{SOLVED}<blushes> MakeMKV not producing an MKV file
dcbdbis
#1 Post by dcbdbis » Tue Dec 21, 2010 4:10 am
Downloaded the latest 1.6.3 for linux. Built it followng the wiki. No issues, no errors.
I have received a set of Blu-Ray discs as a gift. Linux is my only OS. MakeMKV did indeed copy all to the HDD and I have a bunch of m2ts files that are indeed playable. But I cannot find in my preferences, nor on my screen, any option to specify an MKV filename to output to.
So I DO have the raw data, but how do I, using this tool, create an MKV file?
Am I missing some component? System, AMD64, Ubuntu Meerkat.
Sincerely and respectfully,
Dave...
BitJam2
Re: MakeMKV not producing an MKV file
#2 Post by BitJam2 » Tue Dec 21, 2010 10:29 pm
When I choose "Save Selected Files" (after selecting "Open Blu-ray disc"), MakeMKV generates a .mkv file for each selected title on the disc. These are named something like title01.mkv, title02.mkv, etc.
dcbdbis
Re: {SOLVED}<blushes> MakeMKV not producing an MKV file
#3 Post by dcbdbis » Tue Dec 21, 2010 11:29 pm
I am an idiot. <blushes>
It sucks getting old.
I was not "Opening the disc" first. I was simply putting the disc in, and when you do that the only menu item active is "Backup disc".
Once I actually Opened the disc, I was able to do exactly as you described.
THANK YOU!
Dave
BitJam2
#4 Post by BitJam2 » Wed Dec 22, 2010 1:18 am
I respectfully disagree. You are not an idiot. The UI is confusing. I remember feeling a similar frustration the first time I tried to use it. It is not clear that you have to hit the giant icon below in order to activate the rest of the toolbar icons. I suspect we Linux users have a more difficult time with this UI than Windows users but I'm not sure exactly why.
