RIPPING "LOVE THE COOPERS"
bfnplm
Post by bfnplm »
The subject DVD seems to have an algorithm that MakeMKV cannot handle. I have tried 2 different DVDs on 4 different players which generate the same errors. I've included the errors generated.
MakeMKV v1.15.3 win(x64-release) started
Title #1 was added (23 cell(s), 1:49:25)
Title #2 was added (2 cell(s), 0:02:32)
Title #3 was added (2 cell(s), 0:02:32)
Title #4 was added (2 cell(s), 0:02:31)
Title #5 was added (2 cell(s), 0:02:36)
Title #6 has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 was added (2 cell(s), 0:02:38)
Title #9 has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 was added (1 cell(s), 0:24:40)
Title #14 was added (1 cell(s), 0:14:20)
Title #17 was added (23 cell(s), 1:49:25)
Cells 2-6 were skipped due to cell commands (structure protection?)
Title #18 was added (19 cell(s), 1:49:01)
Title #19 was added (19 cell(s), 1:49:01)
Title #20 was added (19 cell(s), 1:49:01)
Title #21 was added (19 cell(s), 1:49:01)
Title #22 was added (23 cell(s), 1:49:25)
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Title #23 was added (18 cell(s), 1:46:52)
Title #24 was added (18 cell(s), 1:46:52)
Title #25 was added (18 cell(s), 1:46:52)
Title #28 was added (18 cell(s), 1:46:52)
Title #29 was added (18 cell(s), 1:46:52)
Title #30 was added (23 cell(s), 1:49:25)
Title #31 was added (23 cell(s), 1:49:25)
Title 1 in VTS 25 is equal to title 1 and was skipped
Title 2 in VTS 25 is equal to title 1 and was skipped
Title 1 in VTS 23 is equal to title 1 and was skipped
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'DVD+R-DL hp DVDRW SU208GB HH00' at offset '8382464'
Encountered 36 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
Saving 1 titles into directory //pbcloudthree/Public/Shared Videos/MISC DVDS/LOVE THE COOPERS
The source file 'DVD+R-DL hp DVDRW SU208GB HH00' is corrupt or invalid at offset 8820736, attempting to work around
The source file 'DVD+R-DL hp DVDRW SU208GB HH00' is corrupt or invalid at offset 8859648, attempting to work around
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'DVD+R-DL hp DVDRW SU208GB HH00' at offset '5839337472'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '5839337472'
Failed to save title 0 to file //pbcloudthree/Public/Shared Videos/MISC DVDS/LOVE THE COOPERS/Love the Coopers_t00.mkv
Encountered 11 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
0 titles saved, 1 failed
Re: RIPPING "LOVE THE COOPERS"
Start with cleaning the disk; your drive cannot read parts of it.
Next, is this drive in an external USB housing, or installed in a computer? The second batch of errors is consistent with it being spun too fast for the available power, but that usually only affects drives that are powered by USB.
