Re: SDFtool Flasher
Post by MartyMcNuts » Tue Sep 29, 2020 1:30 am
duss909 wrote: Sun Sep 27, 2020 8:10 pm Thanks for creating this easy-to-use flashing tool, MartyMcNuts.
Sim sala bim - and my Asus BW-16D1HT has changed firmware.
You have - for what it's worth - forever my utmost gratitude.
You're welcome!!!! Enjoy!
rayians
Re: SDFtool Flasher
Post by rayians » Wed Sep 30, 2020 12:57 am
Correction on my previous post. I definitely have NET framework 4.8, based on the value in regedit. So I do have MakeMKV and proper NET framework and I am still get the "Unhandled exception has occurred in your application" error. As stated before, if I hit continue the flasher will open, but it will not recognize any optical drives. I have a drive already installed and am looking to flash a WH16NS40 with 1.05.
MartyMcNuts wrote: Tue Sep 29, 2020 1:29 am
rayians wrote: Mon Sep 28, 2020 4:31 pm Very strange situation with my PC. I checked the .NET framework version using the cmd prompt and it shows up as 4.0.0. I tried to install 4.7.2 and it would not allow me to because it says I have 4.7.2 or later already installed.
Not sure what to say here.....
You could try using the modified ASUS flasher, as long as your drive does not have an encrypted firmware on it.
Re: SDFtool Flasher
Post by MartyMcNuts » Wed Sep 30, 2020 2:14 am
rayians wrote: Wed Sep 30, 2020 12:57 am Correction on my previous post. I definitely have NET framework 4.8, based on the value in regedit. So I do have MakeMKV and proper NET framework and I am still get the "Unhandled exception has occurred in your application" error. As stated before, if I hit continue the flasher will open, but it will not recognize any optical drives. I have a drive already installed and am looking to flash a WH16NS40 with 1.05.
Do you have the latest version of MakeMKV installed? It's needed as it contains sdftool.exe, which is needed for this flasher to work properly.
williamw38
Re: SDFtool Flasher
Post by williamw38 » Fri Oct 02, 2020 11:54 am
HL-DT-ST-BD-RE_BU50N-1.00-NM00100-211711211006.bin, PLEASE someone send me this file, my drive does not ready any bluray i just need to flash firmware again but i cound not find it anywhere
aloha
Re: SDFtool Flasher
Post by aloha » Fri Oct 02, 2020 2:42 pm
Hello:
Check this post https://www.makemkv.com/forum/viewtopic ... 19&t=19113
then get the ZIP file (mk-firmware-pack-20200720.zip). Open the ZIP file and start tunneling down to BU50N. Violà!
Regards,
A
rayians
Re: SDFtool Flasher
Post by rayians » Sat Oct 03, 2020 12:37 am
You've done it one again Marty!! I can never thank you enough!!!
NormanC
Re: SDFtool Flasher
Post by NormanC » Tue Oct 06, 2020 4:16 pm
Hey
before I order a drive, I just want to make sure I understand correctly:
Can I use the SDFtool Flasher in Windows 10 64bit without changing ACHI to IDE in BIOS, or would I still needto load a 32bit windowsand swap to IDE in BIOS?
Regards
Re: SDFtool Flasher
Post by MartyMcNuts » Tue Oct 06, 2020 10:30 pm
NormanC wrote: Tue Oct 06, 2020 4:16 pm Hey
Regards
Yes you can. None of that 32 bit and bios changes crap is needed.
williamw38
Re: SDFtool Flasher
Post by williamw38 » Sat Oct 10, 2020 11:27 pm
did not work, i want original firmware not patched one , i need to burn bluray discs, i dont have any uhd disc
Re: SDFtool Flasher
Post by Billycar11 » Sat Oct 10, 2020 11:31 pm
williamw38 wrote: Sat Oct 10, 2020 11:27 pm did not work, i want original firmware not patched one , i need to burn bluray discs, i dont have any uhd disc
If you want original firmware just don't flash an MK firmware flash a DE but it should have no effect on the burning ability either way
williamw38
Re: SDFtool Flasher
Post by williamw38 » Mon Oct 12, 2020 7:39 am
Where could i find DE firmware?, the zip file i downloads only hás mk firmware
Re: SDFtool Flasher
Post by MartyMcNuts » Mon Oct 12, 2020 9:57 am
williamw38 wrote: Mon Oct 12, 2020 7:39 am Where could i find DE firmware?, the zip file i downloads only hás mk firmware
Here you go. Freshly extracted from the BU50N installer...
DE_LG_BU50N_1.00.bin.zip
(1.25 MiB) Downloaded 3308 times
williamw38
Re: SDFtool Flasher
Post by williamw38 » Tue Oct 13, 2020 10:22 am
thanks
williamw38
Re: SDFtool Flasher
Post by williamw38 » Tue Oct 13, 2020 11:39 am
MartyMcNuts wrote: Mon Oct 12, 2020 9:57 am
this is not the firmware that cames with my drive, my drive cames with bw50 one, so do you have bw50 one?
williamw38
Re: SDFtool Flasher
Post by williamw38 » Tue Oct 13, 2020 11:51 am
mine came with this one but i cant find it anywhere
Manufacturer: hp HLDS
Product: BDRE BU50N
Revision: BW50
Serial number: KZEH9KA5649
Firmware date: 2116-12-22 10:52
Bus encryption flags: 1F
Highest AACS version: 23
Firmware version: 0.BW50P
