1.15.2 fails to compile
plittlefield
Post by plittlefield » Fri Aug 14, 2020 1:06 pm
Latest release 1.15.2 fails to compile in Ubuntu Linux.
Lots of errors but here are the last few lines...
In file included from ./libmatroska/inc/matroska/KaxCluster.h:41:0,
                 from ./libmakemkv/inc/libmkv/internal.h:36,
                 from libmakemkv/src/version.cpp:22:
./libmatroska/inc/matroska/KaxBlock.h:146:24: warning: defaulted and deleted functions only available with -std=c++11 or -std=gnu++11
     ~KaxBlockGroup() = default;
In file included from ./libmakemkv/inc/libmkv/internal.h:42:0,
./libmatroska/inc/matroska/KaxInfoData.h:57:36: warning: defaulted and deleted functions only available with -std=c++11 or -std=gnu++11
     KaxPrevUID(EBML_EXTRA_PARAM) = default;
./libmatroska/inc/matroska/KaxInfoData.h:67:36: warning: defaulted and deleted functions only available with -std=c++11 or -std=gnu++11
     KaxNextUID(EBML_EXTRA_PARAM) = default;
In file included from libmakemkv/src/stdstring.cpp:21:0:
./libmakemkv/inc/lgpl/stdstring.h:50:27: warning: defaulted and deleted functions only available with -std=c++11 or -std=gnu++11
         inline string() = delete;
./libmakemkv/inc/lgpl/stdstring.h:51:44: warning: defaulted and deleted functions only available with -std=c++11 or -std=gnu++11
         inline string(const char* value) = delete;
./libmakemkv/inc/lgpl/stdstring.h:67:29: error: expected ‘,’ or ‘...’ before ‘&&’ token
         inline string(string&& value) { data = value.data; value.data = (char*)emptyString; }
./libmakemkv/inc/lgpl/stdstring.h:67:37: error: invalid constructor; you probably meant ‘buf::string (const buf::string&)’
libffabi/src/ffabi.c: In function ‘ffm_init’:
libffabi/src/ffabi.c:153:5: warning: ‘avcodec_register_all’ is deprecated [-Wdeprecated-declarations]
     avcodec_register_all();
In file included from libffabi/src/ffabi.c:22:0:
/tmp/ffmpeg/include/libavcodec/avcodec.h:4159:6: note: declared here
 void avcodec_register_all(void);
Makefile:75: recipe for target 'out/libmakemkv.so.1.full' failed
make: *** [out/libmakemkv.so.1.full] Error 1
As a test, I ran the same procedure for 1.15.1 and that compiled fine.
Paully
Re: 1.15.2 fails to compile
Post by mike admin » Fri Aug 14, 2020 8:43 pm
plittlefield
Post by plittlefield » Sat Aug 15, 2020 1:57 pm
CFLAGS="-std=gnu++11" fixed it for me.
So, my full command line (for no gui) is...
CFLAGS="-std=gnu++11" PKG_CONFIG_PATH="/tmp/ffmpeg/lib/pkgconfig" ./configure --disable-gui
make
sudo make install
mdPlusPlus
Post by mdPlusPlus » Fri Sep 18, 2020 10:25 am
I'm still getting the following error when compiling makemkv-oss:
/usr/bin/ld: -lQt5Core kann nicht gefunden werden
collect2: error: ld returned 1 exit status
make: *** [Makefile:94: out/makemkv.full] Fehler 1
bib1963
Post by bib1963 » Sun Sep 20, 2020 11:33 am
That should not be difficult for someone to fix.
You do not have the Qt5Core devel libs installed.
On opensuse, it's something like libQt5Core-devel-5.blahblahblah.rpm
If you do have it installed, then I assume you need a '-L' to the directory where is is installed for the linker.
mdPlusPlus
Post by mdPlusPlus » Thu Sep 24, 2020 6:12 pm
bib1963 wrote: Sun Sep 20, 2020 11:33 am That should not be difficult for someone to fix.
I have `libqt5core5a` installed (Ubuntu 20.04). There doesn't seem to be a dev package, judging by `apt search libqt | grep dev`.
I also tried several methods of linking `/usr/lib/x86_64-linux-gnu` like recommended in other forums, but so far I'm out of luck.
bib1963
Post by bib1963 » Sun Sep 27, 2020 11:57 am
Post "find / -name libQt5Core\*"
mdPlusPlus
Post by mdPlusPlus » Thu Oct 08, 2020 4:19 pm
bib1963 wrote: Sun Sep 27, 2020 11:57 am Post "find / -name libQt5Core\*"
$ find /usr -name libQt5Core\*
/usr/lib/x86_64-linux-gnu/libQt5Core.so.5.12
/usr/lib/x86_64-linux-gnu/libQt5Core.so.5.12.8
/usr/lib/x86_64-linux-gnu/libQt5Core.prl
mdPlusPlus
Post by mdPlusPlus » Fri Feb 26, 2021 1:41 pm
A simple
sudo apt reinstall qtbase5-dev
seems to have fixed my issue. I have no idea how I haven't tried that sooner.
