A different "Save Failed" issue
dhstraayer
Post by dhstraayer »
Working from a previously ripped set of video files (ripped by MagicDVD). Win 7. Using default drive for output file. This one goes through the whole save process, about 7 or 8 minutes, and then issues a "save failed" error at the end. I've attached the log file.
setarip_old
Re: A different "Save Failed" issue
Post by setarip_old »
Hi!
Try using your original, commercial DVD as the source for a new, DIRECT rip and conversion by MakeMKV...
dhstraayer
OK, workarounds are fine. But when evaluating software I like to see some actual attention paid to finding and fixing bugs.
setarip_old
What I've suggested is NOT a workaround - On the contrary, by now using your original, commercial DVD as the source material, it's a means of determining whether your other source material ("a previously ripped set of video files [ripped by MagicDVD]") is flawed...
Post by mike admin »
There is not much information in the log except that source file is apparently corrupt in a strange way. Please re-run from your original DVD disc and see if the same error shows up.
