Ava 2020 - Cant recognize disc
cman0101
Post by cman0101 »
Can't recognize disc on LG WH14NS40 :(
Anyone have luck with this one?
Re: Ava 2020 - Cant recognize disc
The 4K UHD version or Bluray?
cman0101
Post by cman0101 »
Bluray
Are you getting "No disk" or some other error? "No disk" means the drive doesn't recognize the format of the disk, which can be a bad disk, a dirty disk (most likely smudges in the area of the hub hole), or the drive is having issues.
Does it recognize other BDs?
puertorican
Post by puertorican »
These Redbox-released discs will only work in older drivers. Works on LiteOn and my Panasonic UJ-260 but not on the LGs. The same issue happened with their Becky movie.
cman0101
Re: Ava 2020 - "No disc inserted"
Post by cman0101 »
Sorry it actually says "No disc inserted"
It's not the drive - I did a few before and after attempting this one.
I noticed this bluray appears to be a bit thicker and very rounded edges...Like the one that "Beckey" was on that a lot of people also had issues with. Is this a new type of disc that has new protection or something? strange.
cman0101
Post by cman0101 »
puertorican wrote: Sat Sep 26, 2020 1:07 am These Redbox-released discs will only work in older drivers. Works on LiteOn and my Panasonic UJ-260 but not on the LGs. The same issue happened with their Becky movie.
Oh strange - this is a redbox release. I appreciate the information. Is this a new type of protection or something?
Logan8972
Post by Logan8972 »
Nope it’s not new protection, libre drives which is a hack drive patch for some reason can’t read certain Blu-ray Disc, use any old bluray drive that can read Blu-ray Disc and mkv will decrypt the bluray as usual
phillip9
Post by phillip9 »
oh.. darn.
I have an internal LG blu-ray drive (BU40N) & an external LG ( WH16NS40) blu-ray drive and neither drive can read the AVA blu-ray disc from Redbox.
coffeeroasted
Post by coffeeroasted »
I'm ripping Ava right now on my WH14NS40 drive. Originally it would just spin. I closed MakeMKV, opened/closed the drive tray, then re-opened MakeMKV. Initially it threw the same "No disc inserted". But I just tried to re-open the disc in MakeMKV and it came up immediately. *shrug*
avenger09123
Post by avenger09123 »
coffeeroasted wrote: Sun Sep 27, 2020 11:29 pm I'm ripping Ava right now on my WH14NS40 drive. Originally it would just spin. I closed MakeMKV, opened/closed the drive tray, then re-opened MakeMKV. Initially it threw the same "No disc inserted". But I just tried to re-open the disc in MakeMKV and it came up immediately. *shrug*
Tried your method, didn't work for me. My WH16NS40 wouldn't recognize it, and just assumed the drive was still empty.
That being said my BC-5500A recognized it immediately. Damn 8.5 MB a sec is so slow.
Another disc with a rounded edge. Another unreadable by LibreDrive. Huh. There's gotta be a commonality.
a_player_so_much_pun
Post by a_player_so_much_pun »
out of curiosity I got The Fanatic (another RB release) and that worked on a LibreDrive drive... just wanted to point out that historically around Becky time RbB changed the disc itself, indeed got changed (concurring with other assessments that the disc itself 'feels' different, more rounded edge)
mmmzon
Post by mmmzon »
I tried AVA from three different RBs, with the very same effect. No way to read it, no matter what I do.
OS device name: R:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: XXXXXX
Highest AACS version: 72
Firmware version: 1.02
No disc inserted <<< no way to change this status
Any wise words on how to bypass it?
mmmzon
Post by mmmzon »
The older and slower drive managed to get data off the disc, though. it seems it is related with newer (faster) drives or Libredrive firmware
OS device name: E:
Manufacturer: TSSTcorp
Product: BDDVDW SE-506BB
Revision: TS01
Serial number: XXXX
Bus encryption flags: 1F
Highest AACS version: 68
Drive platform: MT1939
Harware support: Yes
Firmware support: No
Firmware version: 05.21
DVD all regions: Possible, not yet enabled
BD raw data read: Possible, not yet enabled
BD raw metadata read: Possible, not yet enabled
sword4nsics
Post by sword4nsics »
I am getting the same issues. I have two drives that do not recognize the disc at all but my regular TV blue-ray drive reads and plays it just fine but not the two drives connected to my computer. A Buffalo libredrive/UHD activated and a stock unflashed external ASUS BW-16D1X-U. I am not sure what the issue is except some encoding on newer discs not yet available with these drives.
