ragico
#3316 Post by ragico » Sun Oct 11, 2020 7:31 pm
SamuriHL wrote:
Sun Oct 11, 2020 6:45 pm
I've not played on the firestick yet but that requires FEL->MEL conversion. Once that process gets nailed down by you adventurous people, maybe Mike can add an option to do so in MakeMKV to make it seamless. :D I should try a couple of my MEL movies with plex on the firestick and see how that goes. That'd be nice.
I compared the firestick vs shield on Panasonic GZ2000 oled and could not see any red push or colour saturation.
Firestick at moment is better than shield IMHO.
#3317 Post by RESET_9999 » Sun Oct 11, 2020 7:34 pm
SamuriHL wrote:
Sun Oct 11, 2020 7:15 pm
shawnc22 wrote:
Sun Oct 11, 2020 7:01 pm
It's really too bad that the firestick can't handle lossless audio. That's more of a deal breaker for me than the seemingly better DV implementation.
Wait it can't do lossless audio?? Yea, ok, that's a deal breaker for me as well. Damn. (You can tell how much I've used my firestick LOL)
also no 24/23hz support on plex i think ?
so it's either:
1- shield dv issues + lossless audio + plex library
2- Firestick proper dv + no lossless audio + plex library
3- x700 / oppo proper dv + lossless audio + no plex library
one day, hopefully, we can get a device that can do it all.. i bet it will end up being an HTPC
ragico
#3318 Post by ragico » Sun Oct 11, 2020 7:51 pm
Firestick supports 24/23hz on plex.
quietvoid
#3319 Post by quietvoid » Sun Oct 11, 2020 7:57 pm
Currently you have to disable the firestick's own refresh rate matching and enable Plex's to get DoVi from Plex. Otherwise it's not consistent.
Haven't verified but it seems to switch the display just fine.
ragico
#3320 Post by ragico » Sun Oct 11, 2020 8:00 pm
I have not disabled firestick own refresh rate, It is enabled. Never a problem.
chros
#3321 Post by chros » Sun Oct 11, 2020 8:17 pm
A note about the phrase "LLDV", since you use it recently:
- this is a mode of the display device and not the player, nor the file!
- although the player triggers it based on its setting (e.g. Oppo)
- it has nothing to do with the content itself (can be MEL/FEL DV)
In LLDV mode of a display device it disables its certain image processings (that are enabled otherwise) to reduce latency between itself and the "player" device. This can result in banding/posterization, especially with low bitrate DV content, such as streaming profile 5 MEL DV.
Hence it's not desirable at all to use LLDV mode when watching DV video content.
For example, Sony Oleds don't have full DV support, only LLDV. Even Vincent recently stated the above issues in his late Sony reviews.
Other Oleds that have full DV implementation (LG, Panasonic, Philips) can be set into LLDV mode, e.g. by enabling player-led DV processing on Oppo.
#3322 Post by SamuriHL » Sun Oct 11, 2020 8:44 pm
So I'd still lose lossless audio formats which is also a deal breaker for me. I didn't build an ATMOS audio system for no reason. UGH. Yea, I agree, we may eventually get to a full solution but we appear to be falling just short. Fortunately I still have my UB820 for now.
#3323 Post by shawnc22 » Sun Oct 11, 2020 10:03 pm
Only thing I'd like to add is that the player has to also support the full implementation of DV for non-LLDV. Some players, such as the xbox one x, is only capable of outputting LLDV regardless of the display's capabilities.
#3324 Post by Manixx2020beyound » Sun Oct 11, 2020 10:08 pm
LLDV is Player processed algorithm vs uhd tv doing the work rgb8bit/12bit dv algorithm.
Example xbox1 canot do regular dv even if your uhd tv can.
Both result in identical visual output LLDV & dv.
Last edited by Manixx2020beyound on Sun Oct 11, 2020 10:29 pm, edited 1 time in total.
#3325 Post by SamuriHL » Sun Oct 11, 2020 10:14 pm
Additionally the HD Fury can force LLDV.
#3326 Post by Manixx2020beyound » Sun Oct 11, 2020 10:52 pm
Also most of the red push that has bin stated over & over are mostly from folks playing back regular uhd doblyvision rgb8bit on the shield so it’s not a LLDV related red push on the shield.
Vudu,Disney,MA profile 5 all have no red push issuses so it is shield specific for the uhd profile.
#3327 Post by Manixx2020beyound » Sun Oct 11, 2020 11:09 pm
Tonight I’ll test maldorian profile 5 real dv in x700 vs Disney maldorian dv shield tv Disney.
All in doblyvision.
ray_007
#3328 Post by ray_007 » Mon Oct 12, 2020 1:12 am
Has anyone had any success on making DV work in 'Alita & Godzilla King of Monster' on Firestick4k? All I get is black screen with sound only. Is it because it's a HDR10+ and DV title? Tried Muxing in MP4 but getting HDR10+ and no DR :/
whiplash1
#3329 Post by whiplash1 » Mon Oct 12, 2020 7:02 am
I've tested Godzilla KOTM on my android TV (exact same DV implementation as Firestick), it plays fine. I don't have Alita, sorry.
#3330 Post by RESET_9999 » Mon Oct 12, 2020 2:25 pm
DV p5 Streaming contents comparisons between the x700 and the Shield.
Mandalorian:
x700 web-dl VS Shield disney+ stream: https://screenshotcomparison.com/compar ... /picture:1
ALITA:
x700 vudu VS Shield vudu: https://screenshotcomparison.com/compar ... /picture:1
