ASUS BW-16D1HT - Failures after update
Mtenga
#1 Post by Mtenga » Fri Sep 18, 2020 10:24 pm
Just had my second 161 fail after making it UHD friendly. Both failed within two weeks of being updated using the easy update options from this site on the ASUS thread.
Surely can’t be coincidence?
Re: ASUS BW-16D1HT - Failures after update
#2 Post by Billycar11 » Fri Sep 18, 2020 11:17 pm
they are just junk get a BU40N
Ezatoka
#3 Post by Ezatoka » Sun Sep 20, 2020 10:59 am
You can't generalize that. I also have an ASUS BW-16D1HT and I ripped hundreds of DVDs and BluRays, there was never a single disc which I couldn't rip (though to be fair I only posess two UHDs, but also hadn't any problems with them)
Navvie
#4 Post by Navvie » Sun Sep 20, 2020 2:01 pm
Define failed?
Running 1.15.2 my 16D1HT regularly insists there is no disc in the drive, yet 1.15.1 sees the disc fine. It happens too often to be the drive or coincidence.
Registered user
Linux / Windows 10
Asus BW-16D1HT 3.10MK (disc exploded, taking out my second BW-16D1HT)
Asus BC-12D2HT 3.11MK
LG BH16NS40 flashed to WH16NS60 1.03
LG GGC-H20L 1.03
Pioneer BDR-205 GENE
#5 Post by Billycar11 » Sun Sep 20, 2020 7:59 pm
Yes I can you have 1 Asus drive I have had 100s and on average 25% of them are defective I flash and test those drives
Mtenga
#6 Post by Mtenga » Mon Sep 21, 2020 3:02 pm
Define failed?
Dead, deceased, passed on to the great drive repository in the sky.
Windows won’t see it anymore and there was no power to it. Now in the bin.
