yusesope
#3091 Post by yusesope » Sun Sep 27, 2020 9:12 am
PapitaHD wrote: Sat Sep 26, 2020 12:55 pm I checked all of them and only Saving Private Ryan flickers.
It is a good sign :D !
Thanks for the files!
RESET_9999 wrote: Sat Sep 26, 2020 3:46 pm Because I have a another DV TV with an appleTV in another room.
I see. Profile 5 only? No profile 8?
RESET_9999 wrote: Sat Sep 26, 2020 3:46 pm But i do get that in order to obtain a new/proper profile 5 file, encoding is required.
I think so too. Also because all the examples you mentioned occur during the decoding phase, using the previously encoded information.
shawnc22 wrote: Sat Sep 26, 2020 4:46 pm this is a more sophisticated version of your previous -mode 2 conversion?
The concept of "-mode 2" should remain associated with those profiles (5/8) in which the EL is completely absent (and the RPUs have a different structure). In this case I'm trying to mimic the behavior of a MEL file.
shawnc22 wrote: Sat Sep 26, 2020 4:46 pm When converting to MEL, am I correct to understand that your tool is not actually converting the base layer to 4000 nits with information from the EL, but instead modifying the RPU so that it can tell the decoder later during playback that no extra picture information exists on the EL, thus treating the entire file as MEL?
During decoding, the image generated by the data present in EL represents a residue (difference) of the original video content compared to the image obtained by processing the data present in BL.
EL is a 10-bit video bitstream that carries the residual between the mezzanine source and the base layer and the dynamic metadata for Dolby Vision.
By modifying the RPU the idea is to tell the decoder that the residual signal is equal to zero and that it should not bother to "read" the content.
The rest of the information, both static (eg, MaxFALL and MaxCLL) and dynamic (eg, min, max and avg luminance of each shot) remain unchanged.
By giving up the process of decoding the data in EL, I think it is normal that it is no longer possible to generate the 12bit signal as it was mastered by the creators (using monitors up to 10000 nits).
Keep also in mind that current consumer displays rarely exceed 2000 nits (LCD). OLEDs peak at 600-700 nits, and few home projectors are lucky enough to hit 150 nits. When the signal exceeds the capability of the TV, tone mapping is activated by reducing the luminance as the signal approaches the clipping point of the display (following a Perceptual Quantizer (PQ) curve, remaps luminance from the source values to the lower values the display can support)
Decidueye
#3092 Post by Decidueye » Sun Sep 27, 2020 9:52 am
Hello everyone first post here complete newbie. I wanted to try if Dolby Vision playback with Mission Impossible movies is possible with my LG C9
First tried with Ghost Protocol. I followed the instructions on the first post and double checked, the new mp4 is successfully created but it doesn't work. The TV cannot read the file and says it is not supported.
Is there something I did incorrectly or is it because of the file or my TV?
Tomas
#3093 Post by Tomas » Sun Sep 27, 2020 5:39 pm
PapitaHD wrote: Sat Sep 26, 2020 12:55 pm Gladiator & Kick-Ass: https://we.tl/t-eDu4zjnQj0
Apocalypse Now: https://we.tl/t-SJaD5a4ExL
Transformers 4: https://we.tl/t-z6Oos2hHxy
Saving Private Ryan: https://we.tl/t-IgV2cbcSuY
Everything played perfectly. May I ask how did you convert from FEL to MEL?
thank you very much
Tomas
#3094 Post by Tomas » Sun Sep 27, 2020 7:40 pm
yusesope wrote: Thu Sep 17, 2020 5:54 pm
quietvoid wrote: Thu Sep 17, 2020 4:19 pm Just tried this and it works on the FireTV Stick 4K...On archlinux...And it plays in Dolby Vision with ExoPlayer. :)
It always warms the heart to see "archlinux" written somewhere :D . Thanks for your feedback.
pitrako wrote: Thu Sep 17, 2020 5:17 pm I need some .dll or something? MUX.bat works but MUX_AND_CONVERT_TO_MEL.bat doesn't work, It shows the error I posted above.
PapitaHD wrote: Thu Sep 17, 2020 5:31 pm Same error for me. I'm trying to convert/remux Gemini Man from a full UHD BluRay backup. Officially it's a FEL title, although it has about the lowest bitrare a FEL can have.
Later I'll try Saving Private Ryan.
Yes you are right. Your Windows needs THESE libraries (unpack the archive and place the two dll files where there are the files MUX.bat, DEMUX.bat, etc ...). It's not an elegant solution but it should at least work for these days of testing.
Let me know!
jcdr428 wrote: Thu Sep 17, 2020 5:12 pm Hi @yusesope, so you need tsMuxer to register profile 6 as profile 4 to be read by ExoPlayer, is this correct?
The files that are created by this latest version have as VUI:
0,9,16,9,2 for the Base layer
0,9,16,9,2 for the Enhancement layer.
The correct profile should therefore be 7.
Now I don't remember well but it seems to me that TsMuxeR currently generates files with profile 6 (but, I repeat myself, I could be wrong). If my tool proves to work, in my opinion, we should try to mark the ts files with profile 7 (and not 6).
shawnc22 wrote: Thu Sep 17, 2020 5:39 pm I think yusecope is suggesting that what tsmuxer is currently registering as profile 6 should go back to being registered as profile 7
Yep, Exactly!
unfortunately the link does not work :(
DaMacFunkin
#3095 Post by DaMacFunkin » Mon Sep 28, 2020 6:08 am
Decidueye wrote: Sun Sep 27, 2020 9:52 am Hello everyone first post here complete newbie. I wanted to try if Dolby Vision playback with Mission Impossible movies is possible with my LG C9
What audio file did you create for your mp4?
Your LG won’t play an mp4 if the audio is True-HD.
ktibor69
#3096 Post by ktibor69 » Mon Sep 28, 2020 7:26 am
Is there a way to convert dvhe.07.06, EL+RPU.mp4 file to Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU or dvhe.05.06, BL+RPU profiles?
Unfortunately my LG OLED TV plays the dvhe.07.06, EL+RPU.mp4 file in "Green screen":
ktibor69
#3097 Post by ktibor69 » Mon Sep 28, 2020 7:29 am
DaMacFunkin wrote: Mon Sep 28, 2020 6:08 am
Try to set the True-HD audio track to the second audio track in the mp4 file.
yusesope
#3098 Post by yusesope » Mon Sep 28, 2020 7:39 am
iamTa wrote: Sat Sep 26, 2020 12:41 pm I've just tested this and it works perfectly on an Nvidia Shield!
Thanks for the feedback
Tomas wrote: Sun Sep 27, 2020 7:40 pm unfortunately the link does not work :(
With my second upload I should have solved the missing libraries problem.
Refer to THIS post (ignore the red line).
Keep in mind that you are in the middle of a testing phase (FEL -> MEL, read HERE an HERE).
To create unmodified files, just use "MUX.bat" and "DEMUX.bat" (following the same logic of the instructions of the first linked post)
Decidueye
#3099 Post by Decidueye » Mon Sep 28, 2020 7:58 am
Yes, I did not use the TrueHD audio. I used the AC3 one for testing purposes. I also do not have dedicated streaming devices like the Shield.
Only tried playing it back through DLNA (through a Windows 10 PC) and USB drive using LG's WebOS app / internal player. Also the error message is "File is not recognized". But it should work since the OP used his USB drive as well?
mirror88
#3100 Post by mirror88 » Mon Sep 28, 2020 10:20 am
Thank you for your great works. If you like, I can provide a zidoo z9x media player for your test. It does not require a special version of exoplayer to be installed. DV Mel MKV files can be played directly.
Tomas
#3101 Post by Tomas » Mon Sep 28, 2020 10:38 am
yusesope wrote: Mon Sep 28, 2020 7:39 am
My Windows download link doesn't work.
iamTa
#3102 Post by iamTa » Mon Sep 28, 2020 11:49 am
Tomas wrote: Sun Sep 27, 2020 5:39 pm Everything played perfectly. May I ask how did you convert from FEL to MEL?
thank you very much
So these are the steps I take to convert FEL to MEL and remux with TrueHD/Atmos into an MKV:
  • Extract hevc streams with ffmpeg: ffmpeg.exe -i X:\BDMV\STREAM\XXXXX.m2ts -map 0:0 -c copy X:\BL.hevc -map 0:1 -c copy X:\EL.hevc
  • Feed both hevc files from step 1 into MUX_AND_CONVERT_TO_MEL.bat
  • Feed single hevc file from step 2 into DEMUX.bat
  • Use latest tsMuxeR nightly, add both hevc files from step 3 into input along with X:\BDMV\STREAM\XXXXX.m2ts from step 1, remove duplicate video tracks and output to ISO
  • Use MakeMKV to convert ISO to MKV
These MKVs can then be played back using the modded ExoPlayer and potentially the latest Emby beta (I've not tested Emby).
I've converted and tested a few full length movies and the above method works flawlessly.
Thank you yusesope for all your hard work.
deadchip12
#3103 Post by deadchip12 » Mon Sep 28, 2020 12:10 pm
iamTa wrote: Mon Sep 28, 2020 11:49 am
thank you very much
Does this have any benefit versus the original method in the first page if I own a c9 oled tv? Sorry haven't followed this thread for a while.
Tomas
#3104 Post by Tomas » Mon Sep 28, 2020 12:43 pm
thank you very much
Can I ask for the ffmpeg download link?
userr
#3105 Post by userr » Mon Sep 28, 2020 12:58 pm
Ive been reading this thread for a very long time, but i settled for a method that works for me, and im wondering, would there be benefits of doing it differently / with newer tools?
Im still using:
- tsMuxer (can be any version im just using it for demuxing)
- bl_el_rpu_builder_v0.0.4_alfa_initial_release (combining BL+EL+RPU)
- v1.0.0 mp4muxer (making the final .mp4)
Im using profile 4 with mp4muxer
I know i do not get lossless audio with this, but with my current setup it is not necessary, but i wonder, is there benefit picturewise to change these tools/steps?
Im in the process of buying new audio equipment so i guess i have to rerip everything (i guess thats one big downside of doing the mp4s)
Thank you
