ghostshadow
Post by ghostshadow »
Tomas wrote:
Mon Oct 05, 2020 6:33 pm
ghostshadow wrote:
Mon Oct 05, 2020 3:02 pm
Tomas wrote:
Mon Oct 05, 2020 2:45 pm
Hi, I have it set to AUTO. I can't open the mp4muxer program or I don't know how to do it via the command line.
1. You go to your folder where you have decompressed mp4muxer
2. In the window at the top you click on: File --> Open Windows PowerShell --> Open Windows PowerShell as administrator
3. You type in the console : .\mp4muxer -i path\to\BL_EL_RPU.hevc --dv-profile 8 --dv-bl-compatible-id 1 -o path\to\TEST_FILE.mp4
PS : path\to\BL_EL_RPU.hevc = location of your file BL_EL
Please, I'm probably doing something stupid. You wouldn't advise me how to write a path. The BL_EL_RPU.HEVC file is saved on disk "G" in the "mp4muxer" folder. Please how do I write the path to the mp4 conversion
.\mp4muxer -i G:\mp4muxer\BL_EL_RPU.hevc --dv-profile 8 --dv-bl-compatible-id 1 -o G:\TEST_FILE.mp4
Tomas
Post by Tomas »
ghostshadow wrote:
Mon Oct 05, 2020 7:32 pm
I am doing something wrong?
https://ibb.co/Q6jvCT8
ray_007
Post by ray_007 »
Fuluer wrote:
Mon Oct 05, 2020 6:14 pm
ray_007 wrote:
Mon Oct 05, 2020 4:07 pm
As a partially deaf person I heavily rely on subtitles but so far I have not been able to get subtitles working on any of my DV files. Currently I am using following method:
Use tsmuxer to get 'bl' and 'el' Audio and Subtitles (PGS) files
Generate a bl-el-rpu file using 'yusesope' tool (mode 1)
Use tsmuxer to Mux bl-el-rpu+Audio+Subtitle and generate a .ts file.
The said files (format 4) works flawlessly with DV on my TV via USB HDD but the subtitles just wont work no matter what method I try. So far I have tried renaming the sub file similar to movie name, putting the sub file and movie in same folder, converting PGS to SRT, but nothing works. Even MPC-HC refuses to show subtitles on these files.
Is this a .ts file types restriction or am I doing something wrong here? Please help me out. Thanks.
I can't personally verify, but this post seems to say TS doesn't support PGS when using DV -
viewtopic.php?f=12&t=18602&p=85286#p85286
That sucks, so do I have any other options? Even with MP4 I cannot seem to get subtitles working and I have used the utility posted by 'Grencola' and method posted on Page 1.
ghostshadow
Tomas wrote:
Mon Oct 05, 2020 7:46 pm
.\mp4muxer -i G:\mp4muxer\BL_EL_RPU.hevc --dv-profile 8 --dv-bl-compatible-id 1 -o G:\test1.mp4
acsokis
Post by acsokis »
"Automated" BL+EL+RPU.hevc creation for yusesope tool
Here is my solution for an "automated" BL+EL+RPU.hevc creation for device which plays only Single Track Dual Layer MEL films. Because
the use of the original MUX_AND_CONVERT_TO_MEL.bat and DEMUX_AND_CONVERT_TO_MEL.bat in case of FEL films always faild. Films are hanged after a few mins or they was choppy after a few mins.
Here is a code for a simple .bat file to do the same. This is a simple batch run for FEL to MEL via ffmpeg demuxing and muxing by the tool.
In the last step you can set everything manually in tsMUXER.
Input and output paths needs to be configures for your machine. It is a simple "Search and change" with any kind of notepad apps.
When the process is finished it opens up tsMuxer with the BL_EL_RPU.hevc and with the original media file. From you can set audio channels and subs manually and individually for each movies.
Run command with drag and drop media file onto batch file.
Just rename the attached .txt to .bat
FEL to MEL demux and make BL+EL+RPU.hevc.txt
(10.9 KiB) Downloaded 905 times
The King of the Code
The Code of the King
daddy
Post by daddy »
ghostshadow wrote:
Mon Oct 05, 2020 9:47 am
Hello, I tested on MIDWAY FR UHD Dolby Vision . Playback on the internal player of the Panasonic HZ1500E TV
Process below I used recommended versions of all software
created BL.hevc and EL.hevc using ffmpeg
MUX_AND_CONVERT_TO_PROFILE_81.bat to create BL_EL_RPU.hevc
mp4muxer with BL_EL_RPU.hevc to create .mp4
The final MP4 is well read in DV, I watched 1 hour. No image concerns.
I tested by doing the procedure to make an mkv and add my soundtracks (DTS HD)
The MKV is read without problem but in HDR PQ
I don't know how to add the DTS tracks to the mp4 (to make an mp4 file with DTS soundtracks).
I tested to mux with FFmpeg but suddenly I have an mp4 without DV (under media info)
Pour le mkv je pense pas que mon lecteur interne puisse le lire en DV, ça vient du lecteur
For the mkv I don't think my internal player can read it in DV, it comes from the player
om complet                              : J:\midway\MidwayT2.mp4
Profil du format                         : Base Media / Version 2
Identifiant du codec                     : mp42 (mp42/dby1/isom)
Taille du fichier                        : 34,3 Gio
Durée                                    : 2 h 18 min
Débit global moyen                       : 35,5 Mb/s
Date d'encodage                          : UTC 2020-10-04 16:48:40
Date de marquage                         : UTC 2020-10-04 16:48:40
Vidéo
Profil du format                         : Main 10@L5.1@High
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU / SMPTE ST 2086, HDR10 compatible
Identifiant du codec                     : dvhe
Identifiant du codec/Info                : High Efficiency Video Coding with Dolby Vision
Durée                                    : 2 h 18 min
Débit                                    : 35,5 Mb/s
Largeur                                  : 3 840 pixels
Hauteur                                  : 2 160 pixels
Format à l'écran                         : 16/9
Type d'images/s                          : Constant
Images par seconde                       : 23,976 (24000/1001) Im/s
Espace de couleurs                       : YUV
Sous-échantillonnage de la chrominance   : 4:2:0
Profondeur des couleurs                  : 10 bits
Bits/(Pixel*Image)                       : 0.179
To add dts/dts-hd to an mp4 file
- first demux it as audio.mp4. exemple: ffmpeg.exe -i 00058.m2ts -map 0:0 -c copy BL.hevc -map 0:1 -c copy EL.hevc -map 0:7 -c copy audio.mp4
- then add the audio mp4 to your mp4_dv file with mp4box. exemple : mp4box.exe -add mp4_dv.mp4:rate=0 -add audio.mp4#audio:lang=fr-FR -no-iod mp4_dv_movie.mp4
C'est bizarre. Le débit vidéo de ton fichier Midway est trés faible (35Mb/s) comparé à ma version dvhe.07.06. Il a été réencodé ?
Général
Nom complet                              : Y:\4k\Midway [dts][4k][DV].mp4
Identifiant du codec                     : isom (isom)
Taille du fichier                        : 69,2 Gio
Durée                                    : 2 h 18 min
Débit global moyen                       : 71,6 Mb/s
Date d'encodage                          : UTC 2020-03-03 12:24:09
Date de marquage                         : UTC 2020-03-03 12:24:09
Vidéo #1
HDR format                               : SMPTE ST 2086, HDR10 compatible
Identifiant du codec                     : hev1
Durée                                    : 2 h 18 min
Débit                                    : 63,0 Mb/s
Sous-échantillonnage de la chrominance   : 4:2:0 (Type 2)
Bits/(Pixel*Image)                       : 0.317
Taille du flux                           : 60,9 Gio (88%)
Default                                  : Non
Date d'encodage                          : UTC 2020-03-03 09:20:45
Date de marquage                         : UTC 2020-03-03 12:31:27
Gamme de couleurs                        : Limited
Coordonnées de chromaticité              : BT.2020
Caractéristiques du transfert            : PQ
Coefficients de la matrice               : BT.2020 non-constant
Mastering display color primaries        : BT.2020
Maximum Frame-Average Light Level        : 502 cd/m2
Codec configuration box                  : hvcC
Vidéo #2
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
Durée                                    : 2 h 18 min
Débit                                    : 7 074 kb/s
Largeur                                  : 1 920 pixels
Hauteur                                  : 1 080 pixels
Bits/(Pixel*Image)                       : 0.142
Taille du flux                           : 6,84 Gio (10%)
Default                                  : Non
Audio
Format                                   : DTS
Identifiant du codec                     : mp4a-A9
Durée                                    : 2 h 18 min
Type de débit                            : Constant
Débit                                    : 1 509 kb/s
Débit maximum                            : 1 529 kb/s
Canaux                                   : 6 canaux
Channel layout                           : C L R Ls Rs LFE
Echantillonnage                          : 48,0 kHz
Images par seconde                       : 93,750 Im/s (512 SPF)
Profondeur des couleurs                  : 24 bits
Mode de compression                      : Avec perte
Taille du flux                           : 1,46 Gio (2%)
Langue                                   : Français
Default                                  : Oui
ghostshadow
daddy wrote:
Tue Oct 06, 2020 5:45 am
Durée                                    : 2 h 18 min
Vidéo
Durée                                    : 2 h 18 min
Débit                                    : 35,5 Mb/s
Général
Durée                                    : 2 h 18 min
Vidéo #1
Durée                                    : 2 h 18 min
Débit                                    : 63,0 Mb/s
Default                                  : Non
Vidéo #2
Durée                                    : 2 h 18 min
Débit                                    : 7 074 kb/s
Default                                  : Non
Audio
Format                                   : DTS
Durée                                    : 2 h 18 min
Débit                                    : 1 509 kb/s
Canaux                                   : 6 canaux
Langue                                   : Français
Default                                  : Oui
en FR
Merci bien pour l'audio
Oui c'est une encode x265 que j'ai fait sur le BL
in En
Thanks for the audio
Yes it's an x265 encode that I made on the BL
Tomas
Post by Tomas »
ghostshadow wrote:
Mon Oct 05, 2020 9:20 pm
Thank you very much, it already works. I can ask how long does it take to convert a movie to mp4.
ghostshadow
5mn on my pc Ryzen 9 3900x
whiplash1
Post by whiplash1 »
Finally I've done it! This was my white whale. I'm so relieved my 6yr old laptop managed to power through the entire process and it works like a charm! Massive thank you to you yusesope! You're a legend mate!
https://ibb.co/ZWrPNsW
Tomas
Post by Tomas »
Please, did anyone who has ZIDOO Z9X convert the movie to go well? So that the image does not tear?
ghostshadow
Tomas wrote:
Tue Oct 06, 2020 2:47 pm
I receive mine on Thursday, and I will test at that time. For the moment on the internal player of my Panasonic TV, the mp4 and TS files pass without problem in dolby vision.
And I saw the difference visually on the Midway film, between HDR10 and Dolby vision.
When I have the Z9x if it recognizes dolby vision files, I will try to get the information on the tv with my HDFury (I have to find out how to do it) so I will be sure that the dolby meta data is fine.
ragico
Post by ragico »
The last Plex beta added support fo DV mkv.
Here: https://forums.plex.tv/t/release-announ ... 154124/362
iamTa
Post by iamTa »
ragico wrote:
Tue Oct 06, 2020 9:56 pm
And it works a treat on the Shield 2019 :D
Post by SamuriHL »
Yes, it triggers DV. A LOT of testing needs to happen cause from what I can see in my limited 2 minute testing so far it looks like a mess. The colors seems way off to me. I could be wrong and will do some bigger comparisons this weekend when I get a chance but I see red. Lots of red.
