Unable to copy some HD-DVDs using the Xbox 360 reader
Silasqwerty
#1 Post by Silasqwerty » Fri Aug 28, 2020 8:05 am
Trying to copy the Transformers HD-DVD movie using the Xbox 360's HD-DVD player doesn't work right in MakeMKV, but it works perfectly when playing it back using an Xbox 360. Another affected set of discs is the "Heroes Season 1" collection. Both use AACS 4, and I'm not sure if that's directly causing the issue or if it's just that newer discs that happen to have a newer version of AACS.
Transformers:
Disc Information
Label: TRANSFORMERS_D1_NA
Timestamp: 2007-09-21 11:47:36
Data capacity: 26.33 Gb
Disc type: HD DVD-ROM
Disc size: 120mm
Maximum read rate: 30.24 Mbps [3x]
Number of layers: 2 (OTP)
The source file '/HVDVD_TS/MENULOOP.EVO' is corrupt or invalid at offset 296960, attempting to work around
The source file '/HVDVD_TS/MENULOOP.EVO' is corrupt or invalid at offset 403456, attempting to work around
The source file '/HVDVD_TS/MENULOOP.EVO' is corrupt or invalid at offset 608256, attempting to work around
The source file '/HVDVD_TS/MENULOOP.EVO' is corrupt or invalid at offset 858112, attempting to work around
The source file '/HVDVD_TS/MENULOOP.EVO' is corrupt or invalid at offset 1011712, attempting to work around
The source file '/HVDVD_TS/MENULOOP.EVO' is corrupt or invalid at offset 1306624, attempting to work around
The source file '/HVDVD_TS/MENUINTRO.EVO' is corrupt or invalid at offset 4096-8192, attempting to work around
The source file '/HVDVD_TS/MENUINTRO.EVO' is corrupt or invalid at offset 8192, attempting to work around
The source file '/HVDVD_TS/MENUINTRO.EVO' is corrupt or invalid at offset 370688, attempting to work around
The source file '/HVDVD_TS/MENUINTRO.EVO' is corrupt or invalid at offset 612352, attempting to work around
The source file '/HVDVD_TS/MENUINTRO.EVO' is corrupt or invalid at offset 974848, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 6144, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 14336, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 18432, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 24576, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 24576-26624, attempting to work around
The source file '/HVDVD_TS/FEATURE_1.EVO' is corrupt or invalid at offset 26624, attempting to work around
The source file '/HVDVD_TS/TRAILER_TEASER.EVO' is corrupt or invalid at offset 4096-8192, attempting to work around
The source file '/HVDVD_TS/TRAILER_TEASER.EVO' is corrupt or invalid at offset 8192-10240, attempting to work around
The source file '/HVDVD_TS/TRAILER_TEASER.EVO' is corrupt or invalid at offset 10240-12288, attempting to work around
The source file '/HVDVD_TS/TRAILER_TEASER.EVO' is corrupt or invalid at offset 12288-14336, attempting to work around
The source file '/HVDVD_TS/TRAILER_TEASER.EVO' is corrupt or invalid at offset 14336-16384, attempting to work around
The source file '/HVDVD_TS/TRAILER_TEASER.EVO' is corrupt or invalid at offset 16384-18432, attempting to work around
The source file '/HVDVD_TS/TRAILER_TEASER.EVO' is corrupt or invalid at offset 18432-20480, attempting to work around
The source file '/HVDVD_TS/TRAILER_TEASER.EVO' is corrupt or invalid at offset 20480-24576, attempting to work around
The source file '/HVDVD_TS/TRAILER_TEASER.EVO' is corrupt or invalid at offset 24576, attempting to work around
The source file '/HVDVD_TS/TRAILER_IRONMAN.EVO' is corrupt or invalid at offset 4096-6144, attempting to work around
The source file '/HVDVD_TS/TRAILER_IRONMAN.EVO' is corrupt or invalid at offset 6144-8192, attempting to work around
The source file '/HVDVD_TS/TRAILER_IRONMAN.EVO' is corrupt or invalid at offset 8192-10240, attempting to work around
The source file '/HVDVD_TS/TRAILER_IRONMAN.EVO' is corrupt or invalid at offset 10240-12288, attempting to work around
The source file '/HVDVD_TS/TRAILER_IRONMAN.EVO' is corrupt or invalid at offset 12288-14336, attempting to work around
The source file '/HVDVD_TS/TRAILER_IRONMAN.EVO' is corrupt or invalid at offset 14336-16384, attempting to work around
The source file '/HVDVD_TS/TRAILER_IRONMAN.EVO' is corrupt or invalid at offset 16384-18432, attempting to work around
The source file '/HVDVD_TS/TRAILER_IRONMAN.EVO' is corrupt or invalid at offset 18432-22528, attempting to work around
The source file '/HVDVD_TS/TRAILER_IRONMAN.EVO' is corrupt or invalid at offset 22528, attempting to work around
The source file '/HVDVD_TS/TRAILER_AUTOBOTS.EVO' is corrupt or invalid at offset 4096-8192, attempting to work around
The source file '/HVDVD_TS/TRAILER_AUTOBOTS.EVO' is corrupt or invalid at offset 8192-10240, attempting to work around
The source file '/HVDVD_TS/TRAILER_AUTOBOTS.EVO' is corrupt or invalid at offset 10240, attempting to work around
Failed to decode audio/video data for title #6 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #7 - invalid mux or internal error, title skipped.
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 47104-49152, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 49152, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 49152-51200, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 51200, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 55296, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 55296-57344, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 57344-59392, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 59392-61440, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 61440-63488, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 63488, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 67584, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 67584-69632, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 69632-71680, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 75776, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 75776-77824, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 77824-79872, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 79872-81920, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 81920-83968, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 83968-86016, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 86016, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 86016-88064, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 88064, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 92160, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 92160-94208, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 94208-96256, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 96256, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 96256-98304, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 98304-100352, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 100352, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 104448, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 104448-106496, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 106496-108544, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 108544-110592, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 110592-112640, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 112640-116736, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 116736-118784, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 118784, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 122880, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 122880-124928, attempting to work around
The source file '/HVDVD_TS/DWLOGO.EVO' is corrupt or invalid at offset 124928, attempting to work around
Failed to decode audio/video data for title #8 - invalid mux or internal error, title skipped.
Failed to decode audio/video data for title #9 - invalid mux or internal error, title skipped.
The source file '/HVDVD_TS/BLACK.EVO' is corrupt or invalid at offset 14336-16384, attempting to work around
The source file '/HVDVD_TS/BLACK.EVO' is corrupt or invalid at offset 16384, attempting to work around
The source file '/HVDVD_TS/BLACK.EVO' is corrupt or invalid at offset 20480, attempting to work around
The source file '/HVDVD_TS/BLACK.EVO' is corrupt or invalid at offset 26624, attempting to work around
The source file '/HVDVD_TS/BLACK.EVO' is corrupt or invalid at offset 30720, attempting to work around
Heroes Season 1 Disc 1:
Disc Information
Label: HEROES_S1_D1
Timestamp: 2007-07-12 12:20:40
Data capacity: 27.68 Gb
Disc size: 120mm
https://pastebin.com/FeL6b9CS
Silasqwerty
Re: Unable to copy some HD-DVDs using the Xbox 360 reader
#2 Post by Silasqwerty » Sat Oct 03, 2020 6:02 am
Issue still present on version 1.15.3.
