Dolby Vision and 1.15.1
spink123
Re: Dolby Vision and 1.15.1
Post by spink123 »
Hi guys, I finally managed to get DV played on my Shield as shown on my Vertex2 (LLDV). However, when I used MediaInfo app to check the mkv ripped movie there isn’t any ‘Dolby Vision’ displayed under HDR format. I downloaded some .ts and .mp4 DV demo clips and MediaInfo did show them as ‘Dolby Vision’.
Any guys here using any other apps in Mac to check the details of the DV mkv files and state that they are of DV format? Thanks
zeerow2k
Post by zeerow2k »
spink123 wrote: Sun Sep 20, 2020 7:13 pm Hi guys, I finally managed to get DV played on my Shield as shown on my Vertex2 (LLDV). However, when I used MediaInfo app to check the mkv ripped movie there isn’t any ‘Dolby Vision’ displayed under HDR format. I downloaded some .ts and .mp4 DV demo clips and MediaInfo did show them as ‘Dolby Vision’.
this has been addressed multiple times in this thread.
mediainfo has not yet been updated to detect the dolby vision information in MKV files.
gabi.gegea@gmail.com
Post by gabi.gegea@gmail.com »
Any updates regarding an apk version of the new Exoplayer?
djbuddha
Post by djbuddha »
gabi.gegea@gmail.com wrote: Sat Sep 26, 2020 12:01 pm Any updates regarding an apk version of the new Exoplayer?
I’m also curious about this
djbuddha wrote: Sat Oct 03, 2020 2:48 pm
Looks like it is not yet available yet.
ElegyD
Post by ElegyD »
Latest Plex for Android beta (8.8.0.20999-beta) adds support for Dolby Vision in MKV.
https://forums.plex.tv/t/android-mobile ... 154125/367
Cannikin
Post by Cannikin »
ElegyD wrote: Tue Oct 06, 2020 2:53 pm Latest Plex for Android beta (8.8.0.20999-beta) adds support for Dolby Vision in MKV.
:shock: Anyone know which APK is needed for an Nvidia Shield Pro?
Dinst
Post by Dinst »
Cannikin wrote: Tue Oct 06, 2020 3:38 pm
Arm64 for the 2019 Pro
jakuboleksy
Post by jakuboleksy »
https://forums.plex.tv/t/release-announ ... 154124/362
WHATS NEW:
Bump the minimum supported Plex Media Server version to 1.15.2.
Player: support for Dolby Vision in MKV.
Player: Live TV is no longer supported in the old player.
Cannikin
Post by Cannikin »
Cannikin
Post by Cannikin »
HOL-EE CRAP IT WORKED
The very first time I started a DV movie it showed the badge for about 5 seconds and then the screen flashed and the HDR badge came up instead. I exited out and went back in and it stayed DV for a good 15 seconds, but I had to get to a meeting for work so that's the longest I could test.
I'll try watching some harder stuff (like Gemini Man in 60fps) later and post some updates!
quietvoid
Post by quietvoid »
On the Firestick 4K, the Plex app crashes when backing out. Don't have a Plex forum account otherwise I'd comment there.
For playback (makemkv samples):
Profile 5 > nothing triggered
Profile 7, MEL > HDR triggered
Profile 7, FEL > Dolby Vision triggered, black screen
Profile 8.1 > HDR triggered
So same behavior as ExoPlayer for FEL, except it only plays P7 FEL correctly..
On yusesope's ExoPlayer apk, they all trigger Dolby Vision.
Dinst
Post by Dinst »
quietvoid wrote: Tue Oct 06, 2020 5:27 pm On the Firestick 4K, the Plex app crashes when backing out. Don't have a Plex forum account otherwise I'd comment there.
There is a tool to convert FEL to MEL
quietvoid
Post by quietvoid »
Dinst wrote: Tue Oct 06, 2020 5:30 pmThere is a tool to convert FEL to MEL
Totally aware, but that's not the point. It should at least trigger Dolby Vision on all of the samples.
Dinst
Post by Dinst »
quietvoid wrote: Tue Oct 06, 2020 5:43 pm
Just buy a Shield, it plays any form of single layer Dolby Vision you can throw at it and it also supports TrueHD Atmos.
