Dual-layer FEL untouched VS Dual-layer MEL converted
https://screenshotcomparison.com/comparison/6565
the untouched FEL is brighter & has more punch, no doubt. But I think this is normal because I'm seeing the same kind(if not more) of difference when I compare the Spears and Munsil FEL & MEL
Spears and Munsil dual-layer FEL untouched VS Spears and Munsil dual-layer MEL untouched
https://screenshotcomparison.com/comparison/6564
Dual-layer MEL untouched VS Single-layer MEL (el+RPU) untouched
https://screenshotcomparison.com/comparison/6566
also from the bluray discs I inspected, FEL DV hevc stream is the actual movie with a white/grey tint on it while MEL DV is just a static white/grey image.
We still can see the video in the MEL conversion so that could be the reason why it doesn't play on the x700. I can add some random MEL track to any HDR10 hevc stream and it will still play in DV (single or dual layer). with some flickering but it triggers DV.
real FEL / real MEL / MEL conversion
