I'm having problems ripping CSI - s01d02 title 04. I have ripped every other title on every disc for the entire set except this one. I have verified that the other titles play fine. What I am receiving is this:
AV synchronization issues were found in file '/video/tv/CSI/CSI - s01ed2_t04.mkv' (title #5)
AV sync issue in stream 0 at 0:00:02.002 : video frame timecode differs by +66.733ms
AV sync issue in stream 0 at 0:00:02.035 : video frame timecode differs by -33.366ms
AV sync issue in stream 0 at 0:00:12.812 : video frame timecode differs by +66.733ms
AV sync issue in stream 0 at 0:00:12.846 : video frame timecode differs by -33.366ms
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 286863360-286869504, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 286869504, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 286869504-286875648, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 286875648, attempting to work around
The source file '/BDMV/STREAM/00000.m2ts' is corrupt or invalid at offset 286906368, attempting to work around
AV sync issue in stream 0 at 0:01:07.984 : video frame timecode differs by -83.416ms
AV sync issue in stream 0 at 0:01:08.001 : video frame timecode differs by -66.733ms
AV sync issue in stream 0 at 0:01:08.084 : video frame timecode differs by -16.683ms
AV sync issue in stream 0 at 0:01:08.034 : video frame timecode differs by -33.366ms
AV sync issue in stream 0 at 0:01:08.118 : video frame timecode differs by -16.683ms
Failed to save title 4 to file /video/tv/CSI/CSI - s01ed2_t04.mkv
0 titles saved, 1 failed
Now the fun part. I tried this on three drives with the same results. Thinking I had a bad disc, I got my hands on another copy of the disc.... and received the EXACT same error on the EXACT same title. And I mean exact. offset #'s and everything are an EXACT match between the two discs. This has got to be some sort of pressing or mastering error or possibly copy protection due to the repeatability between discs and drives.
Any thoughts/help would be greatly appreciated.
Update 19:08 - I noticed 1.15.3 was available and attempted with no change. Previous attempt was with 1.15.2.
CSI Bluray
Krawk
Re: CSI Bluray
Posted the same problem couple of years ago, both a Canada disc and a USA disc. There is a mastering error or something of the sort at play. I eventually copied disc to hard drive then decoded it that way.
ranger671
Re: CSI Bluray
Thanks for the reply Krawk. I followed your lead and made a backup of the disc and performed a stream dump creating an mts data file. It still glitched early in the video at the point of the issue. I still would have liked a check box to ignore the corrupt area and just grab the data that's there.
Krawk
Re: CSI Bluray
What I mean is that I dragged and dropped the files from the disc to the hard drive, then pointed MakeMKV to the hard drive. I kept getting a HASH error every time I tried directly from the disc, even with Any DVD ahead of MakeMKV.ranger671 wrote: Tue Oct 06, 2020 6:07 pm Thanks for the reply Krawk. I followed your lead and made a backup of the disc and performed a stream dump creating an mts data file. It still glitched early in the video at the point of the issue. I still would have liked a check box to ignore the corrupt area and just grab the data that's there.
If you get an error doing what I suggest, have MakeMKV look at the disc first, then go to your Windows Explorer Window and copy the files. It somehow unlocks the ability to copy the files, but somehow leaves them encrypted.
ranger671
Re: CSI Bluray
Krawk, I appreciate the followup, but I'm on Linux not Windows.
