#3256 Post by RESET_9999 » Wed Oct 07, 2020 11:32 pm
DaMacFunkin wrote: Mon Oct 05, 2020 6:41 am
Hi, I know it isn’t entirely possible to be technically correct with external screen shots but I would say the x700 is cooler, is that what you are seeing?
yep, there is the red blocs artifacts issue and the colors are sligthly off compared to the x700.
https://screenshotcomparison.com/comparison/6903
I think all the files produced by @yusesope tool are correct. the problem is the Shield.
#3257 Post by SamuriHL » Thu Oct 08, 2020 1:09 am
RESET_9999 wrote: Wed Oct 07, 2020 11:32 pm
Exactly!
ray_007
#3258 Post by ray_007 » Thu Oct 08, 2020 2:31 am
Guys, since MP4 files dont play nice with Subs, is it possible to add downloaded subtitles on modified version of Kodi Exoplayer on Firestick4k? Please reply thanks
#3259 Post by RESET_9999 » Thu Oct 08, 2020 2:57 am
Here are 5 more comparisons between the Shield and the Sony x700. The file tested is a profile 04.06 single track BL+EL+RPU.
But this time, instead of using my camera, a friend of mine(thank's manix) provided me two samples tone mapped to SDR from Dolby Vision made using a capture card (pro-res HQ) and the vertex 2 which allow the DV tone mapping.
This method shows the difference more accurately than camera pictures because exactly the same tone mapping is applied to both players and no clipping nor off looking colors usually introduced by the camera. it allows me to compare a lot more frames quickly too.
here are the 5 comparisons...
downscaled to 1080p:
https://screenshotcomparison.com/compar ... /picture:0
full resolution:
https://screenshotcomparison.com/comparison/6905
I also asked him for the same comparison but with a FEL movie and also a sample from the firestick TV
Video
Format                                   : ProRes
Codec ID                                 : V_PRORES
Duration                                 : 3 min 0 s
Bit rate                                 : 645 Mb/s
Bits/(Pixel*Frame)                       : 3.243
Stream size                              : 13.5 GiB (99%)
lexyz
#3260 Post by lexyz » Thu Oct 08, 2020 5:14 am
RESET_9999 wrote: Thu Oct 08, 2020 2:57 am Here are 5 more comparisons between the Shield and the Sony x700. The file tested is a profile 8 single track BL+EL+RPU.
Nice. :D Can you make Mission Impossible shots with same method? :roll:
I've linked samples recently.
DaMacFunkin
#3261 Post by DaMacFunkin » Thu Oct 08, 2020 6:40 am
SamuriHL wrote: Thu Oct 08, 2020 1:09 am
Exactly!
I wouldn’t jump too quickly, I have Zidoo Z9X as well as Shield and in my limited testing on the Zidoo the colours look more over saturated than on my Oppo Clone - which is amazingly natural.
I haven’t tried any 8.1 files yet though.
DaMacFunkin
#3262 Post by DaMacFunkin » Thu Oct 08, 2020 6:46 am
Hi, just a quick Q, if I have a profile 7 mkv made with 1.53, can it then be coverted to 8.1 or do need to re-rip the disk, running out of space with all these ripped files on my laptop. Thank you.
#3263 Post by shawnc22 » Thu Oct 08, 2020 7:20 am
full resolution:
Video
Format                                   : ProRes
Codec ID                                 : V_PRORES
Bit rate                                 : 645 Mb/s
Nice work as always on the comparisons! But just curious on why profile 8 videos were used? especially ones with an EL that it's not supposed to have
DaMacFunkin wrote: Thu Oct 08, 2020 6:46 am Hi, just a quick Q, if I have a profile 7 mkv made with 1.53, can it then be coverted to 8.1 or do need to re-rip the disk, running out of space with all these ripped files on my laptop. Thank you.
No other tool currently exists other than makemkv that will create DV mkvs. Mkvtoolsnix will preserve the DV metadata, but cannot create or do any conversions, so I don't think you'll be able to do any profile/video conversions after the fact if makemkv is unable to do so in the first place.
Tomas
#3264 Post by Tomas » Thu Oct 08, 2020 8:38 am
DaMacFunkin wrote: Thu Oct 08, 2020 6:40 am
Exactly!
Please and you drove some DV mkv transferred to FID with FEL to MEL. I have Zidoo and I'm not doing well yet. Everything is fine on the shield.
#3265 Post by RESET_9999 » Thu Oct 08, 2020 11:04 am
shawnc22 wrote: Thu Oct 08, 2020 7:20 am
ha my bad, I meant to say profile 04.06. we still use the old tsmuxer.
#3266 Post by RESET_9999 » Thu Oct 08, 2020 2:11 pm
Koceens wrote: Sun Oct 04, 2020 12:22 pm Hello,
Can you please share steps you made to create this file? And what software versions you used (TS muxer)?
I have tried many times to create a working .ts file from my UHD Bluray, but it does not play on my Hisense U8QF via USB. Says file is not supported.
Your file works and triggers DV.
From all the methods described in this long conversation only yusesope's method is working for me and then muxing it with mp4muxer. Plays on my TV with all DV profiles. The problem is that with this method I don't know how to encode subtitles from .srt file. My TV doesn't read external subtitles from a separate file in mp4 container for some reason. I would really appreciate if someone could help with suggestion on this matter.
Thank you in advance!
sorry for the late response, this TS file is an original untouched demo. Remuxing that file with any version of tsmuxer will probably make it unsupported by your device.
#3267 Post by RESET_9999 » Thu Oct 08, 2020 2:19 pm
lexyz wrote: Thu Oct 08, 2020 5:14 am
here we go: https://screenshotcomparison.com/comparison/6913
he's getting a black screen on the Firestick TV, sorry because it has probably been answered a million times but can someone tell me what file does work on the firestick?
quietvoid
#3268 Post by quietvoid » Thu Oct 08, 2020 2:38 pm
RESET_9999 wrote: Thu Oct 08, 2020 2:19 pmhe's getting a black screen on the Firestick TV, sorry because it has probably been answered a million times but can someone tell me what file does work on the firestick?
FEL files don't work (black screen), though I've had it work once after profile 7 to 8.1 conversion.
All other samples (other than profile 4) have worked for me.
yusesope
#3269 Post by yusesope » Thu Oct 08, 2020 2:53 pm
RESET_9999 wrote: Thu Oct 08, 2020 2:19 pm he's getting a black screen on the Firestick TV...
The FireStick should read my FELs -> MELs (and of course the original MELs)
@PapitaHD posted a lot of samples. The FireStick should play the "MEL STDL mkv" sample (+ my ExoP and maybe the new Plex...IDK) without any problems.
PapitaHD wrote: Sun Oct 04, 2020 7:04 pm I've created a lot of samples of the so-called bathroom fight scene from MI Fallout (which is considered to be one of the best scenes for DV testing), in basically all formats for testing purposes:
FEL DTDL ISO: https://we.tl/t-ULqcqHX5UF
MEL DTDL ISO: https://we.tl/t-QCnGWO6BLg
FEL STDL TS: https://we.tl/t-ZjRQW5MvXp
MEL STDL TS: https://we.tl/t-t9Wyhoj13S
FEL STDL mkv: https://we.tl/t-m37JLz8GtM
MEL STDL mkv: https://we.tl/t-T9birvQfHC
Profile 8.1 STSL TS: https://we.tl/t-YjwVzKmar3
FEL x265 DTDL ISO: https://we.tl/t-GRs0U07umW
FEL x265 STDL mkv: https://we.tl/t-bfUqVCblJ8
FEL x265 STDL TS: https://we.tl/t-bE54zCPw2G
Would be great if others could test and compare them. I know re-encoded BL is not supposed to work, but it seems fine to me, maybe someone can point out what's wrong with it.
I hope @PapitaHD will re-upload all these samples to another cloud (pCloud, Mega, etc) as wetransfer only keeps the files for a week!
Thanks for your work @PapitaHD (when I have time I will try to explain to you why the encoded files are not good) and thanks also to @RESET_9999 (and his friend)!
I apologize to those who have asked me questions but these days I have very little time. Sorry!
When the "Plex fever" is gone, we'll start testing again :mrgreen: .
I have some pretty good ideas that I hope to be able to put into practice :lol:
lexyz
#3270 Post by lexyz » Thu Oct 08, 2020 3:46 pm
RESET_9999 wrote: Thu Oct 08, 2020 2:19 pm here we go: https://screenshotcomparison.com/comparison/6913
Thank you :D
It's clearly seen red's distrubution across frame is wrong - less overall but boosted in some areas
I could make a guess - some function applied during DV color transformation return wrong result.
It could be an error during data interpretation by ShieldTV DV decoder or unability to correctly use such data.
Meta for UHD disk and online streaming platforms could be different because it should contain data how to apply EL.
