Failing on backup
ItsMyLife
Failing on backup
#1 Post by ItsMyLife » Wed Sep 30, 2020 3:31 pm
I have two machines, my primary Windows 10 was recently rebuilt after a hard drive failure. When I try to do a backup it fails with a fatal error not long after it says "backing up folder to:". When I go to my secondary Windows 10 machine, I can rip the backup without issue. Here's what I'm getting on the bad machine in the logs:
Debug log started at Wed Sep 30 15:17:02 2020 , written by MakeMKV v1.15.2 win(x64-release)
001005:0000 MakeMKV v1.15.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\gratn/MakeMKV_log.txt
WinCdArb=v1.0.0_tiny win(x64-release)
003338:0000 Downloading latest SDF to D:/ ...
SDF v07b: HL-DT-ST_BD-RE__WH14NS40_1.03_211711211658_K9PHCP94535
DEBUG: Code 2317353400 at ovQ@3;YE,qiWU6Q\E:121264418
DEBUG: Code 0 at ovQ@3;YE,qiWU6Q\E:213132928
DEBUG: Code 1 at ovQ@3;YE,qiWU6Q\E:213132928
DEBUG: Code 2 at ovQ@3;YE,qiWU6Q\E:213132928
DEBUG: Code 3 at ovQ@3;YE,qiWU6Q\E:213132928
DEBUG: Code 4 at ovQ@3;YE,qiWU6Q\E:213132928
DEBUG: Code 5 at ovQ@3;YE,qiWU6Q\E:213132928
DEBUG: Code 2317353400 at ovQ@3;YE,qiWU6Q\E:213132974
DEBUG: Code 0 at SnjLlET?7*kAC=V3:121269570
005072:0000 Backing up disc into folder "file://D:/VS330"
DAFD=PAAAADAAAAEABDQkEFwECAQ==
DCE=oGj3P6pM7ATzMGrCvB5CqrxnYsZZh96fCVYZ1ZQHPUMKJXXJGfBsrv13SEc5F4BqxuJqFajkMlwN7PmVLCGHSz6NWjeKZ4o0aRjRXB7P1aBnTiNfOJGuao8j0offohZf+FCCaJ+X142muWDNcyRCawRE5aTe9QLnmw==
DCE=kqkeYUt0ewZoQWZpLEa75Q8uFSG7kNhWJOUee5c+LWEx5WsA502Ur8QXLLyHGVBvPrU9MUij8SeA8Whqdf+NBqQJwBNWIhtC9IfZQlFfpyzDqB4pK2JNqXdkMEFPF+TjI3Mai+BY7PoCONEnI6FYoLHL8nNp7L7ROw==
Re: Failing on backup
#2 Post by dcoke22 » Wed Sep 30, 2020 4:07 pm
Are the optical drives different in the two machines?
ItsMyLife
#3 Post by ItsMyLife » Wed Sep 30, 2020 8:52 pm
Both LGs but different models.
