maybe this is where i'm going wrong, iso won't open from MakeMKV:shawnc22 wrote: Thu Oct 08, 2020 4:33 pmwhen you open your mounted iso (not mkv) in makemkv, does it not detect DV at all?phneutral wrote: Thu Oct 08, 2020 4:14 pmI actually tried your method 1 - that's why I mentioned the iso - it doesn't work. I will try Yusecope's tool. Even if those workarounds do work, it seems rather at odds with the OP, no?
MakeMKV v1.15.3 win(x64-release) started
The program can't find any usable optical drives.
AACS directory not present, assuming unencrypted disc
Title #00000.m2ts was skipped
Failed to open discWhen I mount ISO to drive F, the option to open disc in MakeMKV is greyed out
