I recently got several UHDs... some of them are used. I was able to rip Star Trek just fine but then when I went to rip Black Hawk Down and Alien i get a corrupted file message. The discs look perfect on the back. I cleaned them vigorously with a microfiber and tried again. No luck. I even tried to backup the discs but got the same sort of message.
I have burned about 25 UHD in the past and only had this problem once before which I figured was a bad disc. This was on Justice League, but having two in a row leads me to believe there is something else going on.
I am running what I think is the correct firmware for my drive. It is an ASUS BW-161HT. I am using the (Modified) ASUS ODD FW Changer and selecting "ASUS-BW-161HT-3.10-WM01601-211901041014" dated 3/19/2019.
I am happy to supply logs and anything else... just not sure where they are. If you tell me I can supply.
Any help is much appreciated.
Alien and Black Hawk Down Won't rip, ASUS BW-16D-1HT
stepmback
Re: Alien and Black Hawk Down Won't rip, ASUS BW-16D-1HT
https://www.makemkv.com/faq/item/8
MakeMKV tells you where it is storing logs when it first starts up if you have debug logging turned on.
stepmback
Here is the log for Alien UHD I tried to rip. I ran this after flashing to what I think is the latest FW for this drive provided on MakeMKV. It got to about 20GB then errored out.
I am attaching the log file.
Here is some drive information along with FW:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: SIK92H5PB123
Bus encryption flags: 1F
Highest AACS version: 72
Firmware version: 3.10
Disc Information
Label: ALIEN
Timestamp: 2019-02-13 14:46:09
Data capacity: 88.45 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Disc Information
Label: ALIEN
Number of layers: 3
An example from the log… one I haven't seen before.
The bottom of the log reports this:
Read errors usually mean the disc is scratched or dirty; or at least that the drive is having trouble reading data from the disc.
001003:0020 DEBUG: Code 101000192 at SnjLlET?7*kAC=V3:29402762
001003:0020 DEBUG: Code 101000192 at <n#P\T%TRbfQ<%b::213130559
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00713.m2ts' at offset '72923136'
001003:0020 DEBUG: Code 3221225488 at EalGM?7C*|p0H2?.2hBq!pNe:29394091
001003:0020 DEBUG: Code 3221225488 at <n#P\T%TRbfQ<%b::213130559
002003:0000 Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '72923136'
DEBUG: Code 3221225488 at WeCdm# ?*))&YS;*<2:29394827
001003:0020 DEBUG: Code 3221225488 at WeCdm# ?*))&YS;*<2:213131433
001003:0020 DEBUG: Code 3221225488 at <n#P\T%TRbfQ<%b::213130559Code: Select all
002023:0000 Encountered 15 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
error=0x06031105 count=15 name=Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
Encountered 157 unclassified errors
error=0x06052400 count=101 name=Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB
error=0xC0000010 count=51 name=OS error - The specified request is not a valid operation for the target device
error=0xC000009C count=5 name=OS error - STATUS_DEVICE_DATA_ERROR
