Thank you very much!yusesope wrote: ↑Sat Sep 26, 2020 8:21 amRESET_9999 wrote: ↑Thu Sep 24, 2020 10:23 pmyep, it looks like @yusesope fel to mel conversions are done properly.
https://screenshotcomparison.com/comparison/6581
This behavior is normal. If you give TsMuxeR a raw hevc stream consisting of BL+EL+RPU, TsMuxer will only be able to assign profile 7.
Do you want profile 8? You have to import a stream with only BL+RPU into TsMuxeR. To do this, right click on "MUX.bat" and "MUX_AND_CONVERT_TO_MEL.bat" and then select "Edit". Add the string -mode 2 in both and save the changes. At the moment, however, I do not recommend proceeding with this solution. Read on to understand why.
PS:
the name of the file created will always be BL_EL_RPU.hevc but it is simply a placeholder for people who are "too lazy"to use the command line
I honestly don't understand why you guys care so much about profile 5.
It uses a proprietary color space (the advantages of which will perhaps be appreciable when we have 12bit panels) and not having an Enhancement Layer is definitely lower quality than a UHD-BD. So why?
Converting a color space involves an encoding operation, and if you wait for me to write an encoder from scratch then the wait will be very long (years).
I'm sure there are people in the world who are already working on it. I don't have the skills for that!
Instead I am doing some experiments on profile 8 (in particular 8.1). The idea is to improve my -mode 2 (UHD-BD -> 8.1). This profile should work for any "streaming device" (from televisions to consoles). What do you think?
x265 does not need a parser for RPU. It simply accepts a file containing the RPUs (I presume sorted according to each access unit present in the Base Layer). Look HERE.
What's the problem? If you proceed with an encoding of the Base Layer then you must also change the parameters of the RPU. At the moment, however, we do not know the algorithm that allows to generate new RPUs!
Tested and works in firestick.yusesope wrote: ↑Sat Sep 26, 2020 8:21 amBefore releasing version v0.0.4_BETA I need one last test: an STDL FEL-> MEL file inside the MKV container (to be tested on a device like the FireStick 4K, capable of playing MEL profile 7 but not FEL profile 7 ). Of course you have to use my version of ExoP.
Always using the various conversion steps FEL -> MEL, instead of creating an m2ts MEL DTDL in TsMuxeR, generate an ISO (always adding first BL.hevc and then EL_RPU.hevc in TsMuxeR) and feed it to MakeMKV.
Thanks for your invaluable help!
Thanks for reporting! I hope Private Ryan is an exception. If you do any more tests, please let us know the results!PapitaHD wrote: ↑Sat Sep 26, 2020 9:35 amBad news... After you'd said it's flickering I checked Saving Private Ryan again with longer samples and sadly it really flickers on C8 and M9702 too.
Final conclusion: STDL MEL (and DTDL MEL) flickers but STDL FEL doesn't.
Strange thing is that Transformers 4 (which has about the same bitrate for its FEL) works perfectly after the MEL conversion, no flickering at all.
I'm gonna test a few more titles.
Ciao mike!
Today @lexyz and @PapitaHD started the "bug hunting" day
It seemed rude not to invite you to play with us
Maybe (and just maybe) I ran into a MakeMKV bug.
THIS 60 sec sample comes from the Spears & Munsil UHD-BD. It is a file with DV MEL but MakeMKV does not recognize it as such and generates a DV-free mkv.
I believe your logic is based on analyzing the nonlinear quantization parameters. The problem is that these RPUs don't have any (due to the value of the boolean disable_residual_flag). You should add a safety net for this non-standard file type.
I've just tested this and it works perfectly on an Nvidia Shield!yusesope wrote:Before releasing version v0.0.4_BETA I need one last test: an STDL FEL-> MEL file inside the MKV container (to be tested on a device like the FireStick 4K, capable of playing MEL profile 7 but not FEL profile 7 ). Of course you have to use my version of ExoP.
I've created a few mkv's with the method yusesope described (converting to MEL with method2, creating ISO with tsMuxeR then remux it with MakeMKV), so others can test them, unfortunately I don't own a device which would be able to play DV-mkv.
Saving Private Ryan is among them, would be interesting to see whether it flickers in an mkv container too or not.
Gladiator & Kick-Ass: https://we.tl/t-eDu4zjnQj0
Apocalypse Now: https://we.tl/t-SJaD5a4ExL
Transformers 4: https://we.tl/t-z6Oos2hHxy
Saving Private Ryan: https://we.tl/t-IgV2cbcSuY
I checked all of them and only Saving Private Ryan flickers.
Because I have a another DV TV with an appleTV in another room.yusesope wrote: ↑Sat Sep 26, 2020 8:21 amI honestly don't understand why you guys care so much about profile 5.
I'm not sure about that, The Sony x700 , the Windows 10 Movies & TV app can tone map on the fly, profile 5 full range to HDR10 bt2020 or SDR bt709. The vertex 2 can also do that.
But i do get that in order to obtain a new/proper profile 5 file, encoding is required.
the encoder (x265.exe) already exists for that.. I was just asking for a tool that can extract the RPU information to a file that would be accepted in x265.exe
it's all fine, it was a long shot. I was just hoping for more magic coming from you
I appreciate all the work you've done.
Hey yusecope, so I went back and reread the FAQ posted here: https://forum.blu-ray.com/showpost.php? ... tcount=119 again just to better understand what the conversion is doing in the big picture. Referring to the image snippet of the dolby docs in that post, lets take for example some FEL content that was mastered on a 4000-nit display and then split up into a 1000-nit base layer and an EL that’s required to reconstruct the original picture. When converting to MEL, am I correct to understand that your tool is not actually converting the base layer to 4000 nits with information from the EL, but instead modifying the RPU so that it can tell the decoder later during playback that no extra picture information exists on the EL, thus treating the entire file as MEL? So in a sense, this is a more sophisticated version of your previous -mode 2 conversion?yusesope wrote: ↑Thu Sep 24, 2020 11:07 amThere are multiple reasons why the FEL structure is intact in my MEL files.
This is not the important thing.
What matters, in my opinion, are the NALu RPU. Imagine the latter as an orchestra conductor. With the right changes I can explain to the Decoder that it does not have to start a second decoding session (as happens in FEL files) but to use "a static image" as substrate (as happens with MEL files) regardless of the presence of FEL data.
This is the goal.
These all played perfectly in DV with no flickering on a LG C9 with an Nvidia Shield and the modded Exoplayer.PapitaHD wrote: ↑Sat Sep 26, 2020 12:55 pmI've created a few mkv's with the method yusesope described (converting to MEL with method2, creating ISO with tsMuxeR then remux it with MakeMKV), so others can test them, unfortunately I don't own a device which would be able to play DV-mkv.
@jcdr428
With the nightly build version of TsMuxeR on Sept 25th, If I choose the TS output format, Plex Server can not detect the TrueHD sound track, only an AC3-5.1 sound track. Plex on Shield TV Pro 2019 can not play the ts file, the picture freezes.
If I choose the M2TS output format, everything is OK.
I have tested 2 movies, got the same result.
Plex Server and Plex Android App are both the latest version.
These are my steps:
1. Use FFMPEG to split BL and EL layer from the UHD Bluray Disk.
2. Use the Mux python script by yusesope to get BL_EL_RPU.hevc.
3. Use TsMuxeR GUI to mux the final TS or M2TS, all the TsMuxeR GUI options are default. Only 2 tracks are selected to mux.
These are my steps:
MUXOPT --no-pcr-on-video-pid --vbr --vbv-len=500
#V_MPEGH/ISO/HEVC, "D:\Downloads\Leon.The.Professional.1994.MULTi.COMPLETE.UHD.BLURAY-MONUMENT\BDMV\STREAM\00023.m2ts", track=4113
#V_MPEGH/ISO/HEVC, "D:\Downloads\Leon.The.Professional.1994.MULTi.COMPLETE.UHD.BLURAY-MONUMENT\BDMV\STREAM\00023.m2ts", track=4117
#A_DTS, "D:\Downloads\Leon.The.Professional.1994.MULTi.COMPLETE.UHD.BLURAY-MONUMENT\BDMV\STREAM\00023.m2ts", track=4352, lang=deu
A_AC3, "D:\Downloads\Leon.The.Professional.1994.MULTi.COMPLETE.UHD.BLURAY-MONUMENT\BDMV\STREAM\00023.m2ts", track=4353, lang=eng
#A_DTS, "D:\Downloads\Leon.The.Professional.1994.MULTi.COMPLETE.UHD.BLURAY-MONUMENT\BDMV\STREAM\00023.m2ts", track=4354, lang=und
#S_HDMV/PGS, "D:\Downloads\Leon.The.Professional.1994.MULTi.COMPLETE.UHD.BLURAY-MONUMENT\BDMV\STREAM\00023.m2ts", fps=24, track=4768, lang=deu
#S_HDMV/PGS, "D:\Downloads\Leon.The.Professional.1994.MULTi.COMPLETE.UHD.BLURAY-MONUMENT\BDMV\STREAM\00023.m2ts", fps=24, track=4769, lang=eng
#S_HDMV/PGS, "D:\Downloads\Leon.The.Professional.1994.MULTi.COMPLETE.UHD.BLURAY-MONUMENT\BDMV\STREAM\00023.m2ts", fps=24, track=4770, lang=deu
V_MPEGH/ISO/HEVC, "D:\tmp\BL_EL_RPU.hevc"
I am not a native English speaker.
Sorry for my bad English.
It is a good sign
Thanks for the files!
I see. Profile 5 only? No profile 8?RESET_9999 wrote: ↑Sat Sep 26, 2020 3:46 pmBecause I have a another DV TV with an appleTV in another room.
I think so too. Also because all the examples you mentioned occur during the decoding phase, using the previously encoded information.RESET_9999 wrote: ↑Sat Sep 26, 2020 3:46 pmBut i do get that in order to obtain a new/proper profile 5 file, encoding is required.
The concept of "-mode 2" should remain associated with those profiles (5/8) in which the EL is completely absent (and the RPUs have a different structure). In this case I'm trying to mimic the behavior of a MEL file.
During decoding, the image generated by the data present in EL represents a residue (difference) of the original video content compared to the image obtained by processing the data present in BL.shawnc22 wrote: ↑Sat Sep 26, 2020 4:46 pmWhen converting to MEL, am I correct to understand that your tool is not actually converting the base layer to 4000 nits with information from the EL, but instead modifying the RPU so that it can tell the decoder later during playback that no extra picture information exists on the EL, thus treating the entire file as MEL?
EL is a 10-bit video bitstream that carries the residual between the mezzanine source and the base layer and the dynamic metadata for Dolby Vision.
By modifying the RPU the idea is to tell the decoder that the residual signal is equal to zero and that it should not bother to "read" the content.
The rest of the information, both static (eg, MaxFALL and MaxCLL) and dynamic (eg, min, max and avg luminance of each shot) remain unchanged.
By giving up the process of decoding the data in EL, I think it is normal that it is no longer possible to generate the 12bit signal as it was mastered by the creators (using monitors up to 10000 nits).
Keep also in mind that current consumer displays rarely exceed 2000 nits (LCD). OLEDs peak at 600-700 nits, and few home projectors are lucky enough to hit 150 nits. When the signal exceeds the capability of the TV, tone mapping is activated by reducing the luminance as the signal approaches the clipping point of the display (following a Perceptual Quantizer (PQ) curve, remaps luminance from the source values to the lower values the display can support)
Hello everyone first post here complete newbie. I wanted to try if Dolby Vision playback with Mission Impossible movies is possible with my LG C9
First tried with Ghost Protocol. I followed the instructions on the first post and double checked, the new mp4 is successfully created but it doesn't work. The TV cannot read the file and says it is not supported.
Is there something I did incorrectly or is it because of the file or my TV?
Everything played perfectly. May I ask how did you convert from FEL to MEL?PapitaHD wrote: ↑Sat Sep 26, 2020 12:55 pmGladiator & Kick-Ass: https://we.tl/t-eDu4zjnQj0
thank you very much
unfortunately the link does not workyusesope wrote: ↑Thu Sep 17, 2020 5:54 pmIt always warms the heart to see "archlinux" written somewhere. Thanks for your feedback.
Yes you are right. Your Windows needs THESE libraries (unpack the archive and place the two dll files where there are the files MUX.bat, DEMUX.bat, etc ...). It's not an elegant solution but it should at least work for these days of testing.
Let me know!
The files that are created by this latest version have as VUI:
0,9,16,9,2 for the Base layer
0,9,16,9,2 for the Enhancement layer.
The correct profile should therefore be 7.
Now I don't remember well but it seems to me that TsMuxeR currently generates files with profile 6 (but, I repeat myself, I could be wrong). If my tool proves to work, in my opinion, we should try to mark the ts files with profile 7 (and not 6).
Yep, Exactly!
What audio file did you create for your mp4?Decidueye wrote: ↑Sun Sep 27, 2020 9:52 amHello everyone first post here complete newbie. I wanted to try if Dolby Vision playback with Mission Impossible movies is possible with my LG C9
Your LG won’t play an mp4 if the audio is True-HD.
Is there a way to convert dvhe.07.06, EL+RPU.mp4 file to Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU or dvhe.05.06, BL+RPU profiles?
Unfortunately my LG OLED TV plays the dvhe.07.06, EL+RPU.mp4 file in "Green screen":
