Will This UHD Drive Work For Ripping 4K Disks
smush
Hi I've seen a list of UHD friendly drives and this one here is mentioned https://www.ballicom.co.uk/lg-bh16ns40- ... H0QAvD_BwE however the advice seems to be to look for SVC Code NS50 how do I check that before buying? Is the drive I linked to NS40? I'm basing that off the model number being BH16NS40
smush
Re: Will This UHD Drive Work For Ripping 4K Disks
anyone that could help please? Thanks
A model number search says this is a 2015 drive, so it is unlikely to support UHD.
It also has a bad reputation for failure.
