Please I wanted to ask there no longer need to be used after MUX_AND_CONVERT_TO_PROFILE_81, use DEMUX step?yusesope wrote: ↑Fri Oct 02, 2020 1:00 pmAnother weekend is about to begin so you have a little time to try "the things" I write !
This time it's up to profile 8.1!
I have updated the POST we refer to during this testing phase.
Find all the instructions there.
This update "fixes" what was previously called "-mode 2".
The new lines of code should allow you to convert a UHD-BD (both MEL and FEL) in a file Single Track Single Layer profile 8.1 (STSL dvhe.08.0x, BL + RPU, HDR10 compatible).
All devices, especially TVs with proprietary OS, capable of playing profile 8 files (and which have so far encountered problems with DV) could benefit from this update.
Before starting, to find out if your device is able to correctly reproduce profile 8, use the test files that Dolby provides on THIS page
Happy testing!
Thank you for the advice.
