Does Libredrive enable reading and ripping of region codes A, B and C for normal Blurays?
Or this fuctionality part of MakeMKV anyway and nothing to do with Libredrive?
I have never tried ripping anything outside of my region (B) so am curious to know before importing some region A discs.
TIA.
Region Coding
Re: Region Coding
Usually works with or without Libredrive but there are some rare cases that it does not mostly for DVDs I believe
Mr_Orange
Re: Region Coding
Thank you. I'll only be importing Blurays. I'm not buying DVDs these days.Billycar11 wrote: Sat Oct 10, 2020 12:54 pm Usually works with or without Libredrive but there are some rare cases that it does not mostly for DVDs I believe
