Michiel De Ruyter Fake Playlist
Kyioto
Post by Kyioto »
The Blu Ray of Michiel De Ruyter has 195 fake playlist options to choose from. I was wondering How I would go about picking the right playlist option
Re: Michiel De Ruyter Fake Playlist
viewtopic.php?f=6&t=16251
There are lots of posts on this forum on that topic. The link above is as good a place to start as any.
MakeMKV has a feature to try to detect the correct playlist in this kind of fake playlist scenario. https://www.makemkv.com/forum/viewtopic.php?f=8&t=14330
I assume MakeMKV didn't pick a playlist or picked the wrong one. Either way, submit a dump.
Kyioto
Post by Kyioto »
I was able to figure it out using the backup feature and then partnered the stream files to the segment map and found 551 and 774 playlist #s were the correct ones.
