Dolby Vision and 1.15.1
Cannikin
Re: Dolby Vision and 1.15.1
#1426 Post by Cannikin » Thu Oct 08, 2020 4:26 pm
Identifying Dolby Vision in MKV files is coming to MediaInfo by tomorrow! https://github.com/MediaArea/MediaInfo/ ... -705658836
Mr_Orange
#1427 Post by Mr_Orange » Thu Oct 08, 2020 9:16 pm
Mr_Orange wrote: Thu Oct 08, 2020 12:17 pm
jakuboleksy wrote: Tue Oct 06, 2020 3:49 pm https://forums.plex.tv/t/release-announ ... 154124/362
WHATS NEW:
Bump the minimum supported Plex Media Server version to 1.15.2.
Player: support for Dolby Vision in MKV.
Player: Live TV is no longer supported in the old player.
I have a 2015 LG so I am restricted to 30Hz for DV but it seems to be working(ish). Some films are more reliable than others it seems. For instance, Universal Soldier works every time but Gladiator and Top Gun either default to HDR10 or don't display any video despite the soundtrack runing.
Further testing gave me and unknown HDR mode with a red tint - this happened for both Top Gun and Gladiator but not Universal Soldier.
Cannikin
#1428 Post by Cannikin » Thu Oct 08, 2020 9:20 pm
Mr_Orange wrote: Thu Oct 08, 2020 9:16 pm Further testing gave me and unknown HDR mode with a red tint - this happened for both Top Gun and Gladiator but not Universal Soldier.
Were you streaming from a Shield? That's also a known problem, but with the Shield itself, unrelated to Plex. They're working on that and there's a hotfix available now (not an official release yet): https://www.nvidia.com/en-us/geforce/fo ... fix-image/
You can get access to the hotfix versions by giving Nvidia the serial number on your Shield and then they'll show as available when you do a system update: https://docs.google.com/forms/d/e/1FAIp ... ONTDELETE-
Mr_Orange
#1429 Post by Mr_Orange » Thu Oct 08, 2020 9:29 pm
Cannikin wrote: Thu Oct 08, 2020 9:20 pm
Yes, it was with a Shield. Thank you for the information on the Hotfix.
cipher
#1430 Post by cipher » Thu Oct 08, 2020 10:22 pm
Cannikin wrote: Thu Oct 08, 2020 4:26 pm Identifying Dolby Vision in MKV files is coming to MediaInfo by tomorrow! https://github.com/MediaArea/MediaInfo/ ... -705658836
Very nice, another software update to cross off the list! Once Plex gets DV working consistently without the few issues being reported, and it's rolled into the non-Beta branch, I'll be very happy. Originally, I was hoping all the software apps would be ready with DV by Xmas so it looks like we'll be ahead of my own prediction.
gabi.gegea@gmail.com
#1431 Post by gabi.gegea@gmail.com » Fri Oct 09, 2020 12:14 am
New version available:
Plex for Android 8.8.0.21038-beta
Working better than the previous one.
Cannikin
#1432 Post by Cannikin » Fri Oct 09, 2020 12:18 am
gabi.gegea@gmail.com wrote: Fri Oct 09, 2020 12:14 am New version available:
Sweet, get it here: https://forums.plex.tv/t/release-announ ... 154124/363
Larrikin
#1433 Post by Larrikin » Fri Oct 09, 2020 9:59 am
Confirmed I have been able to get Dolby Vision to work with:
1.15.3 MakeMKV
LG CX 77"
Plex Beta 8.8.0.21038
I have to stop and start the movie several times at the beginning as the defaults to HDR but then eventually gets Dolby Vision. I don't think that's a MakeMKV issue, I think its a plex issue. Well done to makemkv for supporting Dolby Vision!
Tomas
#1434 Post by Tomas » Fri Oct 09, 2020 9:17 pm
Hi, experts. You are my only salvation. Please I have Synology, but I updated to DSM 7 and unfortunately I can't PLEX (yes my mistake). There is a chance that I should play DV mkv via KODI. How to connect KODi with SYNOLOGY. I'm running through SHIELD. Thank you so much for your help or advice
#1435 Post by gabi.gegea@gmail.com » Fri Oct 09, 2020 10:16 pm
To trigger Dolby Vision it must be single video channel or will work with dual video channels?
(the new Plex beta)
ApexAftermath
#1436 Post by ApexAftermath » Sat Oct 10, 2020 5:11 am
There must be something about my UHD DV rips that isn't right because I am able to get the test files to play fine and TV shows dolby vision, but playing anything in Kodi with the exoplayer default set, or playing in the new plex beta does not trigger dolby vision. Playing on a shield pro 2019. Any suggestions?
Sparky101
#1437 Post by Sparky101 » Sat Oct 10, 2020 12:17 pm
Tomas wrote: Fri Oct 09, 2020 9:17 pm Hi, experts. You are my only salvation. Please I have Synology, but I updated to DSM 7 and unfortunately I can't PLEX (yes my mistake). There is a chance that I should play DV mkv via KODI. How to connect KODi with SYNOLOGY. I'm running through SHIELD. Thank you so much for your help or advice
Can you not mount the Synology as a network share in the Shield and then run Plex server on the Shield itself?
ApexAftermath
#1438 Post by ApexAftermath » Sat Oct 10, 2020 5:28 pm
gabi.gegea@gmail.com wrote: Fri Oct 09, 2020 10:16 pm To trigger Dolby Vision it must be single video channel or will work with dual video channels?
(the new Plex beta)
I would like to know the answer to this as well. Mine are dual video channels and not working in kodi or the new Plex beta.
Tomas
#1439 Post by Tomas » Sat Oct 10, 2020 5:50 pm
Sparky101 wrote: Sat Oct 10, 2020 12:17 pm
I didn't try that
#1440 Post by shawnc22 » Sat Oct 10, 2020 6:00 pm
ApexAftermath wrote: Sat Oct 10, 2020 5:28 pm
(the new Plex beta)
If by dual channel you guys are talking about the BL and EL being on separate tracks, then no it will not work. Not on the Shield at least
