You're welcome!!!! Enjoy!duss909 wrote: Sun Sep 27, 2020 8:10 pm Thanks for creating this easy-to-use flashing tool, MartyMcNuts.
Sim sala bim - and my Asus BW-16D1HT has changed firmware.
You have - for what it's worth - forever my utmost gratitude.
Re: SDFtool Flasher
rayians
Re: SDFtool Flasher
Correction on my previous post. I definitely have NET framework 4.8, based on the value in regedit. So I do have MakeMKV and proper NET framework and I am still get the "Unhandled exception has occurred in your application" error. As stated before, if I hit continue the flasher will open, but it will not recognize any optical drives. I have a drive already installed and am looking to flash a WH16NS40 with 1.05.
MartyMcNuts wrote: Tue Sep 29, 2020 1:29 amNot sure what to say here.....rayians wrote: Mon Sep 28, 2020 4:31 pm Very strange situation with my PC. I checked the .NET framework version using the cmd prompt and it shows up as 4.0.0. I tried to install 4.7.2 and it would not allow me to because it says I have 4.7.2 or later already installed.
You could try using the modified ASUS flasher, as long as your drive does not have an encrypted firmware on it.
Re: SDFtool Flasher
Do you have the latest version of MakeMKV installed? It's needed as it contains sdftool.exe, which is needed for this flasher to work properly.rayians wrote: Wed Sep 30, 2020 12:57 am Correction on my previous post. I definitely have NET framework 4.8, based on the value in regedit. So I do have MakeMKV and proper NET framework and I am still get the "Unhandled exception has occurred in your application" error. As stated before, if I hit continue the flasher will open, but it will not recognize any optical drives. I have a drive already installed and am looking to flash a WH16NS40 with 1.05.
williamw38
Re: SDFtool Flasher
HL-DT-ST-BD-RE_BU50N-1.00-NM00100-211711211006.bin, PLEASE someone send me this file, my drive does not ready any bluray i just need to flash firmware again but i cound not find it anywhere
aloha
Re: SDFtool Flasher
Hello:
Check this post https://www.makemkv.com/forum/viewtopic ... 19&t=19113
then get the ZIP file (mk-firmware-pack-20200720.zip). Open the ZIP file and start tunneling down to BU50N. Violà!
Regards,
A
Regards,
A
rayians
Re: SDFtool Flasher
You've done it one again Marty!! I can never thank you enough!!!
NormanC
Re: SDFtool Flasher
Hey
before I order a drive, I just want to make sure I understand correctly:
Can I use the SDFtool Flasher in Windows 10 64bit without changing ACHI to IDE in BIOS, or would I still needto load a 32bit windowsand swap to IDE in BIOS?
Regards
Regards
Re: SDFtool Flasher
Yes you can. None of that 32 bit and bios changes crap is needed.NormanC wrote: Tue Oct 06, 2020 4:16 pm Hey
Regards
williamw38
Re: SDFtool Flasher
did not work, i want original firmware not patched one , i need to burn bluray discs, i dont have any uhd disc
Re: SDFtool Flasher
If you want original firmware just don't flash an MK firmware flash a DE but it should have no effect on the burning ability either waywilliamw38 wrote: Sat Oct 10, 2020 11:27 pm did not work, i want original firmware not patched one , i need to burn bluray discs, i dont have any uhd disc
williamw38
Re: SDFtool Flasher
Where could i find DE firmware?, the zip file i downloads only hás mk firmware
Re: SDFtool Flasher
Here you go. Freshly extracted from the BU50N installer...williamw38 wrote: Mon Oct 12, 2020 7:39 am Where could i find DE firmware?, the zip file i downloads only hás mk firmware
williamw38
Re: SDFtool Flasher
this is not the firmware that cames with my drive, my drive cames with bw50 one, so do you have bw50 one?MartyMcNuts wrote: Mon Oct 12, 2020 9:57 amHere you go. Freshly extracted from the BU50N installer...williamw38 wrote: Mon Oct 12, 2020 7:39 am Where could i find DE firmware?, the zip file i downloads only hás mk firmware
DE_LG_BU50N_1.00.bin.zip
williamw38
Re: SDFtool Flasher
mine came with this one but i cant find it anywhereMartyMcNuts wrote: Mon Oct 12, 2020 9:57 amHere you go. Freshly extracted from the BU50N installer...williamw38 wrote: Mon Oct 12, 2020 7:39 am Where could i find DE firmware?, the zip file i downloads only hás mk firmware
Manufacturer: hp HLDS
Product: BDRE BU50N
Revision: BW50
Serial number: KZEH9KA5649
Firmware date: 2116-12-22 10:52
Bus encryption flags: 1F
Highest AACS version: 23
Firmware version: 0.BW50P
