Detective Conan: The Zero Enforcer
gotenks05
#1 Post by gotenks05 » Wed Sep 30, 2020 9:13 pm
Hey there everyone, this is my first post here, since I am kind of lost on what to do now, in spite of searching around a lot.
These days, I normally get stuff from iTunes, but there are times when I am forced to buy the thing on Blu Ray, which was most recently the Detective Conan (Case Closed) movie called The Zero Enforcer.
As usual, I load the BD into my external Blu Ray drive, whose model number is BD-RE BP50NB40, but the movie refuses to copy over, with a file that instead says, "This disc is only authorized for region A," and is smaller than the file would have been if it were the actual movie, denoted with a 03, instead of a 02.
I am currently running Windows 10 pro 64-bit, with the latest updates on the slow ring, and also updated MakeMKV in the hopes that it would fix things, which it did not.
After looking around, I figured out how to enable debug logging, which produces this:
Debug log started at Wed Sep 30 19:27:01 2020 , written by MakeMKV v1.15.2 win(x64-release)
001005:0000 MakeMKV v1.15.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\Bryce/MakeMKV_log.txt
SDF  v07b: HL-DT-ST_BD-RE_BP50NB40_1.00_211504221517_MD5G2KG5031
001011:0000 Using LibreDrive mode (v06.2 id=F1E492503DA6)
DEBUG: Code 2147483648 at @-Nuv]M)#h?#R!f1:29396621
DISCID=527D3B4A5BBDDEB02197CED3EFC062DB46798421
003307:0000 File 00005.mpls was added as title #0
003307:0000 File 00004.mpls was added as title #1
003025:0000 Title #00003.mpls has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00000.mpls was added as title #2
003307:0000 File 00013.m2ts was added as title #3
003025:0000 Title #00007.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 4 titles into directory file://C:/Video/Case Closed Movie 22 - Zero the Enforcer
AV sync issues in C:/Video/Case Closed Movie 22 - Zero the Enforcer/Case Closed Movie 22 - Zero the Enforcer_t00.mkv
AV sync in 1 at 0:00:15.140 (4.125ms) : short audio gap was removed, audio skew is -4.125ms
AV sync issues in C:/Video/Case Closed Movie 22 - Zero the Enforcer/Case Closed Movie 22 - Zero the Enforcer_t02.mkv
AV sync in 5 at #17 (0ms) : converting audio from 16bps to 24bps
001003:0020 DEBUG: Code 0 at <F;e`-8A<-u?T[9fqVF+:121263360
001003:0020 DEBUG: Code 5 at {jh$~Hd ?TZ>P#@H:121264165
001003:0020 DEBUG: Code 0 at mirI$m!:l!nb1uc0(p.,]:29400094
---- Failed C:/Video/Case Closed Movie 22 - Zero the Enforcer/Case Closed Movie 22 - Zero the Enforcer_t02.mkv
ch_0        7134722595000 0
ch_1        7135668540000 0
ch_2        7136749620000 0
ch_3        7137830700000 0
ch_4        7138866735000 0
ch_5        7139857725000 0
ch_6        7140668535000 0
ch_7        7141749615000 5
mt=0000026B3CBE9570 n=10
s=0 n=4 o=6064128
    0   4492 000000  7141614480000       45045000 6CD385CB 000000020930000000070601030A82408000000060419A555B029FB7FEDAA658000315CAB3FE0D5E5E05F7CEEA3B37EF2D221C4976594EBAB34D65A55ED28E13EED9B1E82FF59E7760A01011A38E7A7E6C959C52BF1FFCDE2B3A0F53966EAECDE59C6A1695A98CF95B49D0000003000003000089810000006441003FC9A555B0
    0   6492 000000  7141659525000       45045000 0AE87CFF 000000020930000000070601030B02408000000060419A765B029FB7FEDAA658000270F388237B16B4FAE14EEA3B37EF2D221C4976594EBAB34D65A55ED28E13EED9B1E82FF59E7760A01011A38E7A7E6C959C52BF1FFCDE2B3A0F53966EAECDE59C6A1695A98CF95B49D00000030000030000AF800000006441003FC9A765B0
    0   6644 000000  7141704570000       45045000 C00A160B 000000020930000000070601030B82408000000060419A975B029FB7FEDAA6580001E88C61FF06AF2F02FBE7751D9BF796910E24BB2CA75D59A6B2D2AF694709F76CD8F417FACF3BB0500808D1C73D3F364ACE295F8FFE6F159D07A9CB375766F2CE350B4AD4C67CADA4E800000300000300006D410000006441003FC9A975B0
    0  83862 000003  7141749615000       45045000 03632E04 0000000209100000002A67640029ACD900780227E5C05A808080A000007D200017701C0C0000EC82E0000E4E1D249803C60C65800000000768E9381ACF23C00000000906000595438000018000000005060601C480000000070601030C024080000041384188AE0DBFFEF5B2DF32CBB81C4CD8BE27627CB3C6BF8CF61B7F5850
s=1 n=1 o=30744336384
    1   3516 000001  7141605120000       11520000 63F9F3DD 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000003149498A520CC7318C74A52A52D6B5A9695314949884194A631CE74254A52D6B5AD4A5316941C85294C6319093A54A52D6C5A94A4AD6941C44294A639CE74A52A5A
s=2 n=1 o=30744336384
    2   2012 000001  7141605120000       11520000 CCD8D2E1 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000003149498A520CC7318C74A52A52D6B5A9695314949884194A631CE74254A52D6B5AD4A5316941C85294C6319093A54A52D6C5A94A4AD6941C44294A639CE74A52A5A
s=3 n=1 o=823296
    3   2528 000001  7141605120000       11520000 9A57915D 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000000000000000000000000000000000000004210842108421084210842108421084210B5AC6292A52909525494A9294A529420C5239AC5AD2952529525494A8E94A52931CC52B5AC62D6B5AD4B5AD4A5AD4A52
s=4 n=1 o=823296
    4   2012 000001  7141605120000       11520000 1102EAEC 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4000000000000000000000000000000000000000004210842108421084210842108421084210B5AC6292A52909525494A9294A529420C5239AC5AD2952529525494A8E94A52931CC52B5AC62D6B5AD4B5AD4A5AD4A52
s=5 n=0 o=0
s=6 n=1 o=30744336384
    6     30 000011  7141614480000       22522500 313A19BD 16000B078004381000980000000017000A010002BF003C0202007B800000
s=7 n=0 o=6856704
s=8 n=1 o=30744336384
    8     39 000011  7141614480000       22522500 C3CE95DA 16000B07800438100BC100000000170013020001F203C4039C00440102BF003C0202007B800000
s=9 n=0 o=6856704
mt=0000026B4FB18820 n=10
s=0 n=34 o=6064128
    0   3470 000000  7141839705000       45045000 36CC1242 000000020930000000070601030083408000000063419ADA7C994D2F6FFEDAA658009C3B51714369B098614D35BA619E84B020F39E7696F637922EB3BEB38B5D63C45AA82A07BC5A7F692F4366771A47BD3A3F678BAFEF03CA12B58194233D0F3886197EAD673AB1071A7FB693A00000030000030000057C0000006641003FC9
    0    549 000008  7141794660000       45045000 45F8ED74 000000020950000000070601030101408000000062019EF979DB00001B81AC1E198B285CBF25472D1F1E0D5E5E05F7CEEA3B37EDD887125D9653AEACD3186AF694709F76CD2A0F6D89D7968478369D64EF7E6BD787865B7AE95A183FADF670DD9BCADB027FA1367DCAD1960000030000030000030002270000006201003FC9EF
    0   4784 000000  7141929795000       45045000 A72FD94B 000000020930000000070601030183408000000060419AFC53076FFEDAA658007A23187FC1ABCBC0BEF9DD4766FDE5A443892ECB29D75669ACB4ABDA51C27DDB363D05FEB3CEEC1402023471CF4FCD92B38A57E3FF9BC56741EA72CDD5D9BCB38D42D2B5319F2B693A000003000003000003006D400000006541003FC9AFC530
    0   1039 000008  7141884750000       45045000 F140B6A9 000000020950000000070601030201408000000062019F1B39DB0000160C29245E759C2E5F92A3968F8F06AF2F02FBE7751D9BF6EC43892ECB29D756698C357B4A384FBB669507B6C4EBCB423C1B4EB277BF35EBC3C32DBD74AD0C1FD6FB386ECDE56D813FD09B3EE568CB00000300000300000300015F0000006901003FC9F1
    0   4065 000000  7141974840000       45045000 0189662C 000000020930000000070601030282408000000061419B1D5B029FB7FEDAA6580062B9567FC1ABCBC0BEF9DD4766FDE5A443892ECB29D75669ACB4ABDA51C27DDB363D05FEB3CEEC1402023471CF4FCD92B38A57E3FF9BC56741EA72CDD5D9BCB38D42D2B5319F2B693A0000030000030000030089810000006641003FC9B1D5
    0   3869 000000  7142019885000       45045000 436B0E7F 000000020930000000070601030302408000000061419B3E5B029FB7FEDAA658004E1E71046F62D69F5C29DD4766FDE5A443892ECB29D75669ACB4ABDA51C27DDB363D05FEB3CEEC1402023471CF4FCD92B38A57E3FF9BC56741EA72CDD5D9BCB38D42D2B5319F2B693A00000300000300000300AF800000006641003FC9B3E5
    0   4610 000000  7142064930000       45045000 A459422F 000000020930000000070601030382408000000061419B5F5B029FB7FEDAA658003D118C3FE0D5E5E05F7CEEA3B37EF2D221C4976594EBAB34D65A55ED28E13EED9B1E82FF59E7760A01011A38E7A7E6C959C52BF1FFCDE2B3A0F53966EAECDE59C6A1695A98CF95B49D000003000003000003006D400000006641003FC9B5F5
    0   5701 000000  7142109975000       45045000 31AFB85A 000000020930000000070601030402408000000061419B605B029FB7FEDAA65800315CAB3FE0D5E5E05F7CEEA3B37EF2D221C4976594EBAB34D65A55ED28E13EED9B1E82FF59E7760A01011A38E7A7E6C959C52BF1FFCDE2B3A0F53966EAECDE59C6A1695A98CF95B49D0000030000030000030089810000006741003FC9B605
    0   6066 000000  7142155020000       45045000 4EBC45B5 000000020930000000070601030482408000000061419B815B029FB7FEDAA65800270F388237B16B4FAE14EEA3B37EF2D221C4976594EBAB34D65A55ED28E13EED9B1E82FF59E7760A01011A38E7A7E6C959C52BF1FFCDE2B3A0F53966EAECDE59C6A1695A98CF95B49D00000300000300000300AF800000006741003FC9B815
    0   6726 000000  7142200065000       45045000 FF8D58FF 000000020930000000070601030502408000000060419BA25B029FB7FEDAA658001E88C61FF06AF2F02FBE7751D9BF796910E24BB2CA75D59A6B2D2AF694709F76CD8F417FACF3BB0500808D1C73D3F364ACE295F8FFE6F159D07A9CB375766F2CE350B4AD4C67CADA4E8000000300000300006D410000006741003FC9BA25B0
    0   7201 000000  7142245110000       45045000 43F48639 000000020930000000070601030582408000000060419BC35B029FB7FEDAA6580018AE559FF06AF2F02FBE7751D9BF796910E24BB2CA75D59A6B2D2AF694709F76CD8F417FACF3BB0500808D1C73D3F364ACE295F8FFE6F159D07A9CB375766F2CE350B4AD4C67CADA4E80000003000003000089800000006741003FC9BC35B0
    0   9642 000000  7142290155000       45045000 BD1CFCE1 000000020930000000070601030602408000000060419BE45B029FB7FEDAA6580013879C411BD8B5A7D70A7751D9BF796910E24BB2CA75D59A6B2D2AF694709F76CD8F417FACF3BB0500808D1C73D3F364ACE295F8FFE6F159D07A9CB375766F2CE350B4AD4C67CADA4E800000030000030000AF810000006741003FC9BE45B0
    0   4955 000000  7142335200000       45045000 071502D8 000000020930000000070601030682408000000060419A055B029FB7FEDAA658000F44630FF835797817DF3BA8ECDFBCB4887125D9653AEACD3596957B4A384FBB66C7A0BFD679DD828040468E39E9F9B256714AFC7FF378ACE83D4E59BABB379671A85A56A633E56D274000000300000300006D410000006741003FC9A055B0
    0   9666 000000  7142380245000       45045000 37205273 000000020930000000070601030702408000000060419A265B029FB7FEDAA658000C572ACFF835797817DF3BA8ECDFBCB4887125D9653AEACD3596957B4A384FBB66C7A0BFD679DD828040468E39E9F9B256714AFC7FF378ACE83D4E59BABB379671A85A56A633E56D2740000003000003000089810000006741003FC9A265B0
    0   6877 000000  7142425290000       45045000 80B15E42 000000020930000000070601030782408000000062419A475B029FB7FEDAA6580009C3CE208DEC5AD3EB853BA8ECDFBCB4887125D9653AEACD3596957B4A384FBB66C7A0BFD679DD828040468E39E9FA6B367DDC709B117ABEDBF37EF0E92C3AE19E9100CD3400AF84076D27400000030000030000AF810000006841003FC9A4
    0   6852 000000  7142470335000       45045000 F3B1D7FB 000000020930000000070601030802408000000060419A685B029FB7FEDAA6580007A23187FC1ABCBC0BEF9DD4766FDE5A443892ECB29D75669ACB4ABDA51C27DDB363D05FEB3CEEC1402023471CF4FCD92B38A57E3FF9BC56741EA72CDD5D9BCB38D42D2B5319F2B693A000000300000300006D400000006441003FC9A685B0
    0   8363 000000  7142560425000       45045000 3711418C 000000020930000000070601030883408000000060419A8A5B029FB7FEDAA65800062B9567FC1ABCBC0BEF9DD4766FDE5A443892ECB29D75669ACB4ABDA51C27DDB363D05FEB3CEEC1402023471CF4FCD92B38A57E3FF9BC56741EA72CDD5D9BCB38D42D2B5319F2B693A0000003000003000089800000006441003FC9A8A5B0
    0   2119 000008  7142515380000       45045000 43B8E061 000000020950000000070601030901408000000063019EA979DB00000301142F0E45E759C2E5F92A3968F8F06AF2F02FBE7751D9BF6EC43892ECB29D756698C357B4A384FBB669507B6C4EBCB423C1B4EB277BF35EBC3C32DBD74AD0C1FD6FB386ECDE56D813FD09B3EE568CB000000300000300000301B70000006501003FC9
    0   6323 000000  7142605470000       45045000 545687FA 000000020930000000070601030982408000000060419AAB5B029FB7FEDAA6580004E1E71046F62D69F5C29DD4766FDE5A443892ECB29D75669ACB4ABDA51C27DDB363D05FEB3CEEC1402023471CF4FCD92B38A57E3FF9BC56741EA72CDD5D9BCB38D42D2B5319F2B693A00000030000030000AF800000006441003FC9AAB5B0
    0  11298 000000  7142695560000       45045000 23BC4ADA 000000020930000000070601030A03408000000060419ACD5B029FB7FEDAA6580003D118C3FE0D5E5E05F7CEEA3B37EF2D221C4976594EBAB34D65A55ED28E13EED9B1E82FF59E7760A01011A38E7A7E6C959C52BF1FFCDE2B3A0F53966EAECDE59C6A1695A98CF95B49D000000300000300006D400000006441003FC9ACD5B0
    0   1951 000008  7142650515000       45045000 10F24201 000000020950000000070601030A81408000000063019EEC39DB00000300B0614922F3ACE172FC951CB47C7835797817DF3BA8ECDFB7621C4976594EBAB34C61ABDA51C27DDB34A83DB6275E5A11E0DA7593BDF9AF5E1E196DEBA56860FEB7D9C3766F2B6C09FE84D9F72B4658000003000003000003015F0000006501003FC9
    0   7883 000000  7142740605000       45045000 42803A3C 000000020930000000070601030B02408000000060419AEE5B029FB7FEDAA658000315CAB3FE0D5E5E05F7CEEA3B37EF2D221C4976594EBAB34D65A55ED28E13EED9B1E82FF59E7760A01011A38E7A7E6C959C52BF1FFCDE2B3A0F53966EAECDE59C6A1695A98CF95B49D0000003000003000089810000006441003FC9AEE5B0
    0   9564 000000  7142785650000       45045000 D49BF04E 000000020930000000070601030B82408000000060419B0F5B029FB7FEDAA658000270F388237B16B4FAE14EEA3B37EF2D221C4976594EBAB34D65A55ED28E13EED9B1E82FF59E7760A01011A38E7A7E6C959C52BF1FFCDE2B3A0F53966EAECDE59C6A1695A98CF95B49D00000030000030000AF810000006441003FC9B0F5B0
    0 105005 004001  7142830695000       45045000 DEA6E0FF 0000000209100000002A67640029ACD900780227E5C05A808080A000007D200017701C0C0000EC82E0000E4E1D249803C60C65800000000768E9381ACF23C00000000906000595438000018000000005060601C480000000070601030C024080000041384188CC0DBFFEF5B2DF32CBB81C4CD8BE27627CB3C6BF8CF61B7F5850
    0   8146 000000  7142920785000       45045000 EF8EADFE 000000020930000000070601030083408000000063419B527C994D2F6FFEDAA658009C3B51714369B098614D35BA619E84B020F39E7696F637922EB3BEB38B5D63C45AA82A07BC5A7F692F4366771A47BD3A3F678BAFEF03CA12B58194233D0F3886197EAD673AB1071A7FB693A00000030000030000057C0000006641003FC9
    0    725 000008  7142875740000       45045000 CFC8C11A 000000020950000000070601030101408000000062019F7179DB00001B81AC1E198B285CBF25472D1F1E0D5E5E05F7CEEA3B37EDD887125D9653AEACD3186AF694709F76CD2A0F6D89D7968478369D64EF7E6BD787865B7AE95A183FADF670DD9BCADB027FA1367DCAD1960000030000030000030002270000006201003FC9F7
    0   9393 000000  7142965830000       45045000 2938CABB 000000020930000000070601030182408000000060419B7353076FFEDAA658007A23187FC1ABCBC0BEF9DD4766FDE5A443892ECB29D75669ACB4ABDA51C27DDB363D05FEB3CEEC1402023471CF4FCD92B38A57E3FF9BC56741EA72CDD5D9BCB38D42D2B5319F2B693A000003000003000003006D400000006541003FC9B73530
    0  11818 000000  7143010875000       45045000 932510F3 000000020930000000070601030202408000000061419B945B029FB7FEDAA6580062B9567FC1ABCBC0BEF9DD4766FDE5A443892ECB29D75669ACB4ABDA51C27DDB363D05FEB3CEEC1402023471CF4FCD92B38A57E3FF9BC56741EA72CDD5D9BCB38D42D2B5319F2B693A0000030000030000030089800000006641003FC9B945
    0  17066 000000  7143055920000       45045000 62D4B355 000000020930000000070601030282408000000061419BB55B029FB7FEDAA658004E1E71046F62D69F5C29DD4766FDE5A443892ECB29D75669ACB4ABDA51C27DDB363D05FEB3CEEC1402023471CF4FCD92B38A57E3FF9BC56741EA72CDD5D9BCB38D42D2B5319F2B693A00000300000300000300AF810000006641003FC9BB55
    0   8513 000000  7143100965000       45045000 962E0E98 000000020930000000070601030302408000000061419BD65B029FB7FEDAA658003D118C3FE0D5E5E05F7CEEA3B37EF2D221C4976594EBAB34D65A55ED28E13EED9B1E82FF59E7760A01011A38E7A7E6C959C52BF1FFCDE2B3A0F53966EAECDE59C6A1695A98CF95B49D000003000003000003006D400000006641003FC9BD65
    0   4382 000000  7143146010000       45045000 D9E7CF03 000000020930000000070601030382408000000061419BF75B029FB7FEDAA65800315CAB3FE0D5E5E05F7CEEA3B37EF2D221C4976594EBAB34D65A55ED28E13EED9B1E82FF59E7760A01011A38E7A7E6C959C52BF1FFCDE2B3A0F53966EAECDE59C6A1695A98CF95B49D0000030000030000030089810000006741003FC9BF75
    0   8177 000000  7143191055000       45045000 61FE6CF6 000000020930000000070601030402408000000061419A185B029FB7FEDAA65800270F388237B16B4FAE14EEA3B37EF2D221C4976594EBAB34D65A55ED28E13EED9B1E82FF59E7760A01011A38E7A7E6C959C52BF1FFCDE2B3A0F53966EAECDE59C6A1695A98CF95B49D00000300000300000300AF810000006741003FC9A185
    0   6447 000000  7143236100000       45045000 F726CC8E 000000020930000000070601030482408000000060419A395B029FB7FEDAA658001E88C61FF06AF2F02FBE7751D9BF796910E24BB2CA75D59A6B2D2AF694709F76CD8F417FACF3BB0500808D1C73D3F364ACE295F8FFE6F159D07A9CB375766F2CE350B4AD4C67CADA4E8000000300000300006D400000006741003FC9A395B0
    0   7207 000000  7143281145000       45045000 BD26BA0B 000000020930000000070601030502408000000060419A5A5B029FB7FEDAA6580018AE559FF06AF2F02FBE7751D9BF796910E24BB2CA75D59A6B2D2AF694709F76CD8F417FACF3BB0500808D1C73D3F364ACE295F8FFE6F159D07A9CB375766F2CE350B4AD4C67CADA4E80000003000003000089810000006741003FC9A5A5B0
s=1 n=0 o=30744336384
s=2 n=0 o=30744336384
s=3 n=0 o=823296
s=4 n=0 o=823296
s=5 n=0 o=0
s=6 n=0 o=30744336384
s=7 n=0 o=6856704
s=8 n=0 o=30744336384
s=9 n=0 o=6856704
mt=0000026B3CBE29F0 n=10
s=0 n=1 o=6064128
    0   5293 000000  7143326190000       45045000 42B289E3 000000020930000000070601030582408000000060419A7B5B029FB7FEDAA6580013879C411BD8B5A7D70A7751D9BF796910E24BB2CA75D59A6B2D2AF694709F76CD8F417FACF3BB0500808D1C73D3F364ACE295F8FFE6F159D07A9CB375766F2CE350B4AD4C67CADA4E800000030000030000AF800000006741003FC9A7B5B0
    1   3528 006001  7141616640000       11520000 03D58A0B 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000000000000000000000000000000000000316949885294A531CE73A52A5AD6B5294A5314941CA4294A631CE94252A52D6B5294A4AD49394A5294A631CC84A52A52D6B52D6A52D4941C65294A631CE74254A5A
    2   2012 006001  7141616640000       11520000 C1E6D0BA 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000000000000000000000000000000000000000316949885294A531CE73A52A5AD6B5294A5314941CA4294A631CE94252A52D6B5294A4AD49394A5294A631CC84A52A52D6B52D6A52D4941C65294A631CE74254A5A
s=3 n=50 o=823296
    3   2080 006001  7140668535000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140680055000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140691575000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140703095000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140714615000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140726135000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140737655000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140749175000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140760695000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140772215000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140783735000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140795255000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140806775000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140818295000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140829815000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140841335000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140852855000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140864375000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140875895000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140887415000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140898935000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140910455000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140921975000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140933495000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140945015000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140956535000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140968055000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140979575000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7140991095000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7141002615000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7141014135000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7141025655000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7141037175000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7141048695000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7141060215000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7141071735000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7141083255000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7141094775000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7141106295000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7141117815000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7141129335000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7141140855000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7141152375000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7141163895000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7141175415000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7141186935000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7141198455000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7141209975000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7141221495000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    3   2080 006001  7141233015000       11520000 6C3E6591 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
s=4 n=50 o=823296
    4   2012 006001  7140668535000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140680055000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140691575000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140703095000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140714615000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140726135000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140737655000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140749175000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140760695000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140772215000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140783735000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140795255000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140806775000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140818295000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140829815000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140841335000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140852855000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140864375000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140875895000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140887415000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140898935000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140910455000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140921975000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140933495000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140945015000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140956535000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140968055000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140979575000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7140991095000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7141002615000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7141014135000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7141025655000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7141037175000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7141048695000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7141060215000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7141071735000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7141083255000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7141094775000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7141106295000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7141117815000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7141129335000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7141140855000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7141152375000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7141163895000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7141175415000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7141186935000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7141198455000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7141209975000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7141221495000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
    4   2012 006001  7141233015000       11520000 C539CFFD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C630108421084210842108421084210842108421084210842108421084210842108421084210842108421084210842108
s=5 n=7 o=0
    5   1440 004001  7141608000000        5400000 553D8BD9 FFFFFFFFFFFF000000000000000000000000010000010000000000000000FFFFFF000000000000000000FFFFFF000000000000010000000000010000000000000000000000000000010000010000010000010000000000010000000000000000010000000000000000FFFFFF000000000000010000010000FFFFFF0000000000
    5   1440 000001  7140668535000        5400000 AA7797A6 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
    5   1440 000001  7140673935000        5400000 AA7797A6 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
    5   1440 000001  7140679335000        5400000 AA7797A6 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
    5   1440 000001  7140684735000        5400000 AA7797A6 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
    5   1440 000001  7140690135000        5400000 AA7797A6 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
    5   1440 000001  7140695535000        5400000 AA7797A6 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
s=7 n=0 o=6856704
s=9 n=0 o=6856704
004047:0010 AV sync issue in stream 3 at 1:50:11.730 : audio changes from 24bps to 16bps, you won't be able to convert this track to any other format later, please use a conversion profile with audio transcoding
005003:0000 Failed to save title 2 to file C:/Video/Case Closed Movie 22 - Zero the Enforcer/Case Closed Movie 22 - Zero the Enforcer_t02.mkv
005004:0080 3 titles saved, 1 failed
005037:0204 Copy complete. 3 titles saved, 1 failed.
Application exited at Wed Sep 30 19:56:29 2020
After this, log message, I tried using the FLAC profile, after enabling expert mode, but that failed.
Sadly, due to character limit, I cannot post the log of that.
Is there anything else that I can do or is there something wrong in the program?
Re: Detective Conan: The Zero Enforcer
#2 Post by Woodstock » Thu Oct 01, 2020 1:34 am
Which profile you use should not affect this, as the issue is a disk read error.
Have you cleaned the disk? This disk is "fresh off the presses", but it is still possible it is contaminated. It is also possible it was pressed poorly, but I'd go for contamination first.
gotenks05
#3 Post by gotenks05 » Thu Oct 01, 2020 6:07 am
No, I did not do that.
Currently, I am not at home base anymore, due to real life circumstances, so I am not too sure what I have on hand, or where things are, especially because these guys here go for torrents, rather than legal purchases.
I did try looking at the disc though and it looked fine, but that does make sense that something like that could have occurred during the pressing process. I'll try try and see if I there is something that can be used tomorrow.
gotenks05
#4 Post by gotenks05 » Thu Oct 01, 2020 3:23 pm
Alright, this is a little weird now.
I did manage to find some paper towels in plain sight today and tried cleaning the disc, but when I went to try the disc in MakeMKV, the software was no longer no activated, but seeing as cleaning the disc was more important, I told it to go through with the trial (although it is a pain to reenter my key), and here is what the debug log says:
Debug log started at Thu Oct 01 14:43:29 2020 , written by MakeMKV v1.15.2 win(x64-release)
005053:0308 This functionality is shareware. You may evaluate it for 30 days after what you would need to purchase an activation key if you like the functionality. Do you want to start evaluation period now?
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
001003:0020 DEBUG: Code 233 at fWEyzhBg3D0Nu8A1NpANIm0B:0
001003:0020 DEBUG: Code 233 at j8DBcu/PBD9rJ759iIh3XWAP:0
001003:0020 DEBUG: Code 233 at OeckFu8kN0BbaG1lpo1tA9bD:0
001003:0020 DEBUG: Code 233 at QufBk8nTZuUHXTyPAP/rM4s0:0
001003:0020 DEBUG: Code 233 at FmBtDJPdBuDchmren4aFyoW9:0
001003:0020 DEBUG: Code 233 at whJgbu0wHplDR9u3BueU2i8i:0
001003:0020 DEBUG: Code 233 at HKVxaDEs3C5/8yLJYiNSLy2J:0
001003:0020 DEBUG: Code 233 at ya9/ndY5t/921i6gLfEIOB+W:0
001003:0020 DEBUG: Code 233 at QBnUzfs880tI+E25XfLYYrsl:0
001003:0020 DEBUG: Code 233 at aFG/pvm/O8ohnHM+ULEaapHu:0
mt=000002A8FC79BF80 n=10
s=0 n=4 o=6064128
s=3 n=1 o=823296
s=4 n=1 o=823296
s=5 n=0 o=0
s=7 n=0 o=6856704
s=9 n=0 o=6856704
mt=000002A88D217700 n=10
s=0 n=34 o=6064128
s=3 n=0 o=823296
s=4 n=0 o=823296
s=5 n=0 o=0
s=7 n=0 o=6856704
s=9 n=0 o=6856704
mt=000002A8FC799AD0 n=10
s=0 n=1 o=6064128
s=3 n=50 o=823296
s=4 n=50 o=823296
s=5 n=7 o=0
s=7 n=0 o=6856704
s=9 n=0 o=6856704
Application exited at Thu Oct 01 15:12:34 2020
So far, there was no change, although I was able to get the movie onto my computer using DVDFab, which I was not particularly thrilled about.
#5 Post by Woodstock » Thu Oct 01, 2020 5:22 pm
Mike Admin is the man with the magic decoder ring for the debug codes. Hopefully, he'll see this and respond.
As far as paper towels... They're like sandpaper on disks. Soft cotton (think clean T-shirt) or microfiber cloths should be the go-to. I've been using Zeiss spray Lens Cleaner (comes with a microfiber cloth) recently, when a disk is contaminated enough to need cleaning.
Sometimes the only way to see the contamination is to wipe PART of the disk, and compare the clean/not clean sections. I've tried to get pictures of this, but the camera keeps focusing on what the disk is reflecting, so the difference disappears.
