Top Gun dump sent
charlie62
Re: Top Gun dump sent
UK region B won't decrypt dump has been sent so no worries.
charlie62
Working now pure magic from Mike
snafu_
Thanks Mike. I was able to backup Top Gun today.
decaf
I bought this title in Sweden today, and unable to decrypt. Dump sent to e-mail above.
recordplay
brought this title today from Best Buy and it was unable to decrypt. This movie has been out for a bit. Any reason why it is still not rip?
Bluntman
New pressing.recordplay wrote:brought this title today from Best Buy and it was unable to decrypt. This movie has been out for a bit. Any reason why it is still not rip?
Sent from my iPad using Tapatalk Pro
Did you send in a dump @recordplay?
recordplay
No I actually don't know how to do that. I will if that helps decrypt it.
That's how it works... email dumps to svq@makemkv.com & key will automatically be downloaded when available. Usually within a week.
dp5081
dump sent US best buy version
Tw3ak
I just picked up top gun from BB also and still won't rip it. It decrypts fine, I start processing rip and gets to about 97% or so and then stops with errors before finishing.
Did you try gently cleaning your disc Tw3ak? Even brand new discs can sometimes have an almost invisible film on them.
Tw3ak
Yep i cleaned disc and still won't finish it just has a popup that a fatal error occurred or something like that.dcoke22 wrote: Thu Jan 07, 2021 9:54 pm Did you try gently cleaning your disc Tw3ak? Even brand new discs can sometimes have an almost invisible film on them.
Update: I tested in my sony uhd player on my tv and it won't play the actual movie either infact nearly everytime i load disc i get some sound and no picture even on paramount loading screen, 1 time i will see video but most times when i load disc all i get is the paramount loading screen sound and no video so obviously something wrong with my disc i am returning it to best buy for exchange and see if a new disc will actualy play. I assume maybe that's why they were on clearance on my local BB for only $9 because they are known to be bad copies.
kademi
Amazon US 4K Top Gun Maverick version won't rip. Dump submitted.
