Post
by RESET_9999 » Mon Oct 12, 2020 2:33 pm
hepe9 wrote: ↑Mon Oct 12, 2020 2:27 pm
I have a question, why in the first comparative, the fel to mel is more darkness, and now is the same?
no, it's the same and I did not compare fel to mel vs original mel on the first quote you are referring to
camera comparison between
mel original vs fel to mel: https://screenshotcomparison.com/comparison/6581
Capture card comparison Original
MEL vs FEL to mel conversion:
https://screenshotcomparison.com/comparison/7017
EDIT:
the comparison you're probably talking about is fel vs mel... I may have messed up that comparison though. It's much easier to do a mistake when i do camera comparison (exposure EG) than the capture card comparison method.
also keep in mind that the camera(lossy) comparisons are amplifying the difference while the capture card(lossless) show the exact difference.
hepe9
Post
by hepe9 » Mon Oct 12, 2020 3:28 pm
RESET_9999 wrote: ↑Mon Oct 12, 2020 2:33 pm
EDIT:
Yeah sorry, my quote is not good.
RESET_9999 wrote: ↑Wed Sep 23, 2020 11:29 pm
Dual-layer FEL untouched VS Dual-layer MEL converted
https://screenshotcomparison.com/comparison/6565
the untouched FEL is brighter & has more punch, no doubt. But I think this is normal because I'm seeing the same kind(if not more) of difference when I compare the Spears and Munsil FEL & MEL
So in your opinion, what comparison is more accurate?
Post
by RESET_9999 » Mon Oct 12, 2020 3:30 pm
hepe9 wrote: ↑Mon Oct 12, 2020 3:28 pm
again, the first comparison (ragico sample) is
FEL vs fel to mel (in other words: FEL vs MEL)
and the other one(spears) is
original MEL vs fel to mel. (in other words: MEL vs MEL)
you can't compare those.
RESET_9999 on Mon Oct 12, 2020 3:34 pm, edited 1 time in total.
hepe9
Post
by hepe9 » Mon Oct 12, 2020 3:33 pm
RESET_9999 wrote: ↑Mon Oct 12, 2020 3:30 pm
again, the first comparison (london has fallen) is
and the other one is
Ups sorry, I misunderstood
Post
by RESET_9999 » Mon Oct 12, 2020 3:36 pm
hepe9 wrote: ↑Mon Oct 12, 2020 3:33 pm
my bad too hehe.. my wordings ( my english in general) is limited.
rosavanwinkle
Post
by rosavanwinkle » Mon Oct 12, 2020 4:19 pm
Hello everyone,its being a long time since i was here (vacation in norway and other "19" related stuff)
but i just want to quickly ask,whats the latest way of converting we are trying out atm?
i'm atm using ffmpeg and yuescopes script(0.3 i think) and then tsmuxer with eac3
Mediaplayer: Nvidia Shield TV Pro
TV: LG 55SK7900PLA
Soundbar: LG SK8 (not LG SK8Y)
plex pass user
Discord:Rosa#1111
quietvoid
Post
by quietvoid » Mon Oct 12, 2020 5:54 pm
ray_007 wrote: ↑Mon Oct 12, 2020 1:12 am
Has anyone had any success on making DV work in 'Alita & Godzilla King of Monster' on Firestick4k? All I get is black screen with sound only. Is it because it's a HDR10+ and DV title? Tried Muxing in MP4 but getting HDR10+ and no DR :/
I've just made a Doctor Sleep rip (DV and HDR10+) and it's also only black screen on Firestick with Dolby Vision, even though it's MEL.
Might be something caused by HDR10+, because other MEL samples work fine.
If you convert it to 8.1, it also behaves the same on the Firestick.
However, it works in ts on my LG (doesn't support HDR10+ anyways) for both the internal player and Plex.
quietvoid on Mon Oct 12, 2020 6:10 pm, edited 1 time in total.
ray_007
Post
by ray_007 » Mon Oct 12, 2020 6:10 pm
quietvoid wrote: ↑Mon Oct 12, 2020 5:54 pm
Yup, I am pretty sure that there is some sort of conflict going on between HDR10+ and DV. Maybe someone here can shed some light on this? for now just wait and see.
ragico
Post
by ragico » Mon Oct 12, 2020 7:21 pm
ray_007 wrote: ↑Mon Oct 12, 2020 6:10 pm
I too believe that there is some form of conflict between DV and HDR10+ in the same film. We must hope that Yusesope finds the solution.
quietvoid
Post
by quietvoid » Mon Oct 12, 2020 11:21 pm
ragico wrote: ↑Mon Oct 12, 2020 7:21 pm
Should be trivial to just skip the HDR10+ NAL unit with yusesope's script, since the parsing is well done already
I'll send a patch to yusesope, hopefully it's good enough.
However this is destructive, it might be better to just switch a bit on/off. Will see.
Here's some test samples I've created if you guys want to test:
https://mega.nz/file/NEMUCBCD#95KVXGBmS ... wFyEKlsfNs
The one with HDR10+ removed should play fine on the firestick.
cuculain
Post
by cuculain » Tue Oct 13, 2020 2:09 am
neither of the test files played on the new Zidoo Z9x which is dv hdr 10+ capable.....supposedly
just thought id try em both in case
ray_007
Post
by ray_007 » Tue Oct 13, 2020 4:02 am
quietvoid wrote: ↑Mon Oct 12, 2020 11:21 pm
Tried both files and as you predicted, the one with HDR10+ removed played flawlessly on Firestick4k, while the other one gave black screen.
That is pretty amazing development tbh, but when you say this method is destructive does it mean that it destroys DV metadata or something? Lets hope that you and yusesope can work together to get this patch integrated into one of his tool soon
HEVCc
Post
by HEVCc » Tue Oct 13, 2020 9:09 am
ray_007 wrote: ↑Tue Oct 13, 2020 4:02 am
This is great, but honestly this and yusesope's work should be integrated into the player. This way the device can select DV: FEL, DV: MEL, HDR10+, or HDR10. This should all be done in memory on the fly and the source file should contain all the data. I hope to see this in Plex & Kodi one day.
ragico
Post
by ragico » Tue Oct 13, 2020 9:49 am
Tested and, as you predicted, the one with HDR10+ removed, play in Firestick and triggers DV.
quietvoid
Post
by quietvoid » Tue Oct 13, 2020 12:08 pm
It's destructive in the fact that it completely removes the HDR10+ data, and that's not reversible.
