UHD 2001: A Space Odyssey Error
GeorgePeck
#1 Post by GeorgePeck » Wed Sep 30, 2020 4:23 pm
I've looked carefully at all previous posts about this title. I don't see anything I'm doing wrong. I've sent in the debug file 5 days ago. This is an Amazon purchase. Every other disc i purchased works fine. Is it just a new key and I need to be patient, or am I missing something?
OS device name: /dev/rdisk3
Product: BD-RE BU40N
Revision: 1.00
Serial number: MZZJ3TE5335
Firmware date: 2116-12-20 15:28
Highest AACS version: 72
Firmware version: 1.00
Disc Information
Label: 2001_ A Space Odyssey
Timestamp: 2018-11-01 13:37:34
Data capacity: 80.29 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
MakeMKV v1.15.2 darwin(x64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE BU40N 1.00d" opened in OS access mode.
Using LibreDrive mode (v06.2 id=64754CF46FCA)
Saved AACS dump file as /Users/gpeck/.MAKEMKV/MKB20_v66_2001-_A_Space_Odyssey_81ED.tgz
Re: UHD 2001: A Space Odyssey Error
#2 Post by shawnc22 » Wed Sep 30, 2020 8:11 pm
It's likely a new print with a new key. If you've sent in the dump already, then unfortunately all you can do at this point is wait.
#3 Post by dcoke22 » Wed Sep 30, 2020 9:30 pm
Is there a way to tell if the OP's disc has a new key? I didn't have any trouble with my copy.
@GeorgePeck … MakeMKV will download keys as needed assuming you've got that preference turned on (it is on by default). I assume you have that enabled?
preserve
#4 Post by preserve » Thu Oct 01, 2020 7:35 am
^ Not a new key then, but perhaps an alternate one or a different region.
Using: ASUS BW-16D1HT 3.00
GeorgePeck
#5 Post by GeorgePeck » Thu Oct 01, 2020 2:43 pm
New key downloaded and title backed up! (with difficulty, however -- I finally had to back it up and then extract MKV from the backup).
But, the new key was obtained.
