PapitaHD
Post by PapitaHD » Thu Oct 08, 2020 5:55 pm
I reuploaded the MI Fallout samples to Mega: https://mega.nz/folder/zIUHyYgI#IdP6COvbAQ8vNVA0MSH6Jg
ragico
Post by ragico » Thu Oct 08, 2020 7:32 pm
3 films: The Shining, Doctor sleep and Jaws.
They are DV Mel and also HDR10+ compatible.
None of them plays in Firestick 4k.
Audio only with black screen.
Anyone can explain why?
ray_007
Post by ray_007 » Fri Oct 09, 2020 10:53 am
So i converted a Fel movie to Mel using yusesope's tool and instruction but when i try to use that file in MakeMkv, the progress gets stuck halfway through. I have tried few different FEL titles with exactly the same result. I am using latest nightly tsmuxer, along with latest Fel to Mel tool by youscope.
The interesting thing is that i didnt encounter the same problem when feeding a DV ISO to MakeMkv so there must be something happening between tsmuxwer and yusesope tool which i cannot root out.
Is anyone having similar issue lately or maybe it is a bug?
Post by RESET_9999 » Fri Oct 09, 2020 11:18 am
ragico wrote: Thu Oct 08, 2020 7:32 pm 3 films: The Shining, Doctor sleep and Jaws.
same, we wanted to test the doctor sleep sample on the firestick but no go :(
whiplash1
Post by whiplash1 » Fri Oct 09, 2020 11:23 am
My android TV has the exact same DV implementation as Firestick 4k. I've tested The Shining which I ripped using 1.15.2 and it works flawlessly. Haven't tested the other 2 titles.
Tomas
Post by Tomas » Fri Oct 09, 2020 3:37 pm
Please owner Zidoo z9x. How satisfied are you? I find out that perhaps no DV can be played there :). It either cuts or stops completely. I think maybe I'll go back to Shield. What do you think is better Shield or Zdioo z9x?
ghostshadow
Post by ghostshadow » Fri Oct 09, 2020 4:24 pm
Tomas wrote: Fri Oct 09, 2020 3:37 pm Please owner Zidoo z9x. How satisfied are you? I find out that perhaps no DV can be played there :). It either cuts or stops completely. I think maybe I'll go back to Shield. What do you think is better Shield or Zdioo z9x?
Hello, I received my zidoo z9x yesterday.
I did some tests and no DV file passed. Even the dvtest demo files from here. I have a black screen.
For others they open only in HDR10.
The firmware is in beta, but for dolby video it is more alpha. In addition there are bugs with some televisions (LG, Panasonic)
And it comes from the zidoo because my internal player reads these dv files well.
The Shield is better, especially they are very reactive, before zidoo released products quite well finished, now they release products not usable and have served as beta tester.
Tomas
Post by Tomas » Fri Oct 09, 2020 5:12 pm
ghostshadow wrote: Fri Oct 09, 2020 4:24 pm
Just that I've never had a problem with Shield. Zidoo will only play DV to me when the movie is mkv MEL.
cuculain
Post by cuculain » Sat Oct 10, 2020 5:29 am
the mel 7 atmos audio ones seem to start desynching audio and stuttering after 4 -5 mins from ones ive tested so far
a MEL 7 hd ma 7.1 ......Casino royale ripped with makemkv .53 brought up DV on my panasonic z1000 OLED and had zero stutter or audio syncs at well past the 10 min mark and even sliding forward seemed no issues
actually off to watch full movie now,just to confirm it..........ill edit here if it does play full lenght DV ok or not
Looking like Zidoo is close to getting mel 7 working
Had a quick play with trying to use the older ffmpeg to make a MEL 7 atmos over to a MEL 5 one since 5 8 9 are supposedly supported by zidoo ans wasnt having any luck with the 8.1 bat file method last night
Casino royale MEL 7 makemkv .153 ...looked aewsome on the panasonic z1000 oled
Triggered dolby vision on tv ....played with only a very few stutters maybe one or two every 10 15 mins...onlu other issue was maybe 4 times during the movie there would be a 1/2 sec pause and dolby vision info would re trigger up on tv
so very close to perfect
Tomas
Post by Tomas » Sat Oct 10, 2020 6:52 am
Hi, experts. You are my only salvation. Please I have Synology, but I updated to DSM 7 and unfortunately I can't PLEX (yes my mistake). There is a chance that I should play DV mkv via KODI. How to connect KODi with SYNOLOGY. I'm running through SHIELD. Thank you so much for your help or advice.
ghostshadow
Post by ghostshadow » Sat Oct 10, 2020 1:33 pm
MEA CULPA
Hello, quick feedback on my Black Screen problem with DV files (any format).
In fact I solved the problem by changing the HDMI cables (which however were not at the bottom of the game).
I put the cable provided in the Z9x.
My concern also comes from my full HDFury, which I do not control. I use it for sound and video splitter because I am using Sony MDR-HW700 headphones.
Once changed the HDMI cables by putting me on the HDFury in: 'scale' -> passthrough, 'edid' -> automix,, 'hdcp' -> 2.2:
- DV videos work:
* mkv test P7 MEL -> ok
* mkv test P5 -> ok
* MP4 encodes x265 P8 (dvhe.08.06, BL + RPU) -> ok
* MKV P7 makemkv 1.15.3 (dvhe.07.06, BL + EL + RPU) -> ok
But I don't have HD sound on the headphones
By putting the HDFury in: 'scale' -> auto-scale, 'edid' -> automix,, 'hdcp' -> 2.2:
* mkv test P5 -> ok
* MKV P7 makemkv 1.15.3 (dvhe.07.06, BL + EL + RPU) -> Not ok, GREEN screen
*MKV P8 yusesope + makemkv 1.15.3 process UHD-BD TO PROFILE 8.1 -- > ok
I have sound regardless of the audio format
If anyone has any idea to fix the green screen or tell me how to set up my HDFury integral 2.
Thank you
staknhalo
Post by staknhalo » Sun Oct 11, 2020 12:08 am
'dv-bl-compatible-id' would be the base HDR10 HEVC stream, correct? Or is it asking to be pointed to the DV metadata stream? Or is this just a 'yes/no' flag instead?
quietvoid
Post by quietvoid » Sun Oct 11, 2020 3:13 am
yusesope wrote: Thu Oct 08, 2020 2:53 pm I apologize to those who have asked me questions but these days I have very little time. Sorry!
When the "Plex fever" is gone, we'll start testing again :mrgreen: .
I have some pretty good ideas that I hope to be able to put into practice :lol:
Just wanted to give some feedback on the new mode 2 (profile 8.1). It works very well.
From a FEL MKV, converting to 8.1 and back to MKV works with Plex on the Firestick 4K.
The converted 8.1 file can also be used in TS on LG webOS Plex and internal player, both trigger Dolby Vision.
So from the MKVs created by MakeMKV, there is a lot of compatibility fixes possible. :)
dapope
Post by dapope » Sun Oct 11, 2020 4:46 am
EDIT: Info in this post was incorrect. The process I outlined below resulted in crushed blacks. I've reread info in the thread and am now using yusesope's 8.1.bat. I'm also now both demuxing and remuxing using tsmuxer. The only reason I was using mp4muxer was because I did not know LG OLED's could play .ts files. And demuxing with FFMPEG results in video audio desync by some finagling with the PTS (presentation time stamp) value, which is the first I've heard of that term and goes way above my head.
My current procces is: Demux using tsmuxer. Create single layer hevc using 8.1 bat. Convert audio, in this case I converted a stereo lpcm to aac using FFMPEG. Remux to .ts using tsmuxer. If Tsmuxer detected a programmed delay in the audio in the original file you have to manually enter it again here, as the audio file seems to lose the info when you demux. In this case it was 3000ms which is very noticeable. But now I have at least one movie (Escape from New York) playing perfectly. Hope this helps anyone else with a CX or similar.
I am happy to report on my experience with the inbuilt player of LG OLED CX through a HDD. I have seen discussion of other LG OLEDs but not the 2020 model. This site's awful search function does not help.
In short it would appear that the 2020 models do not support profile 7. I saw someone mention this on a thread at AVS. But using profile 5 I am able to trigger Dolby Vision Using the instructions and files from yusesope on page 199 of this thread (thanks Yusesope!). I combine the base and enhancement HEVC layers using his Mux.bat from his tool 0.0.4 alfa. Then I use his command line for his mp4muxer, except changing the DV vision profile to 5. His 8.1 test also works but as I understand it profile 5 is superior.
Keep in my mind I do not have the tools to independently verify the Dolby Vision is working as intended. So there is that. But it looks good to my eyes.
Right now my bigger problem is with converting audio to an AC3 which will play nice with the LG CX player. I am struggling with a DTS-HD MA file, perhaps because is uses Atmos? I'm unclear if the Atmos needs to be eliminated and if there is a special process for doing so. The file with no audio track plays video and triggers DV fine, however if it's muxed with audio the file may or not trigger DV, stutter and probably crash.
looun
Post by looun » Sun Oct 11, 2020 11:40 am
ghostshadow wrote: Sat Oct 10, 2020 1:33 pm
MEA CULPA
- DV videos work:
* mkv test P5 -> ok
* mkv test P5 -> ok
Thank you
interesting but HDMI OUT it's right 422/444 12/10 bit.. or are still 422 24 bit ?
https://ae01.alicdn.com/kf/Uedfc4cb8cc7 ... 2bb16u.jpg
https://ae01.alicdn.com/kf/U5921afdad66 ... 2a13a3.jpg
http://www.hd199.com/thread-1908588-1-1.html
