ray_007
#46
Post
by ray_007 » Tue Oct 06, 2020 6:03 pm
shawnc22 wrote: Tue Oct 06, 2020 5:39 pm
ray_007 wrote: Tue Oct 06, 2020 5:28 pm
ray_007 wrote: Tue Oct 06, 2020 3:58 pm
Hi, Does that also mean I can just throw in a .m2ts DV file into Makemv and it will then produce a DV capable MKV? If so then would I be able to put the resulting file in mkvtoolnix to add/remove Subs and Audio stream while retaining the DV info?
Never mind, tried and didnt work. Going to try it with my current MP4 DV's. Will the conversion effect the quality of the video? Also I am not very good with command lines, so can anyone explain what exactly do i have to type to convert my current MP4 to MKV using ffmpeg?
You can use the m2ts DV file, but you will need to do a straight container conversion to mkv before opening it with makemkv. The ffmpeg command to do so is in the first post of this thread. After creating the new mkv file with 1.15.3, you can process it with mkvtoolsnix; the latest version should retain all the DV metadata.
Okay, so here is what I understood so far:
Use ffmpeg to convert m2ts file.
put the resulting mkv file into makemkv to get the DV MKV
finally use Mkvtoolnix to multiplex sub/audio
Question, Can i just use Mkvtoonix to convert the m2ts file and process it with makemv to get the DV mkv?
Also will there be a quality loss during the process?
#47
Post
by shawnc22 » Tue Oct 06, 2020 6:38 pm
ray_007 wrote: Tue Oct 06, 2020 6:03 pm
Yes, you should be able to use mkvtoolnix to do the conversion. I haven't tried it myself, but I don't see why not. If your m2ts file also included the pgs subtitles, you can carry it over during the mkvtoolsnix conversion, and then makemkv should pick it up as well during the final DV MKV remux. There will be no quality loss in any of these steps.
lexyz
#49
Post
by lexyz » Tue Oct 06, 2020 8:24 pm
Plex for Android 8.8.0.20999-beta and samples
https://www.makemkv.com/download/dvtest/
Shield TV Pro:
P4 - SDR
P5 - SDR, wrong colours
P7_FEL - DV
P7_MEL - DV
P81 - HDR
Bravia:
P4 - SDR
P7_FEL - DV monochrome
P7_MEL - DV oversaturated
P81 - HDR
quietvoid
#50
Post
by quietvoid » Tue Oct 06, 2020 9:07 pm
lexyz wrote: Tue Oct 06, 2020 8:24 pm
Shield TV Pro:
P4 - SDR
P7_FEL - DV
P7_MEL - DV
P81 - HDR
Bravia:
P4 - SDR
P81 - HDR
You should mention your results on the Plex forums thread, I've done it for the FireTV Stick 4K and they're probably looking into it already.
Seems only profile 7 (because it has a HDR10 base layer) are playing correctly.
Digital moe
#51
Post
by Digital moe » Tue Oct 06, 2020 9:43 pm
So I tried the Matrix which I ripped under 1.15.2 and that triggered DV on my 2019 Shield.
I also tried Last Jedi which I did at the weekend with 1.15.3 and that only played back in HDR.
Cannikin
#52
Post
by Cannikin » Tue Oct 06, 2020 9:57 pm
I tried a few movies at lunch on my 2019 Nvidia Shield Pro and these triggered DV:
2001
The Matrix
Saving Private Ryan
War of the Worlds
I also tried The Shining which only triggered HDR. Of those I tried, The Shining is the only one that also has HDR10+ support which could have something to do with it?
I've got 26 Dolby Vision movie rips plus seasons 1 and 2 of Westworld so I've got a bunch more to test. More updates tonight.
Cannikin on Tue Oct 06, 2020 11:43 pm, edited 2 times in total.
#53
Post
by shawnc22 » Tue Oct 06, 2020 11:02 pm
Digital moe wrote: Tue Oct 06, 2020 9:43 pm
Is this the last jedi disc that was released back in 2018 or the recent one with the rest of the series re-release?
Rumourd
#54
Post
by Rumourd » Tue Oct 06, 2020 11:25 pm
Cannikin wrote: Tue Oct 06, 2020 9:57 pm
I tried a few movies at lunch which triggered DV:
2001
The Matrix
Saving Private Ryan
War of the Worlds
Tried it on what?
Digital moe
#55
Post
by Digital moe » Tue Oct 06, 2020 11:29 pm
The original release from 2018.
Cannikin
#56
Post
by Cannikin » Tue Oct 06, 2020 11:42 pm
Rumourd wrote: Tue Oct 06, 2020 11:25 pm
Tried it on what?
Latest Plex beta manually installed onto a 2019 Nvidia Shield Pro (updated the original post to mention this as well)
Digital moe
#57
Post
by Digital moe » Wed Oct 07, 2020 12:09 am
The German UHD of Oldboy seems to work fine as well and triggers DV playback
Edit:
National Lampoons Van Wilder also triggers DV playback.
SyrimSloane
#58
Post
by SyrimSloane » Wed Oct 07, 2020 12:27 am
Just updated to latest Plex Beta and played the Wizard of OZ which i ripped two days ago, and Dolby Vision triggered. Can wait try to newer releases.
jayper
#59
Post
by jayper » Wed Oct 07, 2020 1:32 am
I've noticed that triggering DV can be finicky. It seems that if any drives are asleep in my NAS and the drive needs to spin up before the film starts, then only HDR will trigger. After the drive is spinning, it doesn't seem to be an issue.
PanBear
#60
Post
by PanBear » Wed Oct 07, 2020 1:44 am
DV Triggers playing Gemini Man on a shield pro 2019 at 60fps.
