yusesope wrote: Thu Oct 01, 2020 8:42 amIf you followed all the steps correctly, don't worry about what BDInfo says.Tomas wrote: Wed Sep 30, 2020 9:20 pm I did everything according to the FEE procedure at MEL. The resulting film according to BD info is still FEE. I can ask where I made a mistake.
My files are special ... they are magical!
You were right, everything works as it should. Thank you very much
Tomas
Tomas
ragico
The mkv of Doctor Sleep an The Shining (MEL original) do not play in firestick 4k, sound and black screen. Anyone with the same problem?
Ok, I stand corrected - this is not FEL, but I don't know how to call this stream! I was under impression that disable_resid flag means "disable residue" which means "disable EL". I was under impression that this flag is only present on single-layer streams. If I am right, then this is not a MEL or FEL - this is "DEL" - "discard fake EL". Where did this source media came from?yusesope wrote: Wed Sep 30, 2020 9:09 pmI'm sorry mike but my only neuron is telling me it's a MEL!mike admin wrote: Wed Sep 30, 2020 6:13 pm This is FEL file, not MEL. The 1.15.3 recognizes it as such![]()
I'm happy to be proven wrong!
blenky
Excuse a newbie question! Do I understand correctly that the instruction in post 176 are to create the DV video file only. This would then need to be muxed with an audio track? If so what method should be used? Thanks
kws53
Where can I get BDInfo 0.7.5.6? DVDFab claims it is a FREE utility, but it is nowhere to be seen...
ghostshadow
Hello, you can use TsMuxerblenky wrote: Fri Oct 02, 2020 12:32 am Excuse a newbie question! Do I understand correctly that the instruction in post 176 are to create the DV video file only. This would then need to be muxed with an audio track? If so what method should be used? Thanks
yusesope
I agree with you!mike admin wrote: Thu Oct 01, 2020 8:58 pm I was under impression that this flag is only present on single-layer streams.
The problem is that this stream is present inside a UHD-BD (Spears & Munsil) and it is definitely not a FEL stream.
It only remains to recognize it as MEL (el_spatial_resampling_filter_flag is still true).
yusesope
Another weekend is about to begin so you have a little time to try "the things" I write
This time it's up to profile 8.1!
I have updated the POST we refer to during this testing phase.
Find all the instructions there.
This update "fixes" what was previously called "-mode 2".
The new lines of code should allow you to convert a UHD-BD (both MEL and FEL) in a file Single Track Single Layer profile 8.1 (STSL dvhe.08.0x, BL + RPU, HDR10 compatible).
All devices, especially TVs with proprietary OS, capable of playing profile 8 files (and which have so far encountered problems with DV) could benefit from this update.
Before starting, to find out if your device is able to correctly reproduce profile 8, use the test files that Dolby provides on THIS page
Happy testing!
Happy testing!
Interesting. What happens if we just discard the EL layer in this case? Do you think it is safe? I wonder if it is actually a profile 8 stream at all.yusesope wrote: Fri Oct 02, 2020 12:52 pm The problem is that this stream is present inside a UHD-BD (Spears & Munsil) and it is definitely not a FEL stream.
blenky
I'm testing this on my Zidoo z9X with the UHD of 1917. If I create the file as per instructions using Mp4muxer (by using Tsmuxer it only plays in HDR10) the resultant video file plays in DV. However if I then use tsmuxer to add that file and the audio stream from 1917 the output only plays in HDR10.ghostshadow wrote: Fri Oct 02, 2020 9:55 amHello, you can use TsMuxerblenky wrote: Fri Oct 02, 2020 12:32 am Excuse a newbie question! Do I understand correctly that the instruction in post 176 are to create the DV video file only. This would then need to be muxed with an audio track? If so what method should be used? Thanks
What am doing wrong?
Screen shot of tsmuxer attached and media info on resultant file
General
Complete name : D:\Newsbin\dv\1917_mp4.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 71.8 GiB
Duration : 1 h 58 min
Overall bit rate mode : Variable
Overall bit rate : 86.4 Mb/s
Maximum Overall bit rate : 35.5 Mb/s
Video
Menu ID : 1 (0x1)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Codec ID : 36
Bit rate : 82.5 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.415
Stream size : 68.6 GiB (95%)
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light Level : 168 cd/m2
Audio
Menu ID : 1 (0x1)
Format : AC-3 MLP FBA 16-ch
Format/Info : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Muxing mode : Stream extension
Codec ID : 131
Bit rate mode : Variable
Bit rate : 448 kb/s
Maximum bit rate : 7 158 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Delay relative to video : -2 s 836 ms
Stream size : 381 MiB (1%)
Language : English
Service kind : Complete Main
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Language : English
ghostshadow
essaye de faire un iso avec TsMuxer et apres avec MakeMKV 1.15.3 tu fais un mkv et tu test sur ton zidoo z9x
try to do an iso with TsMuxer and after with MakeMKV 1.15.3 you do an mkv and you test on your zidoo z9x
ghostshadow
Wahoo you're a yusesope chef I'm testing this on Sundayyusesope wrote: Fri Oct 02, 2020 1:00 pm Another weekend is about to begin so you have a little time to try "the things" I write![]()
Happy testing!
Tomas
Hi, if you want to do .TS to play DV you have to have a modified TS muxer. If you want, I can throw it at you. Otherwise, I did an ISO Blu-ray and then made an mkv in makeMKV and I played DV on Zidoo z9x.blenky wrote: Fri Oct 02, 2020 1:27 pmI'm testing this on my Zidoo z9X with the UHD of 1917. If I create the file as per instructions using Mp4muxer (by using Tsmuxer it only plays in HDR10) the resultant video file plays in DV. However if I then use tsmuxer to add that file and the audio stream from 1917 the output only plays in HDR10.ghostshadow wrote: Fri Oct 02, 2020 9:55 amHello, you can use TsMuxerblenky wrote: Fri Oct 02, 2020 12:32 am Excuse a newbie question! Do I understand correctly that the instruction in post 176 are to create the DV video file only. This would then need to be muxed with an audio track? If so what method should be used? Thanks
General ID : 1 (0x1) Complete name : D:\Newsbin\dv\1917_mp4.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 71.8 GiB Duration : 1 h 58 min Overall bit rate mode : Variable Overall bit rate : 86.4 Mb/s Maximum Overall bit rate : 35.5 Mb/s Video ID : 4117 (0x1015) Menu ID : 1 (0x1) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible Codec ID : 36 Duration : 1 h 58 min Bit rate : 82.5 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.415 Stream size : 68.6 GiB (95%) Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 1000 cd/m2 Maximum Frame-Average Light Level : 168 cd/m2 Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 MLP FBA 16-ch Format/Info : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation Commercial name : Dolby TrueHD with Dolby Atmos Muxing mode : Stream extension Codec ID : 131 Duration : 1 h 58 min Bit rate mode : Variable Bit rate : 448 kb/s Maximum bit rate : 7 158 kb/s Channel(s) : 8 channels Channel layout : L R C LFE Ls Rs Lb Rb Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : -2 s 836 ms Stream size : 381 MiB (1%) Language : English Service kind : Complete Main Number of dynamic objects : 11 Bed channel count : 1 channel Bed channel configuration : LFE Text ID : 4768 (0x12A0) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Language : English
blenky
Thanks for that. I'll give that a go. Will try with profile 7 and 8.ghostshadow wrote: Fri Oct 02, 2020 2:24 pm essaye de faire un iso avec TsMuxer et apres avec MakeMKV 1.15.3 tu fais un mkv et tu test sur ton zidoo z9x
