I create have 666 file permissions, even though my umask is 0022. This behavior seemed to have started with 1.15.3, though I suppose it's possible something else changed on my system around the same time I upgraded. Is anyone else seeing this behavior?
Reiver
Re: Permissions issue with 1.15.3
Post by Reiver » Thu Oct 15, 2020 9:33 pm
Yes, I'm seeing the same for all files created for a mkv image or a full backup but directories have the correct umask. Skimming a diff between makemkv-oss-1.15.1 and makemkv-oss-1.15.3 doesn't immediately show the cause.
chowbok
Post by chowbok » Wed Oct 28, 2020 12:36 pm
Hopefully this can be fixed in the next version.
chowbok
Post by chowbok » Fri Oct 18, 2024 6:42 pm
This was never fixed. Can it be? It's inconvenient to have to change the permissions after every rip.
Post by dcoke22 » Tue Oct 22, 2024 3:17 pm
Is the behavior the same on the current 1.17.8 version?
chowbok
Post by chowbok » Tue Oct 22, 2024 3:31 pm
Yes.
