Dolby Vision and Mediainfo HDR Format
douchey
Post by douchey » Fri Oct 09, 2020 9:46 pm
I've made a MKV using MakeMKV 1.15.3 using a source that has Dolby Vision. However, opening it in the latest MediaInfo 20.08 I don't see any reference to Dolby Vision in the video track HDR Format description. As far as I know, MediaInfo should support reading Dolby Vision data?
Muxing the Bluray m2ts to a TS file manually and reading it with MediaInfo, there is a clear reference to the Dolby Vision track.
Should MediaInfo be displaying the Dolby Vision info in MakeMKV mkv files? If not, how can I verify my MakeMKV created files contain DV without trying to play it on a Dolby Vision capable display?
Digital moe
Re: Dolby Vision and Mediainfo HDR Format
Post by Digital moe » Sat Oct 10, 2020 1:00 am
I downloaded the latest version today and it is showing me the DV info for mkv files, I had to switch to Tree view to see this data.
Post by shawnc22 » Sat Oct 10, 2020 1:02 am
Did you really need to make a new thread with all the other dolby vision threads around? You're on the wrong version of mediainfo, you need 20.09.
douchey
Post by douchey » Sat Oct 10, 2020 1:15 am
Can confirm, the new version of MediaInfo 20.09 (just released today Oct 9th) displays the DV info. When I checked last night with the previous version it didn't work.
MediaInfo change log:
Version 20.09, 2020-10-09
+ Dolby ED2: full featured support (presentations, presentation targets, beds, objects)
+ MKV: support of Dolby Vision metadata
+ MXF: detection of Dolby E hidden in PCM tracks having more than 2 channels
+ WAV: detection of Dolby E hidden in PCM tracks having more than 2 channels
+ CineForm: display of color space (including Bayer), bit depth
x WAV: more precise sample count
x SMPTE ST 337: catch of streams starting later than usual (probing increased from 4 to 16 PCM "frames")
x PNG: detection of additional alpha plane in color space
x MXF: detection of additional alpha plane in color space
x AVI: detection of additional alpha plane in color space
x MPEG Audio: was wrongly flagging Xing info tag as CBR
x VorbisTag: does not skip DISCID
x Miscellaneous bug/crash fixes
