Dolby Vision and 1.15.1
Re: Dolby Vision and 1.15.1
Post by SamuriHL » Tue Oct 06, 2020 7:27 pm
jakuboleksy wrote: Tue Oct 06, 2020 3:49 pm https://forums.plex.tv/t/release-announ ... 154124/362
WHATS NEW:
Bump the minimum supported Plex Media Server version to 1.15.2.
Player: support for Dolby Vision in MKV.
Player: Live TV is no longer supported in the old player.
Holy balls! That's fantastic news right there!!!!!!!
codeXRes
Post by codeXRes » Tue Oct 06, 2020 8:06 pm
SamuriHL wrote: Tue Oct 06, 2020 7:27 pm
WHATS NEW:
Great news. Any idea how long it'll take to make it to the public Google Play release?
Post by SamuriHL » Tue Oct 06, 2020 8:15 pm
That's anyone's guess. I've never been able to get the beta of plex on my SHIELD so I'm probably going to have to wait, as well.
Epedemic
Post by Epedemic » Tue Oct 06, 2020 8:33 pm
SamuriHL wrote: Tue Oct 06, 2020 8:15 pm That's anyone's guess. I've never been able to get the beta of plex on my SHIELD so I'm probably going to have to wait, as well.
There's an apk in the link.
I just got it from play store, and it works IF i set refresh rate manually to 23/24fps (LG E6).
Rumourd
Post by Rumourd » Tue Oct 06, 2020 11:27 pm
WHATS NEW:
Plex is already up to 1.20.xxxx
Are you confusing this with MakeMKV 1.15.2 or 1.15.3?
jayper
Post by jayper » Tue Oct 06, 2020 11:38 pm
Rumourd wrote: Tue Oct 06, 2020 11:27 pm
WHATS NEW:
Minimum supported versions means that any version older than stated will no longer be compatible. Meaning if you're running Plex Media Server 1.15.0, then the client will not be compatible.
Rumourd
Post by Rumourd » Tue Oct 06, 2020 11:45 pm
jayper wrote: Tue Oct 06, 2020 11:38 pm
WHATS NEW:
Thank you for clarifying for a dolt. :D
jayper
Post by jayper » Wed Oct 07, 2020 1:34 am
Rumourd wrote: Tue Oct 06, 2020 11:45 pm
Of course, all good. The Plex version numbering being so close to MakeMKV threw me off at first too.
Cannikin
Post by Cannikin » Wed Oct 07, 2020 3:42 am
I tested all of my Dolby Vision encoded MKVs (ripped using MakeMKV 1.15.2) and all of them triggered DV on my LG B7 OLED being fed by a 2019 Nvidia Shield Pro!
However, the majority of them would first trigger HDR instead of DV. I would then hit “back” on the remote, start the movie again, and then DV would be enabled. This sometimes took as many as 6 tries in re-starting the movie to get DV to “stick.” I could then come back to the same movie I had problems with and DV would trigger the first time.
Full List:
1917
Alita: Battle Angel
Anna
Annihilation
Apocalypse Now
Aquaman
Atomic Blonde
Bumblebee
Casino Royale
Doctor Sleep
The Evil Dead
Evil Dead 2
First Man
Gemini Man
Ghost in the Shell
Hereditary
Hunter Killer
It Chapter 2
John Wick 3
Jurassic World: Fallen Kingdom
Knives Out
The Matrix
Matrix 2
Matrix 3
Midway
Mission: Impossible 1-6
Mother!
Pacific Rim: Uprising
Pitch Black
Quantum of Solace
A Quiet Place
Ready Player One
The Shining
Skyfall
Skyscraper
Spectre
Spider-man: Far from Home
Spider-man: Homecoming
Transformers: The Last Knight
Valerian and the City of a Thousand Planets
War of the Worlds
Westworld (Seasons 1 and 2)
The Witch
The Wizard of Oz
jakuboleksy
Post by jakuboleksy » Wed Oct 07, 2020 3:46 am
How do you load the beta Plex? Just from the store or do I have to do something different?
Cannikin
Post by Cannikin » Wed Oct 07, 2020 4:21 am
jakuboleksy wrote: Wed Oct 07, 2020 3:46 am How do you load the beta Plex? Just from the store or do I have to do something different?
You'll have to download the .apk file manually (they said you have to be a Plex Pass member in order to download it). If you're using a Shield you'll want the "arm64v8a" version. Then you'll need to get the file onto your Shield somehow. You can plug in a USB drive, or if you install something like the FX app https://play.google.com/store/apps/deta ... nextapp.fx which will let you load files from the network. Once you do, you just open the .apk file and it'll walk you through installation.
Here's a video showing you how to enable "web" mode in FX so you can download the file on your computer and then drag/drop it into the Shield: https://www.youtube.com/watch?v=-M4MTmE83pw
jakuboleksy
Post by jakuboleksy » Wed Oct 07, 2020 4:25 am
Cannikin wrote: Wed Oct 07, 2020 4:21 am
Thanks for the detailed explanation!
phneutral
Post by phneutral » Wed Oct 07, 2020 7:00 am
Sorry if it's been asked before, but can I remux existing MKV files with the DV layer to trigger DV in Plex, and if so how?
Cannikin
Post by Cannikin » Wed Oct 07, 2020 3:46 pm
phneutral wrote: Wed Oct 07, 2020 7:00 am Sorry if it's been asked before, but can I remux existing MKV files with the DV layer to trigger DV in Plex, and if so how?
If you ripped the MKV using MakeMKV 1.15.2 or higher they should be good to go! If you ripped them in 1.15.1 then I think you can open it with 1.15.3 and output it back to a new file and it'll fix the metadata to match the correct spec (the same thing 1.15.2 would have created).
Rumourd
Post by Rumourd » Wed Oct 07, 2020 7:31 pm
Cannikin wrote: Wed Oct 07, 2020 3:46 pm
This only works on Plex through NVIDIA Shield, correct? Because I feed my Laptop Windows 10 to Plex solely, and nothing triggers the DV, so far.
