Tomas
Post by Tomas » Thu Oct 01, 2020 5:39 pm
yusesope wrote: Thu Oct 01, 2020 8:42 am
Tomas wrote: Wed Sep 30, 2020 9:20 pm I did everything according to the FEE procedure at MEL. The resulting film according to BD info is still FEE. I can ask where I made a mistake.
If you followed all the steps correctly, don't worry about what BDInfo says.
My files are special ... they are magical!
You were right, everything works as it should. Thank you very much
Tomas
Post by Tomas » Thu Oct 01, 2020 5:40 pm
ragico
Post by ragico » Thu Oct 01, 2020 7:47 pm
The mkv of Doctor Sleep an The Shining (MEL original) do not play in firestick 4k, sound and black screen. Anyone with the same problem?
Post by mike admin » Thu Oct 01, 2020 8:58 pm
yusesope wrote: Wed Sep 30, 2020 9:09 pm
mike admin wrote: Wed Sep 30, 2020 6:13 pm This is FEL file, not MEL. The 1.15.3 recognizes it as such :)
I'm sorry mike but my only neuron is telling me it's a MEL!
I'm happy to be proven wrong!
Ok, I stand corrected - this is not FEL, but I don't know how to call this stream! I was under impression that disable_resid flag means "disable residue" which means "disable EL". I was under impression that this flag is only present on single-layer streams. If I am right, then this is not a MEL or FEL - this is "DEL" - "discard fake EL". Where did this source media came from?
blenky
Post by blenky » Fri Oct 02, 2020 12:32 am
Excuse a newbie question! Do I understand correctly that the instruction in post 176 are to create the DV video file only. This would then need to be muxed with an audio track? If so what method should be used? Thanks
kws53
Post by kws53 » Fri Oct 02, 2020 3:43 am
Where can I get BDInfo 0.7.5.6? DVDFab claims it is a FREE utility, but it is nowhere to be seen...
ghostshadow
Post by ghostshadow » Fri Oct 02, 2020 9:55 am
blenky wrote: Fri Oct 02, 2020 12:32 am Excuse a newbie question! Do I understand correctly that the instruction in post 176 are to create the DV video file only. This would then need to be muxed with an audio track? If so what method should be used? Thanks
Hello, you can use TsMuxer
yusesope
Post by yusesope » Fri Oct 02, 2020 12:52 pm
mike admin wrote: Thu Oct 01, 2020 8:58 pm I was under impression that this flag is only present on single-layer streams.
I agree with you!
The problem is that this stream is present inside a UHD-BD (Spears & Munsil) and it is definitely not a FEL stream.
It only remains to recognize it as MEL (el_spatial_resampling_filter_flag is still true).
yusesope
Post by yusesope » Fri Oct 02, 2020 1:00 pm
Another weekend is about to begin so you have a little time to try "the things" I write :lol: :lol: :lol: !
This time it's up to profile 8.1!
I have updated the POST we refer to during this testing phase.
Find all the instructions there.
This update "fixes" what was previously called "-mode 2".
The new lines of code should allow you to convert a UHD-BD (both MEL and FEL) in a file Single Track Single Layer profile 8.1 (STSL dvhe.08.0x, BL + RPU, HDR10 compatible).
All devices, especially TVs with proprietary OS, capable of playing profile 8 files (and which have so far encountered problems with DV) could benefit from this update.
Before starting, to find out if your device is able to correctly reproduce profile 8, use the test files that Dolby provides on THIS page
Happy testing!
Post by mike admin » Fri Oct 02, 2020 1:26 pm
yusesope wrote: Fri Oct 02, 2020 12:52 pm The problem is that this stream is present inside a UHD-BD (Spears & Munsil) and it is definitely not a FEL stream.
Interesting. What happens if we just discard the EL layer in this case? Do you think it is safe? I wonder if it is actually a profile 8 stream at all.
blenky
Post by blenky » Fri Oct 02, 2020 1:27 pm
ghostshadow wrote: Fri Oct 02, 2020 9:55 am
I'm testing this on my Zidoo z9X with the UHD of 1917. If I create the file as per instructions using Mp4muxer (by using Tsmuxer it only plays in HDR10) the resultant video file plays in DV. However if I then use tsmuxer to add that file and the audio stream from 1917 the output only plays in HDR10.
What am doing wrong?
Screen shot of tsmuxer attached and media info on resultant file
General
Complete name                            : D:\Newsbin\dv\1917_mp4.m2ts
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 71.8 GiB
Overall bit rate                         : 86.4 Mb/s
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Bit rate                                 : 82.5 Mb/s
Bits/(Pixel*Frame)                       : 0.415
Stream size                              : 68.6 GiB (95%)
Maximum Frame-Average Light Level        : 168 cd/m2
Audio
Format                                   : AC-3 MLP FBA 16-ch
Format/Info                              : Audio Coding 3 + Meridian Lossless Packing FBA with 16-channel presentation
Muxing mode                              : Stream extension
Codec ID                                 : 131
Maximum bit rate                         : 7 158 kb/s
Delay relative to video                  : -2 s 836 ms
Stream size                              : 381 MiB (1%)
Text
Format                                   : PGS
Codec ID                                 : 144
ghostshadow
Post by ghostshadow » Fri Oct 02, 2020 2:24 pm
essaye de faire un iso avec TsMuxer et apres avec MakeMKV 1.15.3 tu fais un mkv et tu test sur ton zidoo z9x
try to do an iso with TsMuxer and after with MakeMKV 1.15.3 you do an mkv and you test on your zidoo z9x
ghostshadow
Post by ghostshadow » Fri Oct 02, 2020 2:53 pm
yusesope wrote: Fri Oct 02, 2020 1:00 pm Another weekend is about to begin so you have a little time to try "the things" I write :lol: :lol: :lol: !
Happy testing!
Wahoo you're a yusesope chef I'm testing this on Sunday
Tomas
Post by Tomas » Fri Oct 02, 2020 3:09 pm
blenky wrote: Fri Oct 02, 2020 1:27 pm
General
Format                                   : BDAV
Video
Audio
Codec ID                                 : 131
Text
Format                                   : PGS
Codec ID                                 : 144
Hi, if you want to do .TS to play DV you have to have a modified TS muxer. If you want, I can throw it at you. Otherwise, I did an ISO Blu-ray and then made an mkv in makeMKV and I played DV on Zidoo z9x.
blenky
Post by blenky » Fri Oct 02, 2020 3:14 pm
ghostshadow wrote: Fri Oct 02, 2020 2:24 pm essaye de faire un iso avec TsMuxer et apres avec MakeMKV 1.15.3 tu fais un mkv et tu test sur ton zidoo z9x
Thanks for that. I'll give that a go. Will try with profile 7 and 8.
