I converted an .iso file to a .mkv file with makeMKV. It looks succesfully. I tried to play it on my LG 42LE8500. The TV starts to play, but almost directly the error "loading" is displayed. Then again the movie seems to start, but directly the message "loading". This repeats all the time.
Does anyone knows what is the reason for this and how it can be solved?
LG continuously returns to "loading"
Re: LG continuously returns to "loading"
Probably a flawed .ISO image file (or one that's not decrypted).
1) What was the source material from which you created the .ISO image file?
2) What software and procedures did you use to create the .ISO image file?
3) Have you (as you should) tried mounting and playing the .ISO image file (with NO support programs running in the foreground or background)?
