New here. Am I on right track? Archgon MD-8107-UHD. Rebadged LG BU40N. Flashing question
njweb
Post by njweb » Fri Sep 25, 2020 5:57 pm
Hey everyone. New to the forums.
Based on recommendations here, I am getting an Archgon MD8107-UHD external BD burner (rebadged LG BU40N) drive (arrives tomorrow).
I wanted drive that can read old discs (have many old burned CD/DVD discs from ~2002 that my Samsung USB DVD drive does not read. My Asus external BD-R drive -BW-12D1S-U - reads them fine, but it is too bulky for every day use, hence the Archgon; I figured I may as well get something with BD-R and UHD support at the same time.
Anyway I want to enable UHD disc reading on the Archgon (BU40N).
Been reading the threads here https://www.makemkv.com/forum/viewtopic ... 873#p70284 (and saw the video on youtube too), but just to be sure I am on the right track and do not brick my drive on day 1 (done a lot of flashing in my day, but new to the UHD scene...).
Are these the right steps?
1) I downloaded the following: https://www.mediafire.com/file/mezq26ac ... 9.zip/file
I.e. Modified) ASUS ODD FW Changer (24.08.2019) + UHD Friendly Firmwares + Latest MK Pack (20.07.2020.zip
I believe this is the latest zip.
2) Unless I am mistaken, I just need to run the above flasher (.exe of course) and select the right fw binary for my drive (BU40N series).
Anything else (since mine is rebadged or if I am on the wrong track)?
I believe there are two fw options for the BU40N:
Either the official v1.00 firmware or custom v1.03MK BU40N firmware?
Any recommendation as to whether to go with official 1.00 or 1.03MK?
Still new to UHD, so appreciate any recommendations between the two versions?
I did not see the latter 1.03 in the flasher zip, but can I use this one in a thread to which Billy linked (post my Mike Admin)?
https://www.makemkv.com/forum/viewtopic ... 19&t=19422
https://www.makemkv.com/forum/download/file.php?id=1937
Thanks in advance!
Re: New here. Am I on right track? Archgon MD-8107-UHD. Rebadged LG BU40N. Flashing question
Post by MartyMcNuts » Sat Sep 26, 2020 1:44 am
Thanks in advance!
Please don't post the same question in multiple threads. I have answered you in the other thread.
njweb
Post by njweb » Sat Sep 26, 2020 4:29 am
Thanks Marty!
Yes, I decided (while my new thread was awaiting approval) that it might be best to post in the existing thread (although I did not know at the time that a new reply also required approval).
I will reply to you in the other thread, thanks again.
