yusesope
#3181 Post by yusesope » Fri Oct 02, 2020 12:52 pm
mike admin wrote:
Thu Oct 01, 2020 8:58 pm
I was under impression that this flag is only present on single-layer streams.
I agree with you!
The problem is that this stream is present inside a UHD-BD (Spears & Munsil) and it is definitely not a FEL stream.
It only remains to recognize it as MEL (el_spatial_resampling_filter_flag is still true).
yusesope
#3182 Post by yusesope » Fri Oct 02, 2020 1:00 pm
Another weekend is about to begin so you have a little time to try "the things" I write :lol: :lol: :lol: !
This time it's up to profile 8.1!
I have updated the POST we refer to during this testing phase.
Find all the instructions there.
This update "fixes" what was previously called "-mode 2".
The new lines of code should allow you to convert a UHD-BD (both MEL and FEL) in a file Single Track Single Layer profile 8.1 (STSL dvhe.08.0x, BL + RPU, HDR10 compatible).
All devices, especially TVs with proprietary OS, capable of playing profile 8 files (and which have so far encountered problems with DV) could benefit from this update.
Before starting, to find out if your device is able to correctly reproduce profile 8, use the test files that Dolby provides on THIS page
Happy testing!
#3183 Post by mike admin » Fri Oct 02, 2020 1:26 pm
Interesting. What happens if we just discard the EL layer in this case? Do you think it is safe? I wonder if it is actually a profile 8 stream at all.
blenky
#3184 Post by blenky » Fri Oct 02, 2020 1:27 pm
ghostshadow wrote:
Fri Oct 02, 2020 9:55 am
blenky wrote:
Fri Oct 02, 2020 12:32 am
Excuse a newbie question! Do I understand correctly that the instruction in post 176 are to create the DV video file only. This would then need to be muxed with an audio track? If so what method should be used? Thanks
Hello, you can use TsMuxer
I'm testing this on my Zidoo z9X with the UHD of 1917. If I create the file as per instructions using Mp4muxer (by using Tsmuxer it only plays in HDR10) the resultant video file plays in DV. However if I then use tsmuxer to add that file and the audio stream from 1917 the output only plays in HDR10.
What am doing wrong?
Screen shot of tsmuxer attached and media info on resultant file
General
Complete name                            : D:\Newsbin\dv\1917_mp4.m2ts
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 71.8 GiB
Overall bit rate                         : 86.4 Mb/s
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Bit rate                                 : 82.5 Mb/s
Bits/(Pixel*Frame)                       : 0.415
Stream size                              : 68.6 GiB (95%)
Maximum Frame-Average Light Level        : 168 cd/m2
Audio
Format                                   : AC-3 MLP FBA 16-ch
Format/Info                              : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Muxing mode                              : Stream extension
Codec ID                                 : 131
Maximum bit rate                         : 7 158 kb/s
Delay relative to video                  : -2 s 836 ms
Stream size                              : 381 MiB (1%)
Text
Format                                   : PGS
Codec ID                                 : 144
ghostshadow
#3185 Post by ghostshadow » Fri Oct 02, 2020 2:24 pm
essaye de faire un iso avec TsMuxer et apres avec MakeMKV 1.15.3 tu fais un mkv et tu test sur ton zidoo z9x
try to do an iso with TsMuxer and after with MakeMKV 1.15.3 you do an mkv and you test on your zidoo z9x
ghostshadow
#3186 Post by ghostshadow » Fri Oct 02, 2020 2:53 pm
Happy testing!
Wahoo you're a yusesope chef I'm testing this on Sunday
Tomas
#3187 Post by Tomas » Fri Oct 02, 2020 3:09 pm
General
Format                                   : BDAV
Video
Audio
Codec ID                                 : 131
Text
Format                                   : PGS
Codec ID                                 : 144
Hi, if you want to do .TS to play DV you have to have a modified TS muxer. If you want, I can throw it at you. Otherwise, I did an ISO Blu-ray and then made an mkv in makeMKV and I played DV on Zidoo z9x.
blenky
#3188 Post by blenky » Fri Oct 02, 2020 3:14 pm
Thanks for that. I'll give that a go. Will try with profile 7 and 8.
iamTa
#3189 Post by iamTa » Fri Oct 02, 2020 4:12 pm
What's the benefit of Single Track Single Layer Profile 8.1?
blenky
#3190 Post by blenky » Fri Oct 02, 2020 4:26 pm
General
Format                                   : BDAV
Video
Audio
Codec ID                                 : 131
Text
Format                                   : PGS
Codec ID                                 : 144
I have the version of tsmuxer linked in the instructions. Is that not the correct one?
quietvoid
#3191 Post by quietvoid » Fri Oct 02, 2020 5:29 pm
Happy testing!
I've tried the new -mode 2 with a FEL title (Atomic Blonde) and it plays on the Firestick 4K, while previous default (profile 7) just plays a black screen. So that's good news.
That's with an MKV (1.15.3) and ExoPlayer.
Unless it's automatically using -fel_to_mel when using, I didn't look.
The Dolby 8.1 sample also plays in DV as well using ExoPlayer, but not on the C8 internal player.
The tool created 8.1 plays well after mp4muxer --dv-profile 8 on the internal player but not Kodi or ExoPlayer (playback failed).
blenky
#3192 Post by blenky » Fri Oct 02, 2020 6:17 pm
Trying the 8.1 and after creating hevc file using the following command.
mp4muxer -i path\to\BL_EL_RPU.hevc --dv-profile 8 -o path\to\TEST_FILE.mp4
However this give error
Error: For Dolby vision profile 8, dv-bl-compatible-id should be set, value can be 1 or 2.
Do I use 1 or 2?
blenky
#3193 Post by blenky » Fri Oct 02, 2020 6:32 pm
Managed to get 8.1 working on Zidoo z9X by using tsmuxer to combine with Atmos audio from UHD to create ISO. Then created MKV with MakeMKV. Only thing is audio is out of sync. Need to offset audio ahead by about half a second.
Playback gets juddery after about 5 minutes - unwatchable at that point
chros
#3194 Post by chros » Fri Oct 02, 2020 7:09 pm
I tested them + 1 small conversion on oppo clone, all of them plays fine! Thank you!!! :)
- 1080p mp4 from Dolby: Dolby Vision, Version 1.0, dvhe.08.05, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
- 2160p mp4 from Dolby: Dolby Vision, Version 1.0, dvhe.08.09, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
- 2 mins ts FEL->MEL sample: Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Tomas
#3195 Post by Tomas » Fri Oct 02, 2020 8:32 pm
Happy testing!
Please I wanted to ask there no longer need to be used after MUX_AND_CONVERT_TO_PROFILE_81, use DEMUX step?
Thank you for the advice.
