Can't Rip "The Simpsons Movie" D'oh!
JohnnyPhantom
#1 Post by JohnnyPhantom » Wed May 20, 2020 2:16 pm
I've been trying to Rip this movie for a while now.
I've tried about 9 or 10 different drives (of different makes and models), some less than a year old, some less than a week old, tried different machines, on Mac OS X 10.13, 10.14, and 10.15, Windows 7 Home Premium, and Windows 10 Pro, and tried 5 different retail copies of this disc as well. I even lent the movie to a buddy with MakeMKV, same issue, it just will not rip.
I can copy all the files to my hard drive, and point MakeMKV to that folder and try to rip, and it acts the same way as ripping from the BluRay disc itself
Every so often, when a new version of MakeMKV releases I try all over again.
What can I do to rip this movie/disc? What information could I give to help troubleshoot? Can anyone rip this disc?
I've attached the latest log output to this post. I was unable to just copy and paste it in a reply, to large. Even the .txt file was too large, had to zip it first
MakeMKV_log.zip
(2.84 MiB) Downloaded 1080 times
Re: Can't Rip "The Simpsons Movie" D'oh!
#2 Post by Woodstock » Wed May 20, 2020 3:57 pm
Knowing what the exact error message(s) were goes a long way towards solving an issue.
JohnnyPhantom
#3 Post by JohnnyPhantom » Wed May 20, 2020 5:32 pm
Attached the log file to original post, took longer than I thought
Ezatoka
#4 Post by Ezatoka » Wed May 20, 2020 11:52 pm
What kind of Protection is shown in the MakeMKV window before you make the backup?
If you can copy all the files onto your hard disk without any problem, one could think the error is not a read error on the discs surface.
Throwing a guess out: Somehow the aacs certificate files on the disc are corrupt. MakeMKV tries to decrypt the m2ts files with wrong/no keys and gets these messages.
JohnnyPhantom
#5 Post by JohnnyPhantom » Thu May 21, 2020 3:03 pm
AACS v4, BD+ v2007.10
JohnnyPhantom
#6 Post by JohnnyPhantom » Mon Jun 01, 2020 1:16 pm
Any ideas?
JohnnyPhantom
#7 Post by JohnnyPhantom » Sun Sep 27, 2020 10:19 pm
Tried in 1.15.2, still exact same issues
#8 Post by Woodstock » Sun Sep 27, 2020 11:53 pm
What we can see of the errors are similar to what happens when the surface of the disk is contaminated or scratched. If read errors occur during the early stages of ripping, when the key information is read, pretty much everything else is going to fail.
Can we assume you went through the items in the "Read this if you're having errors" message pinned to the top of this forum?
JohnnyPhantom
#9 Post by JohnnyPhantom » Mon Sep 28, 2020 12:21 am
Hey woodstock,
thanks for the reply. I've gone over the read this if having errors list many times, and no luck. I've tried 5 copies of the movie (3 preowned, and 2 brand new sealed) and about 5 blu ray drives, and 6 different machines (mac and windows) and same results each time.
What else can I try?
JohnnyPhantom
#10 Post by JohnnyPhantom » Tue Sep 29, 2020 4:21 pm
Just tried another machine, with another blu ray drive, tried one of the new copies of the movie straight from the box today, and then after a good cleaning, still no luck. I can copy all the data from the disc to the desktop and backup the disc from MKV but even then, I cannot rip the files into a MKV with MakeMKV
#11 Post by Woodstock » Tue Sep 29, 2020 6:32 pm
It will do a complete backup, but won't convert to MKV?
I suggest you follow the FAQ in my signature and send the requested information to support@makemkv.com with a pointer to this topic. Mike has been distracted a lot with the UHD stuff, and may not have see this.
If you open the backup with MakeMKV, does it still fail converting to MKV?
Ezatoka
#12 Post by Ezatoka » Tue Sep 29, 2020 6:48 pm
Does the BluRay can be played after making the full disk backup?
I'd suggest downloading VLC portable if you don't have it. With Ctrl+D you can open the Drive menu. There select BluRay and then Browse to the directory containing the BDMV directory.
JohnnyPhantom
#13 Post by JohnnyPhantom » Wed Sep 30, 2020 3:55 pm
I tried this with no luck. VLC said i didn't have library's for Blu ray, so I fixed that, now says cant decode a BD+ blu ray. and that's where I got stuck
Ezatoka
#14 Post by Ezatoka » Wed Sep 30, 2020 3:57 pm
Didn't you were able to make a decryptep backup with MakeMKV?
JohnnyPhantom
#15 Post by JohnnyPhantom » Mon Feb 07, 2022 1:05 pm
I got a few more copies (mix of used and new) of this movie, so about.... 9 total now. Latest version of MakeMKV Still the same results. Has anyone been able to rip the bluray version of "The Simpson movie"? I'll keep getting discs and drives as i see them in the wild. I'm crazy determined like that.
