Dolby Vision and 1.15.3
Rumourd
Re: Dolby Vision and 1.15.3
Post by Rumourd » Mon Oct 05, 2020 9:52 pm
mike admin wrote:
Mon Oct 05, 2020 9:07 pm
Rumourd wrote:
Sat Oct 03, 2020 5:31 am
What if you used 1.15.1 and later? Will it work then?
Yes.
1.15.0 - DV discarded
1.15.1 - DV bitstream preserved when opening BD disc. Discarded if source is MKV file. A bug - DV bitstream is (slightly and reversibly) corrupted. No MKV DV metadata.
1.15.2 - DV bitstream preserved when opening BD disc. Discarded if source is MKV file. No bitstream corruption bug. Full MKV DV metadata.
1.15.3 - DV bitstream preserved when opening all sources. DV metadata ignored in source container, full MKV DV metadata always reconstructed from bitstream. Corrupted bitstream produced by 1.15.1 is recognized and repaired. DV bitstreams with invalid codec IDs (V_QUICKTIME and V_MS_FOURCC/DVHE) produced by mkvtoolnix and ffmpeg are properly recognized.
Thanks, and thanks for this great software! Hopefully plex will add DV readability soon!
tazlord
Post by tazlord » Mon Oct 05, 2020 10:15 pm
Unfortunately, this doesn't seem to be working. I have tried it in 2 scenarios (below) with unexpected results.
Am I doing something wrong?
Scenario 1: MKV with original BL and EL tracks embedded.
Supplying an MKV with both of the original BL and EL tracks embedded to MakeMKV 1.15.3 does not return expected results. MakeMKV does not display any DV metadata when selecting this type of MKV as the source. Executing the "remux" results in an MKV file with a single HDR10 HEVC track with no DV metadata present (loading the resulting MKV back into MakeMKV shows no DV metadata present).
Original "Dual-Layer" tracks (BL + EL) wrapped in MKV
Track information
Type: Video
Codec: MpegH HEVC Main10@L5.1
Resolution: 3840x2160
Aspect ratio: 16:9
Frame rate: 23.976 (24000/1001)
Resulting single-track MKV from MakeMKV using the above file as source
Track information
Type: Video
Resolution: 3840x2176
Scenario 2: MKV with original HDR10 HEVC track (BL only) embedded.
Supplying an MKV with only the original BL track (no EL track) embedded to MakeMKV 1.15.3 does not return expected results. MakeMKV does not display any DV metadata when selecting this type of MKV as the source. Executing the "remux" results in an MKV file with a single HDR10 HEVC track with no DV metadata present (loading the resulting MKV back into MakeMKV shows no DV metadata present).
Original BL track wrapped in MKV
Track information
Type: Video
Aspect ratio: 16:9
Track information
Type: Video
Aspect ratio: 16:9
Fuluer
Post by Fuluer » Mon Oct 05, 2020 11:33 pm
Track information
Type: Video
Aspect ratio: 16:9
Track information
Type: Video
Track information
Type: Video
Aspect ratio: 16:9
Track information
Type: Video
Aspect ratio: 16:9
It's not ideal - requires 3 programs, 2 intermediate files, lots of storage, and time - but this works consistently viewtopic.php?f=12&t=23306&p=97160#p97160
jlpsvk
Post by jlpsvk » Tue Oct 06, 2020 12:32 am
when i use as source MKV, with video from yousesope's tool mode 2, i get dvhe.07.00 BL+RPU... is that correct??? i think it should not be 07.00... probably 05.06 would be ideal for single track single layer MEL
tazlord
Post by tazlord » Tue Oct 06, 2020 1:28 am
Unfortunately, the method described in that post doesn't seem to work for me either.
Post by shawnc22 » Tue Oct 06, 2020 2:51 am
Track information
Type: Video
Aspect ratio: 16:9
Track information
Type: Video
Track information
Type: Video
Aspect ratio: 16:9
Track information
Type: Video
Aspect ratio: 16:9
Scenario 2 is obviously not going to work because the EL was discarded in the original remux process. You're not magically going to get the DV EL back when running it through 1.15.3.
As for scenario 1, I haven't tried it myself, but from the reports of others, it doesn't look like 1.15.3 will recognize mkvs that have BL and EL layers on separate tracks. At this point, you have a few options to get to a compliant DV mkv file (assuming the BL and EL tracks were not altered in any way during the remux process):
1) The easiest way is to probably just drop the mkv into tsmuxer, create a structured bluray iso, mount it and then load it with makemkv. If the mkv contains an atmos track, you will need to extract it and convert it first to thd+ac3 format with eac3to before using it with tsmuxer.
2) The longer and not entirely sure it'll work method is to extract out the BL and EL layers from the mkv, merge it with yusecope's tool into a single BL+EL+RPU track, drop it into an mkv (mkvtoolnix or tsmuxer -> ts and then a 1:1 container conversion with ffmpeg), and finally open it with makemkv and remux.
tazlord
Post by tazlord » Tue Oct 06, 2020 3:55 am
I'll have to give that a try. Unfortunately, "assuming the BL and EL tracks were not altered in any way during the remux process" also presents an issue for me as my ultimate goal is to compress the BL track to save space and re-merge it with the EL track. I have been able to do that successfully using the dual-layer MP4 method and the re-compressed video does in fact play back in DV. Hopefully that will be possible with whatever single-layer MKV method(s) come from all of this testing and development.
jlpsvk
Post by jlpsvk » Tue Oct 06, 2020 8:12 am
what about devices which supports only dvhe.05 profile? that means only BL+RPU (MEL single track single layer)? makemkv produces dvhe.07.06, which is not supported on many devices.... i can make dvhe.05.06, which works from m2ts, but when running through MakeMKV, it's dvhe.07.00(BL+RPU)... which is weird.
ghostshadow
Post by ghostshadow » Tue Oct 06, 2020 11:59 am
I followed the method given on post 1.
I wanted to open the final mkv created by MakeMkv 1.15.3 with tsmuxer to extract the tracks for checking.
When I import the mkv into tsmuxer it tells me: 'Track 1 was not recognized and was ignored for the file' final.mkv '
Is this normal?
whiplash1
Post by whiplash1 » Tue Oct 06, 2020 1:03 pm
Is this normal?
That's probably the Atmos track getting rejected by tsmuxer.
ghostshadow
Post by ghostshadow » Tue Oct 06, 2020 2:59 pm
Is this normal?
Exactly what a jerk I am. Thank you very much I had completely forgotten the sound tracks I was obsessed with the video lol.
Impeccable, I receive my Zidoo z9x on Thursday I could test the mkv on it
whiplash1
Post by whiplash1 » Tue Oct 06, 2020 3:07 pm
Is this normal?
ray_007
Post by ray_007 » Tue Oct 06, 2020 3:58 pm
Hi, Does that also mean I can just throw in a .m2ts DV file into Makemv and it will then produce a DV capable MKV? If so then would I be able to put the resulting file in mkvtoolnix to add/remove Subs and Audio stream while retaining the DV info?
ray_007
Post by ray_007 » Tue Oct 06, 2020 5:28 pm
Never mind, tried and didnt work. Going to try it with my current MP4 DV's. Will the conversion effect the quality of the video?
Post by shawnc22 » Tue Oct 06, 2020 5:39 pm
Never mind, tried and didnt work. Going to try it with my current MP4 DV's. Will the conversion effect the quality of the video? Also I am not very good with command lines, so can anyone explain what exactly do i have to type to convert my current MP4 to MKV using ffmpeg?
You can use the m2ts DV file, but you will need to do a straight container conversion to mkv before opening it with makemkv. The ffmpeg command to do so is in the first post of this thread. After creating the new mkv file with 1.15.3, you can process it with mkvtoolsnix; the latest version should retain all the DV metadata.
