Dolby Vision and 1.15.1
Re: Dolby Vision and 1.15.1
Post by dcoke22 » Wed Oct 14, 2020 1:39 am
@Larrikin
Cool. I'm glad it's working.
I'm curious about the AC-3. Can you post your conversion profile for it?
Larrikin
Post by Larrikin » Wed Oct 14, 2020 1:43 am
dcoke22 wrote: Wed Oct 14, 2020 1:39 am @Larrikin
Sure.
Here it is:
<?xml version="1.0" encoding="utf-8"?>
<profile>
<!-- profile name - Default -->
<name lang="eng">AC3</name>
<!-- Common MKV flags -->
<mkvSettings
ignoreForcedSubtitlesFlag="true"
useISO639Type2T="false"
setFirstAudioTrackAsDefault="true"
setFirstSubtitleTrackAsDefault="true"
setFirstForcedSubtitleTrackAsDefault="true"
insertFirstChapter00IfMissing="true"
<outputSettings name="ac3" outputFormat="AC3">
<description lang="eng">Save as AC3</description>
<extraArgs>-b 640k</extraArgs>
</outputSettings>
<trackSettings input="DTSHDMA-multi">
<output outputSettingsName="ac3"
defaultSelection="$app_DefaultSelectionString,+sel:true">
</output>
</trackSettings>
<!-- Save DTS as AC3 -->
<trackSettings input="DTS-stereo">
</output>
</trackSettings>
<trackSettings input="DTS-multi">
</output>
</trackSettings>
</profile>
Larrikin
Post by Larrikin » Wed Oct 14, 2020 2:25 am
Well, maybe I spoke too soon. I've come across a DTS X 7.1 sound track, and tried running it with the AC3 profile.
I got this error message and it wouldn't run:
FFMPEG_ERROR: FFENC002: [ac3 @ 0x7ff80d039e00] Specified channel layout '7.1' is not supported
Any ideas?
Post by MartyMcNuts » Wed Oct 14, 2020 3:21 am
Larrikin wrote: Wed Oct 14, 2020 2:25 am
Any ideas?
In ffmpeg you will need to downmix to 5.1 as AC3 cannot handle more channels than 5.1. Just add -ac 6 to ffmpeg command and it will automagically downmix to 5.1 channels.
I'm not sure if you can use the plain old DTS audio but you can use ffmpeg to extract the DTS core from a DTS-HD track by adding the following to your ffmpeg command: -bsf:a dca_core -c:a copy
And this also goes for trueHD. FFMPEG has an experimental trueHD encoder so you could try using: -c:a truehd -strict -2 -ac6
Larrikin
Post by Larrikin » Wed Oct 14, 2020 3:26 am
MartyMcNuts wrote: Wed Oct 14, 2020 3:21 am
You also mentioned you would prefer plain DTS if possible. You can use ffmpeg to extract the DTS core from a DTS-HD track by adding the following to your ffmpeg command: -bsf:a dca_core -c:a copy
Hey - thanks for your interest and help. I don't prefer DTS as my soundbar can't support it, so apologies for confusion there.
As for adding -ac 6 to ffmpeg command, I'm not running my own instance of ffmpeg. I am using MakeMKV and using the profile above. Unless I am mis-understanding what you mean?
Post by MartyMcNuts » Wed Oct 14, 2020 3:32 am
Larrikin wrote: Wed Oct 14, 2020 3:26 am
Doesn't the script from dcoke22 use ffmpeg? I though he said that in his comment?
Larrikin
Post by Larrikin » Wed Oct 14, 2020 3:36 am
@martymcnuts No. I am using this method:
Also, I was able to hack a conversion profile for MakeMKV 1.15.3 that seems to have converted a multichannel DTS track into a multichannel AAC track (using FFmpeg) while creating the MKV file. I've tested it a single time and verified the output using mediainfo.
I created a file with the contents below named aactest.mmcp.xml and put it in ~/Library/MakeMKV/aactest.mmcp.xml
So I used my own profile above for AC3 instead of AAC.
Post by MartyMcNuts » Wed Oct 14, 2020 3:45 am
Larrikin wrote: Wed Oct 14, 2020 3:36 am @martymcnuts No. I am using this method:
Oh, well. Just so you know, if you decide to use ffmpeg and mkvtoolnix, you can use ffmpeg to convert the audio to trueHD and mux with your video using mkvtoolnix.
Larrikin
Post by Larrikin » Wed Oct 14, 2020 3:46 am
MartyMcNuts wrote: Wed Oct 14, 2020 3:45 am
I'm literally giving that a go now :). I'm also going to see if I can upscale it to E-AC3.
Larrikin
Post by Larrikin » Wed Oct 14, 2020 3:59 am
Actually, I should use TrueHD instead of E-AC3. TrueHD 5.1.
This is the command I used for e-ac3. What should change so it does TrueHD 5.1 instead?
/Users/larrikin/Applications/ffmpeg -i /Volumes/ATP/Media/Movies4K/Apollo.13/Apollo.13.1995.mkv -vn -ac 6 -sn -c:a eac3 -b:a 960k -map 0:1 /Users/larrikin/Disposable.Data2/audioe.ac3
Post by MartyMcNuts » Wed Oct 14, 2020 4:17 am
Larrikin wrote: Wed Oct 14, 2020 3:59 am
change to:
/Users/larrikin/Applications/ffmpeg -i /Volumes/ATP/Media/Movies4K/Apollo.13/Apollo.13.1995.mkv -vn -sn -c:a truehd -strict -2 -b:a 1536k -map 0:1 /Users/larrikin/Disposable.Data2/audio.thd
also, if the audio you want to convert is greater than 5.1 channels then add -ac 6 before -map
Larrikin
Post by Larrikin » Wed Oct 14, 2020 4:23 am
Thanks mate. I have started it and its processing now. I'm not sure it will give me the desired result though as one thing that popped up on the screen as its processing it is:
[truehd @ 0x7ff01684c400] Only mono and stereo are supported at the moment.
Post by MartyMcNuts » Wed Oct 14, 2020 4:34 am
Larrikin wrote: Wed Oct 14, 2020 4:23 am
It said that for me too
[truehd @ 00000172495239c0] Only mono and stereo are supported at the moment.
however, it also says a few lines below
Stream #0:0: Audio: truehd, 48000 Hz, 5.1, s16, 1536 kb/s
When I checked the file out in mediainfo, it says it's 6 channel.
Larrikin
Post by Larrikin » Wed Oct 14, 2020 7:46 am
MartyMcNuts wrote: Wed Oct 14, 2020 4:34 am
So TrueHD 5.1 played only silence on the Sonos ARC. It recognised the signal but no sound. Perhaps the bitrate was set too high? I know with E-AC3 Sonos ARC has a limit of 960k. I tried the E-AC3 version and it worked no problems.
Post by MartyMcNuts » Wed Oct 14, 2020 10:48 am
Larrikin wrote: Wed Oct 14, 2020 7:46 am
Dunno.. Are you sure it supports TrueHD? The audio track I converted played fine on my pc using MPC-HC. Did your audio track work on your pc?
