MastaG
Post by MastaG »
Well fukk me..
I've created four different versions of Gemini Man.
All with the same source files:
BL_EL_RPU.hevc (created with -mux -fel_to_mel as I described a few posts back)
Gemini.ac3 (the core ac3 5.1 audio taken from the Blu-ray disc)
Now I've muxed four versions with mp4muxer with only difference in --dv-profile being 4, 6, 7 (as recommended by yusesope) and 8.
Producing:
Profile 04:
General
Complete name                            : test_dv4.mp4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (mp42/dby1/isom)
File size                                : 68.9 GiB
Duration                                 : 1 h 57 min
Overall bit rate                         : 84.3 Mb/s
Encoded date                             : UTC 2020-09-19 14:32:24
Tagged date                              : UTC 2020-09-19 14:32:24
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.04.09, BL+EL+RPU, SDR compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hev1
Codec ID/Info                            : High Efficiency Video Coding
Bit rate                                 : 83.7 Mb/s
Frame rate                               : 59.940 (60000/1001) FPS
Bits/(Pixel*Frame)                       : 0.168
Stream size                              : 68.4 GiB (99%)
Mastering display luminance              : min: 0.0010 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 5180 cd/m2
Maximum Frame-Average Light Level        : 1577 cd/m2
Codec configuration box                  : hvcC+dvcC+hvcE
Audio
Codec ID                                 : ac-3
Stream size                              : 536 MiB (1%)
Profile 06:
General
Complete name                            : test_dv6.mp4
Encoded date                             : UTC 2020-09-19 15:38:54
Tagged date                              : UTC 2020-09-19 15:38:54
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.06.09, BL+EL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hev1
Audio
Codec ID                                 : ac-3
Profile 07:
General
Complete name                            : test_dv7.mp4
Encoded date                             : UTC 2020-09-18 14:35:45
Tagged date                              : UTC 2020-09-18 14:35:45
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.09, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hev1
Audio
Codec ID                                 : ac-3
Language                                 : emg
Profile 08:
General
Complete name                            : test_dv8.mp4
Encoded date                             : UTC 2020-09-19 16:47:48
Tagged date                              : UTC 2020-09-19 16:47:48
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.08.09, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hev1
Audio
Codec ID                                 : ac-3
Now watch this:
https://streamable.com/4v5u4k
As you can see they all trigger DV.
But only the one being profile 08 (the last one) plays OK.
Why is that?
Perhaps profile 8 should be used for all Blu-ray DV rips then?
I'm going to try on Shield TV and also test all 4 of them with Emby client to see how well they play.
Post by shawnc22 »
MastaG wrote:
Sat Sep 19, 2020 6:49 pm
Well fukk me..
Producing:
Profile 04:
General
Video
Codec ID                                 : hev1
Audio
Codec ID                                 : ac-3
Profile 06:
General
Video
Codec ID                                 : hev1
Audio
Codec ID                                 : ac-3
Profile 07:
General
Video
Codec ID                                 : hev1
Audio
Codec ID                                 : ac-3
Language                                 : emg
Profile 08:
General
Video
Codec ID                                 : hev1
Audio
Codec ID                                 : ac-3
Now watch this:
Why is that?
Profile 8 is not supposed to have an EL according to Dolby specs. If whatever you're using for playback is following dolby standards, then it may just be ignoring the EL when it encounters a profile 8 video.
MastaG
Post by MastaG »
shawnc22 wrote:
Sat Sep 19, 2020 7:06 pm
That makes sense.. but they're virtually the same.
I cannot spot any differences.
Also for a MEL movie what does the enhancement layer contain?
hepe9
Post by hepe9 »
ragico wrote:
Sat Sep 19, 2020 4:49 pm
hepe9 wrote:
Sat Sep 19, 2020 12:39 pm
ragico wrote:
Sat Sep 19, 2020 12:33 pm
Try what?
If .pgs subtitles works with the firestick and exoplayer
As I said mp4 files do not support pgs subtitles so there is no way, at moment, to know if they are supported in exoplayer/firestick. I think we must wait for Tsmuxer m2ts format played via exoplayer to test this functionality.
But firestick can play m2ts?
Edit: I read It can
If Tsmuxer add this, pls try .pgs subtitles
Thank you :wink:
chros
Post by chros »
yusesope wrote:
Don't worry: your M9702 doesn't need a "conversion" FEL -> MEL.
That's not really true :)
Oppo can't playback single track dual layer files, but it can profile 5 single track single layer MEL files (BL+RPU, without EL).
So as someone just asked above: why don't you try to create BL+RPU instead of BL+EL+RPU? :) What's the reason behind this? Thanks
yusesope
Post by yusesope »
RESET_9999 wrote:
Sat Sep 19, 2020 3:08 pm
yes, MEL Single Track Double Layer made with your tool plays on the x700... but not the FEL ones and not the converted MEL ones.
ragico wrote:
Sat Sep 19, 2020 12:32 pm
Thr m2ts file plays in sony x700 via usb.
Dolby vision is triggered a couple of seconds after the play starts.
There is some heavy flickering here and there.
Third attempt guys!
Find the new file HERE.
Does it play on the FireStick and x700?
Thanks for your patience!
pitrako wrote:
Sat Sep 19, 2020 10:00 am
Profile 4 = It starts but lags until the image freezes.
Profile 5 = It plays correctly.
Profile 7 = Black screen, time does not advance.
Profile 8 id 1 = It plays correctly.
Profile 8 id 2 = It plays correctly.
fel_to_mel_test_2.mp4 (your test file)= Black screen, time does not advance.
No luck for me with profile 7 :( .
Why is that?
Profile 5 and 8 are not good in this case! These are files with Enhancement Layer and profile 5/8 does not have this layer. In addition, the HW DV decoder uses different decoding modes depending on the profile!
Bobr.BY wrote:
Sat Sep 19, 2020 10:41 am
to
yusesope
Pls make (compilation) new version ExoPlayer
I have already answered HERE
spezi wrote:
Sat Sep 19, 2020 1:40 pm
If I use FEL -> MEL then the resulting file size is the same as without that conversion. Is that right?
Normally MEL EL-file sizes are much lower.
Parameter -mode 2 doesn't delete EL data. Getting not a file BL+RPU.hevc, only BL+EL+RPU.hevc with similar size.
I'm using profile 5 on Windows 10 using mp4muxer. Only this works.
My idea does not include any video encoding but only a modification of the RPU units. It is therefore normal that the size is the same.
Don't worry, "-mode 2" works as it should. "BL+EL+RPU.hevc" is just a name like any other: if you use the command line you can assign it whatever name you like!
chros wrote:
Sun Sep 20, 2020 8:45 am
Profile 5 has a proprietary color space and it is not currently possible to convert a UHD-BD to Profile 5.
PlatypusW wrote:
Sat Sep 19, 2020 4:14 pm
I don’t think the intention of this experiment was to ‘fix’ any of that? This was more for other devices, e.g. firestick?
Yep.
It is for those devices which are unable to play FEL movies
ragico
Post by ragico »
@Yusesope
The new file fel_to_mel_test_3 plays correctly in firestick. No problem at all.
In sony x700 it plays with the same behaviour as the m2ts file I tested yesterday:
It starts as SDR and Dolby vision is triggered a couple of seconds after the play starts.
There is some heavy flickering here and there. Suddenly, for a fraction of a second, the colour changes, for example from red to blue, and then returns to red. This happens on the Despicable me title which is in red originally. But again this happens randomely on the entire test file, same as the m2ts I tested yesterday.
pitrako
Post by pitrako »
Stays at 00:00 again on exoplayer in PUS7304.
yusesope
Post by yusesope »
ragico wrote:
Sun Sep 20, 2020 4:44 pm
@Yusesope
Thanks for the update!
Maybe next weekend I'll try to come up with some new ideas :lol: !
pitrako wrote:
Sun Sep 20, 2020 4:56 pm
I'm sorry but the problem in your case is that your TV doesn't support files with profile 7.
ragico
Post by ragico »
@Yusesope
Update on m2ts test files.
In my previous post I have reported the problems playing the m2ts files (originated from Yusesope fel_to_mel_test2 and 3) played in sony x700 (a couple of seconds delay to trigger dolby vision and heavy flickering with random changes in colours).
I have redone these 2 m2ts files but, this time, I have used an old version of tsmuxer that generates profile 7 (used by me from long time to backup my UHD bluray discs) and not the actual last nightly.
The result is that both files (test2 and 3) play flawlessly in x7oo and all problems are gone.
Hope this can help.
Edit: Tsmuxer here: https://mega.nz/fm/BvRT1Daa
hepe9
Post by hepe9 »
@ragico I don't know, but maybe if you post the exact version it can help more to @yusesope :wink:
pitrako
Post by pitrako »
I read somewhere in this thread that some people triggers dolby vision in mx player, how? I have HW+ on and the max I get is HDR10+.
jcdr428
Post by jcdr428 »
ragico wrote:
Mon Sep 21, 2020 11:34 am
@ragico I can't download from your Mega link. Please give me a valid link and I will look at difference in outputs of this and latest tsMuxer version.
ragico
Post by ragico »
jcdr428 wrote:
Mon Sep 21, 2020 5:00 pm
https://we.tl/t-pIYtWh6Rj2
yusesope
Post by yusesope »
Great insight 8)!
Thank you for your time!
Let's wait for @jcdr428 to let us know.
Then we can start with some comparisons using the original FEL files.
The fact that you didn't have any problems this time gives me hope!
